Option to disable XnView from starting up whenever we view an image in fullscreen mode
Moderators: XnTriq, xnview
Stanfoo
Post by Stanfoo » Thu Mar 14, 2019 2:49 am
Whenever you open an image to be viewed in fullscreen mode, after pressing ESC to exit, XnView program is automatically opened and shows that same image. I find that intrusive, it would be nice to have an option to disable XnView from automatically opening whenever we view an image in fullscreen mode. I used FastStone Image Viewer before switching to XnView and that image viewer did not have this problem, so I would think you'd be able to implement this.
Re: Option to disable XnView from starting up whenever we view an image in fullscreen mode
Post by xnview » Thu Mar 14, 2019 11:44 am
you means that browser comes after pressing ESC on fullscreen image?
Stanfoo
Post by Stanfoo » Fri Mar 15, 2019 2:17 am
No. Browser comes immediately after opening an image on fullscreen mode. But you don't notice the browser until after you exit fullscreen mode.
Post by cday » Fri Mar 15, 2019 7:47 pm
Option to 'Close XnView when exit fullscreen' ?
Stanfoo
Post by Stanfoo » Sat Mar 16, 2019 2:19 am
That could work, but it would have to close at the same time when exiting fullscreen. If you still see the browser for a split second after exiting fullscreen, then there wouldn't be much point, as I don't want to see the browser at all. Ideally I'd prefer XnView to just not start up at all.
Post by xnview » Mon Mar 18, 2019 11:47 am
do you have 'open browser' unchecked?
Stanfoo
Post by Stanfoo » Tue Mar 19, 2019 10:52 am
yes
foxyshadis
Post by foxyshadis » Mon Apr 15, 2019 5:39 am
This has worked for me for years. Under Interface->Keyboard there's a "Pressing ESC once quits XnViewMP" option, do you have that set to Never? Either of the other options should do it.
