file in use?
Moderators: XnTriq, xnview
FlyAway
file in use?
Post by FlyAway » Mon Apr 29, 2019 1:33 pm
Hi :)
In thumbnails view, with some video, when I click canc on my keyboard, Xnview MP tell me that the file is in use and it can't delete it. Can you help me?
edit
the same when I open the video with the integrated player :(
Re: file in use?
Post by xnview » Wed May 01, 2019 7:19 am
"some video" you have not always the problem?
FlyAway
Re: file in use?
Post by FlyAway » Wed May 01, 2019 9:32 am
not always, I think it may depend on the file size. As if Xnview is trying to process it and then it cannot be deleted.
FlyAway
Re: file in use?
Post by FlyAway » Wed May 01, 2019 4:36 pm
same problem if I want drag and drop a video to another folder :(
Re: file in use?
Post by xnview » Mon May 06, 2019 8:49 am
with 0.93.1?
FlyAway
Re: file in use?
Post by FlyAway » Mon May 06, 2019 11:28 am
yes Version 0.93.1 64bits (Mar 6 2019)
Re: file in use?
Post by xnview » Mon May 06, 2019 11:54 am
I can't reproduce, which format?
FlyAway
Re: file in use?
Post by FlyAway » Thu May 09, 2019 10:53 am
.avi and .mp4
If you want I can send you the program, I use the portable edition. I have test it in another PC and the problem is the same :(
Re: file in use?
Post by xnview » Fri May 10, 2019 5:59 am
Windows 10?
FlyAway
Re: file in use?
Post by FlyAway » Sat May 11, 2019 7:49 am
yes, 64
FlyAway
Re: file in use?
Post by FlyAway » Mon May 13, 2019 9:03 am
this is a screenshot of error
Rick
Re: file in use?
Post by Rick » Sun May 19, 2019 4:28 pm
XnView has been good at releasing files
If you have the preview p[em and the video is in it the file stays locked. C Licking n something else will release the file. If it stays locked and this is a continuing problem, install lock hunter or unlocker which will unlock the file when you need it
Rick
FlyAway
Re: file in use?
Post by FlyAway » Sun May 19, 2019 10:01 pm
thank you but it doesn't seem like a big help :mrgreen:
