XnConvert for Android
I'm happy to announce XnConvert for Android
Brian Gimbli
Re: XnConvert for Android
Post by Brian Gimbli »
I've been using XnConvert for a couple years on my PC, and when it will available on iPhone?
loans for people with bad credit https://maybeloan.com/bad-credit-loans
Brian Gimbli wrote: Thu Dec 31, 2020 2:18 pm I've been using XnConvert for a couple years on my PC, and when it will available on iPhone?
Currently not planned for iOS
Amoli
Post by Amoli »
I love this app, had to add some suggestions/requests to the to-do list.
Why it's great:
- webp support - better quality than jpg, or smaller size
- 1-tap batch convert via Share
What's less great: 8)
- no way to change the output folder (Android 11+ restrictions? No problem with older OS)
- user interface idiosyncrasies (see link above)
Btw, why is there no bicubic resize option? Or other resize algorithms from the likes of Avisynth, other than lanczos & bilinear?
maxwell56
Post by maxwell56 »
Thanks for this great app. Batch conversion resp. convert in batch mode doesn't work with orf raw files. Batch conversion works well with conventional bitmaps, e.g. jpeg in png. In the case of choosing raw files and a following conversion into jpeg the media directiory stays empty. I'm using XnConvert on a Chromebook under Android.
maxwell56 wrote: Thu Mar 30, 2023 5:49 pm Thanks for this great app. Batch conversion resp. convert in batch mode doesn't work with orf raw files. Batch conversion works well with conventional bitmaps, e.g. jpeg in png. In the case of choosing raw files and a following conversion into jpeg the media directiory stays empty. I'm using XnConvert on a Chromebook under Android.
ok i'll check. Currently i work on the new version with more actions tools
maxwell56
Post by maxwell56 »
Canon cr2 raw (size 64 MB) file conversion results in a crash of XnConvert under Android 9.0 (Chromebook with ARM 64 prosessor).
