Saving the selected tab in the "Edit IPTC"
Moderators: cday, XnTriq, helmut, xnview, Dreamer
SergSA
Post by SergSA » Tue Mar 12, 2019 8:43 am
I propose to make it so that when you open the "Edit IPTC", it is not the "Caption" tab that is active, but the one that was opened last time.
I work only with the "Keywords" tab and every time I edit I have to switch the tab.
Re: Saving the selected tab in the "Edit IPTC"
Post by michel038 » Tue Mar 12, 2019 12:42 pm
+1
I use the "IPTC / XMP Edition" window only to add "city".
To improve speed, it would be useful when opening this window to point to the last used tab ("source")
Or add the ability to create a new button in the toolbar, which points directly to edit iptc/xmp>source>city
viewtopic.php?f=60&t=37541&p=150313
Post by xnview » Thu Aug 22, 2019 1:07 pm
Post by xnview » Tue Sep 17, 2019 10:18 am
This problem is supposed to be fixed in XnView MP 0.94. Please check and confirm the bug fix here.
Post by michel038 » Tue Sep 17, 2019 9:18 pm
Ok in V0.94 B1
New checkbox in "Options" tab .
Thanks
Parfait !
CameronD
Post by CameronD » Sat Sep 21, 2019 2:22 am
Works well.
A minor change to the English wording ...
should say "Open last opened tab"
Alternatively, the following might be slightly clearer:
"Reopen at last opened tab"
