XnConvert for Android
Discussions on Android and iOS apps: XnPhotoFx, XnRetro, XnSketch, and so on.
I'm happy to announce XnConvert for Android
Moderator & Librarian
Re: XnConvert for Android
“XnConvert – Photo Resize, Compress & Convert” wrote:
It's the best way to resize, compress, add a logo, watermark or text on your photos or pictures, fast and easy.
XnConvert allows you to easily and quickly reduce the picture size or resolution before to send emails, or to share on social media like Instagram, Facebook, Twitter.
SELECT your photos
  • Select in the gallery your photos
  • Grid or Detail mode
  • Sort by filename, pathname, date
  • Group photos following criteria
BATCH convert, resize, compress photos
  • Mode to resize photos: Stretch, Fit In, Fit over
  • Predefined most-used photo resolutions
  • Bilinear or Lanzcos method
  • Sharpen
  • Add text to your photos
  • Add your watermark or logo to mark your photos - Affix your professional footprint
  • Convert into JPEG, PNG or WEBP format
EDIT single photo
  • Crop or rotate
  • Resize
Features:
  • Original photos are not modified
  • Choose the compression of output photos
  • Keep EXIF metadata
  • Keep original modified file's date
  • Custom image resolution
  • Create your own template, and use it for a batch convert
You can purchase the Pro version
  • No Ads
  • No template limit
  • No limit for batch convert
RESIZE PHOTO – RESIZE IMAGE – CROP IMAGE – PHOTO BATCH CONVERT
WATERMARK, TEXT, LOGO on Photos
Help us to improve XnConvert by sending your bugs or requests on Image
Facebook: http://www.facebook.com/xnview
Twitter: http://www.twitter.com/xnview
Icon based on work of ArrayOfLilly
Beta tester: Jens Pous
v1.02.9 (20.May.2019)
  • ISO placeholder
  • Setting to open template view when select 1 photo
  • Bugs fixed
v1.02.7 (14.May.2019)
  • EXIF not removed
  • Bugs fixed
v1.02.6 (07.May.2019)
  • With Pro version, number of template can't be > 2
  • Previous folder restored
  • Long press to view image in fullscreen
  • Crop problem
  • Watermark size is not correct
  • Text size is not correct
  • Position center added
  • Uppercase extension problem
  • Bugs fixed
v1.02.4 (03.Apr.2019)
  • German, Spanish, Italian, Japanese, Polish, Portuguese & Russian added
  • Bugs
v1.02.3 (01.Apr.2019)
  • French
  • Bugs
v1.02.2 (28.Mar.2019)
  • WebP
  • Bugs
v1.01.2 (22.Mar.2019)
  • Crash on Android <7
enzo.rodi
Post by enzo.rodi »
Hi
The exif metaddata after converting jpg to webp isnt available amymore. Is there a Special setting for webp files?
Thanks
Enzo
enzo.rodi wrote: Sun Aug 18, 2019 4:08 pm The exif metaddata after converting jpg to webp isnt available amymore. Is there a Special setting for webp files?
i'll check the problem...
enzo.rodi
Post by enzo.rodi »
Any progress so far ?
Regards
Enzo
enzo.rodi wrote: Fri Aug 30, 2019 1:28 pm Any progress so far ?
a fixed version will be available today
