XnView MP, still has a lot of work and Bugs to fix, if this is true it is not worth canceling this option for something new. Preferably I get the old version that has fewer failures.
Only the preview? Do you have installed the XnShell package?AngelP wrote: Fri Apr 26, 2019 1:40 am Hi, when I uninstall the previous XnView Full, and then install the XnView MP, the Preview of the Images in the XnView Shell is lost, this is because this new version of the XnView MP is not compatible with the XnShell, even if I install everything in 64 bit systems. To return to work I must reinstall the Full Classic XnView, now in version 2.48![]()
why "still has a lot of work"?XnView MP, still has a lot of work and Bugs to fix, if this is true it is not worth canceling this option for something new. Preferably I get the old version that has fewer failures.![]()
Ok, I explain better and forgive my English!xnview wrote: Fri Apr 26, 2019 6:02 amOnly the preview? Do you have installed the XnShell package?AngelP wrote: Fri Apr 26, 2019 1:40 am Hi, when I uninstall the previous XnView Full, and then install the XnView MP, the Preview of the Images in the XnView Shell is lost, this is because this new version of the XnView MP is not compatible with the XnShell, even if I install everything in 64 bit systems. To return to work I must reinstall the Full Classic XnView, now in version 2.48![]()
Ok, the XnView classic package contains XnShell Extension 32bits, XnView MP doen't have it, you need to install the XnShell Extension package...
