Protecting the Alpha version
Moderators: XnTriq, xnview
Dreamer
Post by Dreamer » Sun Nov 06, 2005 11:24 pm
helmut wrote:
Dreamer wrote:Right, so I think we should use a warning dialog (and password protected zip).
We agree regarding the password protected ZIP, but I'm not so sure with the dialog. As tester, I don't want to see this dialog at start-up all the time. So there should be a way to disable the dialog.
I think for now, we should go for the password protected ZIP. If this does not help, we still could do more about this.
Please check this post again.
It means:
= almost no extra work for anyone (Pierre...)
= ability to disable warning dialog
In final release we could replace it with standard tip.ini file.
Post by helmut » Tue Nov 08, 2005 10:48 pm
Dreamer wrote:...
It means:
When thinking about it more I think that using the Tip dialog is a good idea. Let's see whether Pierre agrees, I'll point him to this topic.
BTW:
Currently Google returns about 56.000 hits for "XnView 1.82", compared to 0 hits some days ago.
Post by xnview » Wed Nov 09, 2005 9:40 am
helmut wrote:
Dreamer wrote:...
It means:
Current Tip use or a new dialog?
marsh
Text in titlebar?
Post by marsh » Wed Nov 09, 2005 1:05 pm
Text in 'title bar' is another alternative.
Names could have more description when appropriate.
v.1.80 alpha (unstable)
v.1.80 alpha (for discussion only)
v.1.80 beta (unstable)
Re: Text in titlebar?
Post by helmut » Wed Nov 09, 2005 7:09 pm
marsh wrote:Text in 'title bar' is another alternative.
Good idea. I'd prefer the title bar to the dialog box, since this does not affect usage.
Regardless which solution is choosen, best is if Pierre wouldn't need to change any code / file before releasing the final version. For this reason using "tips.ini" is out of question.
VuDu
Post by VuDu » Thu Nov 10, 2005 3:13 pm
I agree with the 'title bar' alternative, with that I think the "tool tip" warning would no longer be necessary.
Well, another thing, I think that releasing the zip file with a version description instead of the regular "xnview-alpha.zip".
For example: "xnview-1.82-alpha-01nov.zip", besides "spreading" the alpha/unstable word, it'd help ppl to know wich alpha version are on those portals, etc...
what do you think?
Ad decus et ad libertatem nati sumus
Aut haec teneamus aut cum dignitate moriamur
Dreamer
Post by Dreamer » Fri Nov 11, 2005 1:12 am
|VooDoo| wrote:For example: "xnview-1.82-alpha-01nov.zip", besides "spreading" the alpha/unstable word, it'd help ppl to know wich alpha version are on those portals, etc...
what do you think?
But it's in the same folder...
Post by helmut » Fri Nov 11, 2005 7:27 am
|VooDoo| wrote:I agree with the 'title bar' alternative, with that I think the "tool tip" warning would no longer be necessary.
what do you think?
Another good idea. For the Alphas and betas we really could use the version in the filename. I think we have enough good ideas and suggestions, and it's Pierre's turn, now.
ckit
Post by ckit » Sat Nov 26, 2005 3:04 am
I think it would be better to use RAR or 7-Zip for non-Final releases as the compression ratio and security is better. This will also stop other Download Portals as most of them prefer ZIPs.
Also, distro the non-Final releases as torrents! You'll need some admins or mods that have ADSL or DSL so their upstream data isn't counted towards their bandwidth like me. I have ADSL2+ now and use Azureus 2.3.0.4 :)
Windows 10 Pro x64 1909
XnViewMP and Classic and PhotoFiltre Studio X
Drahken
Post by Drahken » Wed Dec 07, 2005 6:49 pm
The titlebar option is the best, if the application states right in the title bar "alpha (unstable)" or "alpha (testing purposes only)" or some such, and someone whines that it's buggy (note: I'm talking about the "this thing's a piece of crap, screw you" type complaints, not the "I have located a problem, here it is ...." bug reports), we can just label him as a moron and move on.
Repacking (ie using rar or 7zip or whatever), password protecting the zip, or renaming the file will slow down portal sites, but it won't prevent people from unknowingly getting an unstable release. The portals can very easily rename and/or repack the file and pass it off as a stable release.
Popups/tips are always very annoying, mostly useless ("tip: you can open a file by clicking the 'open' button!" No sh~ sherlock!), and almost universally ignored. If you put some sort of popup saying that it's an unstable version, people will just see the popup and say "oh shut up!" and close it without even reading it.
Post by helmut » Thu Dec 08, 2005 7:16 pm
Good to see the "v1.82 beta 1 (unstable)" in the title bar of the 1.82 Beta 1. :-)
Dreamer
Post by Dreamer » Mon Feb 20, 2006 4:53 pm
helmut wrote:Good to see the "v1.82 beta 1 (unstable)" in the title bar of the 1.82 Beta 1. :-)
So is it enough? Close?
Post by helmut » Mon Feb 20, 2006 8:21 pm
I think the hint in the title bar worked very well and is enough.
Locked
