Sort files by random order
gm649
Post by gm649 »
can you add "Sort by random" feature?
it will sort files in random order, so i can view image randomly
slide show has random order ,but we cant use view function like zoom
It will helps so much
Thank you
raysar
Re: Sort files by random order
Post by raysar »
I'm interesting for the same feature for a long time :/
Each time we click on "sort by random" a new random order is generated.
Hey people, are we the only people who need this important feature?
If you add this feature, think add random with recursive folder view :)
We live with so many thousand of picture, ramdom is the only solution to discover new one correctly.
I don't find other good software to do that randomly.
Sinon encore merci (au seul dev?) Pierre-Emmanuel Gougelet qui continue d'ajouter un max de fonctionnalités et de fiabilité au logiciel, bravo pour le taf, t'es un fou :D
raysar wrote: Mon May 18, 2020 3:08 am I'm interesting for the same feature for a long time :/
Why can you explain me, please?
winnylinny
Post by winnylinny »
I made this suggestion back in April: viewtopic.php?f=60&t=40337
Marsu42
Post by Marsu42 »
winnylinny wrote: Sat Jun 27, 2020 1:14 am I made this suggestion back in April: viewtopic.php?f=60&t=40337
+1 I'm missing a Sort by->ranrdom, too - it would be nice to have a semi-static random image order without the constraints of the slideshow mode.
I'd use it for blind image selection (like getting the 'best' pictures for an exposition), i.e. I wouldn't be biased by an image sequence that I already know or that can be expected.
