0.93.1 Wrong file moved
Bugs which have been reproduced by a second user or the developer
Moderator: Dreamer
jadO
Post by jadO » Sun Mar 31, 2019 6:58 am
When dragging a file into another folder the wrong file gets moved, when a file gets added while the mouse button is pressed.
1. Switch to a folder with files
2. Select a file to drag
3. Hold mouse button pressed
4. Add a file to this folder
5. Drag selected file to new folder
As I have selected and keep selected the same file during the operation this file should be moved. But the new added file gets moved. It seems that a check is missing that another file is the selected one for move not the new one.
Re: 0.93.1 Wrong file moved
Post by xnview » Wed Aug 28, 2019 9:28 am
a file is added to same folder during drag?
jadO
Post by jadO » Wed Aug 28, 2019 2:41 pm
While the mouse button keeps being pressed, yes.
Post by xnview » Mon Sep 02, 2019 5:13 pm
how do you add a file during drag&drop?
jadO
Post by jadO » Fri Sep 06, 2019 12:33 pm
Via script or 3rd party application.
Post by xnview » Wed Sep 25, 2019 7:44 am
