The website is reporting 2.47.
The program is saying 2.48.
Is one right?
XnView 2.47 or 2.48?
Regards, PhredE
Willing donor, if only a 'donor token' were supplied in return, putting 'Phred's XnView' or '$D', '$Dd', '$dd' (depending on size) or 'Donor Version' in the title bar. (See Wiztree for partial solution.)
And a local Help file
Re: XnView 2.47 or 2.48?
Many thanks.
..seemed the best way to raise the alert.
Regards, PhredE
