NConvert bug -multi option
Moderators: XnTriq, xnview
Post by cday » Sat Apr 13, 2019 7:17 pm
A regression seems to have been introduced for the -multi option somewhere between NConvert 6.51 and 7.25.
The following code works as expected with the attached test PNGs:
But the following code produces a malformed multipage file using the same PNGs:
Malformed multipage files also seem to be produced for some other file extensions, possibly dependent on the compression method used which complicates investigation, hopefully due to the same regression.
Test files.zip
(2 MiB) Downloaded 17 times
Re: NConvert bug -multi option
Post by xnview » Mon Apr 15, 2019 3:12 pm
known issue (same problem affect XnView 2.47)
