XnView MP 0.93.1
XnView MP 0.93.1
Please, don't post bugs or request in this topic!
You can download XnView MP 0.93.1 here:
Windows x32 ZIP version: http://download.xnview.com/XnViewMP-win.zip
Windows x32 SETUP version: http://download.xnview.com/XnViewMP-win.exe
  • SHA256: FD35790BFA4B9EB254904763098C5D6CABBAA37CE987725CF2E6278826B2C965
Windows x64 ZIP version: http://download.xnview.com/XnViewMP-win-x64.zip
Windows x64 SETUP version: http://download.xnview.com/XnViewMP-win-x64.exe
  • SHA256: 0970D8F0CDD66B49E925E278DFFE7DBA4D48D6FA62FA0BD1D929088FF9B030DC
For Windows 7 and older, you have to install the driver from DirectX to run correctly QtAV (audio/video)
Mac x64 TGZ version: http://download.xnview.com/XnViewMP-mac.tgz
Mac x64 DMG version: http://download.xnview.com/XnViewMP-mac.dmg
Linux TGZ version: http://download.xnview.com/XnViewMP-linux.tgz
Linux DEB version: http://download.xnview.com/XnViewMP-linux.deb
Linux x64 TGZ version: http://download.xnview.com/XnViewMP-linux-x64.tgz
Linux x64 DEB version: http://download.xnview.com/XnViewMP-linux-x64.deb
ARM version: http://download.xnview.com/XnViewMP-linux-arm.tgz http://download.xnview.com/XnViewMP-lin ... _armhf.deb
Linux x64 AppImages version: http://download.xnview.com/XnView_MP-0. ... 4.AppImage
Linux Flatpak version: https://flathub.org/apps/details/com.xnview.XnViewMP
Changelog 0.93.1:
1567: [Bug] Print only first page - https://newsgroup.xnview.com/viewtopic.php?t=38651
1566: [Bug] HEIC on Mac
1565: [Bug] Stars on preview don't change rating
1564: [Bug] Error reading TGA 16bits RLE
1563: [Bug] Exit Artist shown on NEF file
1562: [Bug] Prev/Next not working with two or more opened tabs - https://newsgroup.xnview.com/viewtopic.php?t=38523
1561: [Bug] Problem to move video files - https://newsgroup.xnview.com/viewtopic.php?t=38488
1560: [Bug] Fullscreen view mode - Focus on image lost after edit - https://newsgroup.xnview.com/viewtopic.php?t=38490
1559: [Bug] Contact Sheet: Folder not restored - https://newsgroup.xnview.com/viewtopic.php?t=38570
1558]: [Bug] SPACE key settings - https://newsgroup.xnview.com/viewtopic.php?t=38478
1557: [Bug] WebP 32bits & metadata - https://newsgroup.xnview.com/viewtopic.php?t=38514
1556: [Bug] XCF (floating pixel) crash
1531: [Bug] Linux move to trash - https://newsgroup.xnview.com/viewtopic.php?t=37989
1555: [Bug] Windows Save dialog, Most used formats no more at top
Changelog 0.93:
1507: [New] Space key for next picture
1506: [New] 'Add selection to Favorites' - http://newsgroup.xnview.com/viewtopic.php?t=37666
1505: [New] After 'save as', use output filename setting
1504: [New] Format option button in save dialog (Windows only)
1500: [New] SHIFT/CTRL to constraint drawing line horizontally/vertically
1543: [New] ScrollbarValue setting - http://newsgroup.xnview.com/viewtopic.php?t=33419
1540: [New] Selection grid setting - http://newsgroup.xnview.com/viewtopic.php?t=38270
1539: [New] [General/scanDone] to close or not TWAIN dialog after scan
1534: [New] Import&Sort: Video subfolder - http://newsgroup.xnview.com/viewtopic.php?t=37976
0076: [New] Batch Processing running on multiple cores - http://newsgroup.xnview.com/viewtopic.php?t=24355
1524: [New] WEBP EXIF/XMP support
1523: [New] OpenJPEG updated
1522: [New] WEBP updated
1516: [New] Settings to choose color label - http://newsgroup.xnview.com/viewtopic.php?t=38191
1515: [New] Ratio always > 0, settings added - http://newsgroup.xnview.com/viewtopic.php?t=38107
1514: [New] -clipaste
1553: [Bug] IPTC dialog: Crash 'insert from' in Edit mode
1552: [Bug] Capture (rectangle) with hotkey returns desktop
1551: [Bug] Batch convert: Description not used in 'Add Text'
1550: [Bug] Slideshow: Audio file not loaded from .sld - http://newsgroup.xnview.com/viewtopic.php?t=38427
1549: [Bug] Import&Sort: Image with no EXIF date are not imported
1548: [Bug] Batch Convert: 'Keep structure' & 'Keep parent' can't convert on same root partition
1547: [Bug] Resize presets not correctly saved/restored - http://newsgroup.xnview.com/viewtopic.php?t=38351
1546: [Bug] Crash when renaming folder in folder tree - http://newsgroup.xnview.com/viewtopic.php?t=38380
1545: [Bug] Batch convert: Delete icon not enabled after saving script
1544: [Bug] Batch convert: Small/Large thumbnails setting not restored
1542: [Bug] XnConvert: 'Delete original' setting not saved - http://newsgroup.xnview.com/viewtopic.php?t=38355
1541: [Bug] ICNS with JPEG2000 icon - http://newsgroup.xnview.com/viewtopic.php?t=38363
1538: [Bug] Seek video by clicking on time slider bar - http://newsgroup.xnview.com/viewtopic.php?t=35144
1537: [Bug] XCF 2.10
1536: [Bug] Curves: Area to move control point too small - http://newsgroup.xnview.com/viewtopic.php?t=38336
1535: [Bug] key navigation disabled after crop - http://newsgroup.xnview.com/viewtopic.php?t=38294
1533: [Bug] Paint: Text not saved - http://newsgroup.xnview.com/viewtopic.php?t=37691
1532: [Bug] Contact Sheet: no top margin - http://newsgroup.xnview.com/viewtopic.php?t=37617
0756: [Bug] Print custom size - http://newsgroup.xnview.com/viewtopic.php?t=32327
1531: [Bug] Linux move to trash - http://newsgroup.xnview.com/viewtopic.php?t=37989
1530: [Bug] Freeze when creating thumbnail for small video files - http://newsgroup.xnview.com/viewtopic.php?t=38045
1529: [Bug] DPX 8bits load/save - http://newsgroup.xnview.com/viewtopic.php?t=38159
1528: [Bug] Language mix in dialogs - http://newsgroup.xnview.com/viewtopic.php?t=38096
1527: [Bug] Batch Convert Drag&Drop does not work when listview is enabled - http://newsgroup.xnview.com/viewtopic.php?t=38266
1526: [Bug] Open a PDF can show an error - http://newsgroup.xnview.com/viewtopic.php?t=38249
1525: [Bug] Can't drag in browser mode if there are marked files - http://newsgroup.xnview.com/viewtopic.php?t=38227
1521: [Bug] XCF dead lock
1520: [Bug] Context menu must not be shown on folder in favorite
1519: [Bug] Dead lock on mpa/m4a files - http://newsgroup.xnview.com/viewtopic.php?t=38224
1517: [Bug] Problem with icons generation, settings added (was causing some crash on older QT)
1513: [Bug] Problems when searching with 'base path'
1512: [Bug] MacOSX: UI problem with video files
1511: [Bug] IPTC keywords sorted in details view - http://newsgroup.xnview.com/viewtopic.php?t=38011
1510: [Bug] .lnk can't be viewed - http://newsgroup.xnview.com/viewtopic.php?t=37995
1509: [Bug] Batch Rename: same name but different extension - http://newsgroup.xnview.com/viewtopic.php?t=38020
1508: [Bug] Arrow keys not working in list view
1503: [Bug] Slideshow: use transition not checked after loading .sld
1502: [Bug] Batch convert: Clear input file don't work anymore
1501: [Bug] Slideshow crash
1499: [Bug] Searching by Image Width and Image Height Returns 0 Results - http://newsgroup.xnview.com/viewtopic.php?t=38100
1498: [Bug] Batch Convert: 'Source folder' not selected after load .xbs - http://newsgroup.xnview.com/viewtopic.php?t=38057
1491: [Bug] Load & save image with ICC profile doesn't change icc (sRGB) - http://newsgroup.xnview.com/viewtopic.php?t=37755
1497: [Bug] Bad decoding of embedded comment
1496: [Bug] Crash when renaming Favorites
Changelog 0.92:
1495: [Bug] Open problem - https://newsgroup.xnview.com/viewtopic.php?f=62&t=37920
1495: [Bug] Switch mode - https://newsgroup.xnview.com/viewtopic.php?f=62&t=37916
Changelog 0.91:
1487: [New] PDF v1.4 output
1486: [New] Sqlite 2.24.0
1482: [New] Audio with slideshow - https://newsgroup.xnview.com/viewtopic.php?f=60&t=37463
1387: [New] Ratio field - https://newsgroup.xnview.com/viewtopic.php?f=60&t=37204
1384: [New] Batch convert: Back color added to convert 32bits into 24bits - https://newsgroup.xnview.com/viewtopic. ... 10&t=37147
1391: [New] Autocomplete in copy/move dialog - https://newsgroup.xnview.com/viewtopic. ... 10&t=37257
1478: [New] Join: Fit width or height
1475: [New] Batch resize by width or height - https://newsgroup.xnview.com/viewtopic.php?f=60&t=36864
1471: [New] PackJPG format (read)
1470: [New] Lepton format (read) added
1467: [New] Companion files handling - https://newsgroup.xnview.com/viewtopic.php?f=95&t=35508
1465: [New] HPI alpha channel supported
1464: [New] Custom title bar in browse mode - https://newsgroup.xnview.com/viewtopic.php?f=82&t=37446
1457: [New] Change timestamp: Increment at each file - https://newsgroup.xnview.com/viewtopic.php?f=82&t=37416
1456: [New] Edit colormap - https://newsgroup.xnview.com/viewtopic.php?f=95&t=37217
1452: [New] QtAV used on Linux/Mac for video playing/thumbnailing
1454: [New] Message before to quit - https://newsgroup.xnview.com/viewtopic.php?f=82&t=37380
1447: [New] More options for RAW
1439: [New] KRITA support - https://newsgroup.xnview.com/viewtopic.php?f=60&t=33385
1433: [New] 'Use Alpha channel' not remembered - https://newsgroup.xnview.com/viewtopic.php?f=95&t=34644
1432: [New] Search: Select pathname field - https://newsgroup.xnview.com/viewtopic.php?f=95&t=37086
1441: [New] Tooltips when drawing selection - https://newsgroup.xnview.com/viewtopic.php?f=60&t=37259
1427: [New] Recent quick search list - https://newsgroup.xnview.com/viewtopic.php?f=95&t=37201
1425: [New] Resize dialog - https://newsgroup.xnview.com/viewtopic.php?f=95&t=36772
1409: [New] Relative path in .sld - https://newsgroup.xnview.com/viewtopic.php?f=62&t=37181
1406: [New] Information for Audio/Video file - https://newsgroup.xnview.com/viewtopic.php?f=95&t=35843
1405: [New] Sharpen in Resize dialog
1404: [New] Autoskew in edit mode
1400: [New] IPTC dialog in view mode - https://newsgroup.xnview.com/viewtopic.php?f=60&t=34630
1399: [New] Setting to create descript.ion in UTF8
1493: [Bug] ICC support in compare - https://newsgroup.xnview.com/viewtopic.php?f=62&t=37808
1492: [Bug] JPEG2000 YCC - https://newsgroup.xnview.com/viewtopic.php?f=35&t=37806
1491: [Bug] Load & save image with ICC profile doesn't change icc (sRGB) - https://newsgroup.xnview.com/viewtopic.php?f=62&t=37755
1490: [Bug] 'Crop, save & next' doesn't always save cropped image - https://newsgroup.xnview.com/viewtopic.php?f=82&t=37730
1489: [Bug] Batch convert- automatic crop - https://newsgroup.xnview.com/viewtopic.php?f=79&t=37782
1488: [Bug] When catalog is not used, can't save search
1485: [Bug] Save 32bits as jpeg - https://newsgroup.xnview.com/viewtopic.php?f=62&t=37638
1484: [Bug] Crash with 1x1 png - Thanks to Martin Orem of Binary House
1483: [Bug] TIFF with JPEG compression - https://newsgroup.xnview.com/viewtopic.php?f=35&t=37585
1481: [Bug] IPTC Edit: Object name not always modified on RAW - https://newsgroup.xnview.com/viewtopic.php?f=83&t=37441
1480: [Bug] Deselecting by CTRL key - https://newsgroup.xnview.com/viewtopic.php?f=62&t=37486
1479: [Bug] Batch convert: Problem when filename has $ character
1477: [Bug] Embedded comment always written in utf8 - https://newsgroup.xnview.com/viewtopic.php?f=62&t=37497
1476: [Bug] Batch convert: if 'delete original', steals focus - https://newsgroup.xnview.com/viewtopic.php?f=79&t=37328
1474: [Bug] Batch Rename: First item no more selected - https://newsgroup.xnview.com/viewtopic.php?f=62&t=37297
1473: [Bug] Dialog Edit curves: curve not visible if preview enabled - https://newsgroup.xnview.com/viewtopic.php?f=62&t=37487
1472: [Bug] Crop unavailable until change crop area manually - https://newsgroup.xnview.com/viewtopic.php?f=82&t=37461
1469: [Bug] Export: wepb quality widget too small - https://newsgroup.xnview.com/viewtopic.php?f=62&t=37482
1468: [Bug] Slow when entering on a folder with a lot of files (icon create)
1466: [Bug] Characters problem with exif label in view informations - https://newsgroup.xnview.com/viewtopic.php?f=83&t=37459
1463: [Bug] Edit IPTC: no hierarchicalSubject written for RAW - https://newsgroup.xnview.com/viewtopic.php?f=83&t=37441
1462: [Bug] Edit IPTC: EXIF:artist modified on RAW file - https://newsgroup.xnview.com/viewtopic.php?f=83&t=37441
1461: [Bug] Long full path on windows 10 - https://newsgroup.xnview.com/viewtopic.php?f=95&t=36108
1460: [Bug] Batch Convert: Hot folder, files not completly written, can't be readed - https://newsgroup.xnview.com/viewtopic.php?f=79&t=3743
1459: [Bug] Error reading panorama image from S9 - https://newsgroup.xnview.com/viewtopic.php?f=62&t=37427
1458: [Bug] Rounded value in batch resize - https://newsgroup.xnview.com/viewtopic.php?f=36&t=37451
1455: [Bug] Filesize in Info not changed after save - https://newsgroup.xnview.com/viewtopic.php?f=62&t=37319
1453: [Bug] Video thumbnail not correctly build by QtAv
1451: [Bug] Open image tab while in fullscreen on second monitor - https://newsgroup.xnview.com/viewtopic.php?f=62&t=35028
1450: [Bug] PDF output on Linux - https://newsgroup.xnview.com/viewtopic.php?f=82&t=37376
1449: [Bug] Batch convert: Preview 'after' not always loaded - https://newsgroup.xnview.com/viewtopic.php?f=62&t=37377
1448: [Bug] All details on info pane are missing while Fullscreen preview is active - https://newsgroup.xnview.com/viewtopic.php?f=95&t=3658
1446: [Bug] Join: Collage on non image files
1445: [Bug] Batch Convert: ESC before end of process
1444: [Bug] Grid settings are not saved - https://newsgroup.xnview.com/viewtopic.php?f=62&t=37363
1443: [Bug] When selecting file without thumbnail, should create this one first - https://newsgroup.xnview.com/viewtopic.php?f=95&t=36704
1442: [Bug] Folders in folder tree are expanded - https://newsgroup.xnview.com/viewtopic.php?f=62&t=36808
1440: [Bug] Webm support
1438: [Bug] Excluding folders in Catalog & copy files - https://newsgroup.xnview.com/viewtopic.php?f=95&t=36635
1437: [Bug] Batch Convert: Hot folders & subdirectories - https://newsgroup.xnview.com/viewtopic.php?f=82&t=37338
1436: [Bug] Included/excluded folder list - double entries possible - https://newsgroup.xnview.com/viewtopic.php?f=62&t=37345
1435: [Bug] Slideshow order is not being restored on opening an .sld - https://newsgroup.xnview.com/viewtopic.php?f=62&t=37360
1434: [Bug] Thumbnail and Image Orientation out of sync after Jpeg Lossless Rotate - https://newsgroup.xnview.com/viewtopic.php?f=95&t=36687
1431: [Bug] Compare: thumbnails view size - https://newsgroup.xnview.com/viewtopic.php?f=95&t=36954
1430: [Bug] EXIF Image width/height is not updated - https://newsgroup.xnview.com/viewtopic.php?f=95&t=36625
1429: [Bug] Move shortcut of file - https://newsgroup.xnview.com/viewtopic.php?f=95&t=36971
1428: [Bug] Name collision dialog uses old name on renaming - https://newsgroup.xnview.com/viewtopic.php?f=95&t=37084
1426: [Bug] Ctrl+Right Click does not select the image - https://newsgroup.xnview.com/viewtopic.php?f=95&t=36951
1424: [Bug] Wheel on preview change focus - https://newsgroup.xnview.com/viewtopic.php?f=95&t=36767
1423: [Bug] Ctrl+Right Click unselects the image in detail view - https://newsgroup.xnview.com/viewtopic.php?f=95&t=36950
1422: [Bug] Selection must be restored after undo - https://newsgroup.xnview.com/viewtopic.php?f=95&t=37102
1421: [Bug] Rating/Label on folder always cleared - https://newsgroup.xnview.com/viewtopic.php?f=95&t=37269
1420: [Bug] Selection with the keyboard controls is inconsistent - https://newsgroup.xnview.com/viewtopic.php?f=95&t=34297
1419: [Bug] Duplicate video playback - https://newsgroup.xnview.com/viewtopic.php?f=95&t=35953
1418: [Bug] Not responsive while opening image file - https://newsgroup.xnview.com/viewtopic.php?f=95&t=35057
1417: [Bug] Wrong focus after returning from image tab - https://newsgroup.xnview.com/viewtopic.php?f=95&t=35964
1416: [Bug] Image navigation pane shown on animated GIF - https://newsgroup.xnview.com/viewtopic.php?f=95&t=36012
1415: [Bug] MacOSX: copy instead of move on same partition - https://newsgroup.xnview.com/viewtopic.php?f=95&t=35754
1414: [Bug] Fixed ratio for selection and horizontal handler - https://newsgroup.xnview.com/viewtopic.php?f=95&t=36457
1413: [Bug] PDF when viewing are not skipped if ghosctscript is not installed - https://newsgroup.xnview.com/viewtopic.php?f=95&t=35338
1412: [Bug] Batch Convert: Delete original always use recycle bin - https://newsgroup.xnview.com/viewtopic.php?f=95&t=37132
1411: [Bug] Thumbnail ratio - https://newsgroup.xnview.com/viewtopic.php?f=95&t=33725
1410: [Bug] Batch Rename not possible on Movie - https://newsgroup.xnview.com/viewtopic.php?f=95&t=35923
1401: [Bug] Modified date for OpenXML format changed when creating thumbnail - https://newsgroup.xnview.com/viewtopic.php?f=62&t=37344
1408: [Bug] Keys in slideshow - https://newsgroup.xnview.com/viewtopic.php?f=62&t=37181
1407: [Bug] Favorites not sorted after adding one - https://newsgroup.xnview.com/viewtopic.php?f=95&t=37092
1403: [Bug] Batch Rename: 'always added' not saved - https://newsgroup.xnview.com/viewtopic.php?f=60&t=37332
1402: [Bug] Wrong thumbnail from catalog - https://newsgroup.xnview.com/viewtopic.php?f=82&t=33548
1398: [Bug] Slow search on annotations - https://newsgroup.xnview.com/viewtopic.php?f=82&t=37295
1397: [Bug] Annotation doesn't work, in slideshow - https://newsgroup.xnview.com/viewtopic.php?f=82&t=37300
1396: [Bug] Freeze when clicking on .url - https://newsgroup.xnview.com/viewtopic.php?f=62&t=37289
1395: [Bug] Windows default context menu use only 1 file - https://newsgroup.xnview.com/viewtopic.php?f=82&t=37287
1394: [Bug] Export resize for NConvert - https://newsgroup.xnview.com/viewtopic.php?f=79&t=37278
1393: [Bug] Thumbnail process on big files can't be interrupted - https://newsgroup.xnview.com/viewtopic. ... 10&t=37182
1390: [Bug] Cancel 'Edit Favorites path' - https://newsgroup.xnview.com/viewtopic.php?f=62&t=37100
1389: [Bug] Print: Incorrect caption in picture collection - https://newsgroup.xnview.com/viewtopic.php?f=62&t=37274
1388: [Bug] Directory locked after batch convert - https://newsgroup.xnview.com/viewtopic.php?f=62&t=37242
1386: [Bug] Batch convert: keep folder and folder at root path
1385: [Bug] Paint: b&w, 8bits colormap are converted with bad colors
1383: [Bug] Batch convert: ICC convert doesn't work on 64bits version - https://newsgroup.xnview.com/viewtopic.php?f=79&t=37176
1382: [Bug] Batch convert: extension is not changed - https://newsgroup.xnview.com/viewtopic.php?f=79&t=37165
1381: [Bug] Image with alpha channel converted in JPEG - https://newsgroup.xnview.com/viewtopic.php?f=82&t=37147
Schattenjager
Re: XnView MP 0.93.1
Post by Schattenjager »
Pierre, thank you very much!
XnView MP finally supports Ubuntu system theme without any additional actions)
dietmar
Post by dietmar »
Pierre,
with Linux x64 v93.0 installed, version 0.93.1 is not offered as an available update during automatic or manual update check. MP claims that the system is up-to-date, which it isn't.
Regards
Dietmar
dietmar wrote: Tue Mar 12, 2019 4:05 pm Pierre,
right
SenpaiEd
Post by SenpaiEd »
Hi!
What about arm version update?
Still the same link on the page to http://download.xnview.com/XnViewMP-lin ... _armhf.deb
