XnView: MP 0.93.1 - 64 bit
OS: Windows 10 - 64bit
When you activate the random quick slideshow feature in a folder with more than 32,000 files and watch the overlay "xyz/40000" over a long period of time, it is noticeable that all random picks occur below ~33,000. From coding experience, I would believe the actual value is 32767 from the minimal default RAND_MAX implementation.
Effect: You cannot create a random slideshow with more than ~32,000 pictures because the population space is limited and thus the images are not selected at random.
1. Copy or generate more than 40,000 images in a folder
2. Settings > View > Quick slideshow: Delay: 50ms and Direction Random
3. Start slideshow
4. Closely watch the counter in the top left
Actual behaviour (bug): Counter never goes above 33,000
Expected behaviour: Counter picks each image equally likely, even if the user is insane enough to have such an amount of images.
0.93.1: Random slideshow shows at most ~32,000 images
Moderator: Dreamer
Re: 0.93.1: Random slideshow shows at most ~32,000 images
This problem is supposed to be fixed in XnView MP 0.94. Please check and confirm the bug fix here.
