Very nasty bug with Right-Click + Copy/Move
Moderator: Dreamer
m.Th.
Post by m.Th. » Wed May 08, 2019 9:59 am
Steps:
0. Have the following structure: Folder1 with images in it and some subfolders SF1, SF2, etc. (tested on the network; I think that the same bug appears locally)
1. Select some images from Folder1
2. Right click on (one of) the selected images and choose "Cut" (or Copy)
3. Right click on one of the subfolders - let's say on SF2. From the right-click menu choose "Paste"
Expected:
The selected images from step 2 should go in SF2.
Actual:
The selected images go (again) into Folder1 and if the user chooses "Cut" as operation and "Replace (All)" as option for the dialog which appear, then all the images are lost.
The right-click is very misleading and can generate data loss. Please fix this!
m. Th.
The Ascetic Experience - The best photos and texts from Holy Mountain (Athos)
- Dark Themed XnViewMP 0.90 64bit & XnView 2.00 x64 on Win7 x64 -
Re: Very nasty bug with Right-Click + Copy/Move
Post by xnview » Thu May 23, 2019 8:41 am
you can change
pasteIntoSubfolder=true
Moderator & Librarian
Post by XnTriq » Thu May 23, 2019 9:45 am
m.Th.
Post by m.Th. » Fri May 24, 2019 1:24 pm
you can change
Why this isn't set to 'true' by default ?
m. Th.
