XnView 2.48
XnView 2.48
Dear user,
XnView 2.48 for Windows is available. Versions are available on the normal XnView Download page.
Please note that the XnView Download page offers packages with German/French Setup and German/French Online help.
Direct links to the English Standard version are:
http://download.xnview.com/XnView-win.exe (English Setup, Multi language)
http://download.xnview.com/XnView-win.zip (ZIP file, Multi language)
XnView Shell Extension 32bits:
http://download.xnview.com/XnShellEx.exe
http://download.xnview.com/XnShellEx.zip
XnView Shell Extension 64bits:
http://download.xnview.com/XnShellEx64.exe
http://download.xnview.com/XnShellEx64.zip
SHA256:
XnView-win.exe: EDC6123EA972580360D7FF4633B4B7374FAF5FE6A9F8C145BDCAEC394853BD70
XnView-win.zip: 55B3027D1BB0B9E281D64201608C4988B7D4D397BAE6EAD3569E79F67AF317A0
XnView-win-full.exe: 04758D98547BD1B2746062AA4703B21FA46BE02A0CE5F0A90A4CE1CA8B1AEBD3
XnView-win-full.zip: 82E9B132CD47A2259D0137329B9E65D7AB9A835BDD86A58247A92C8915FCA7A6
XnView-win-small.exe: 3DDFFCDF5B3F2E5A9757271B3A89808291BF9D04AAE32A0D58AB9AE0FCF5E8D8
XnView-win-small.zip: A4B19EF6D1EF873C9AA47BD8A3492EDDFED9A304945AE9BDC8908565C9B6588E
____ 2.48 Changelog
* RGB inverted when printing 8bits cmap picture from browser
* WebP 32bits
* PDF Multipage create - viewtopic.php?f=35&t=38030
____ 2.47 Changelog
XCF 2.10
ICNS with JPEG2000 icon
GIF loop & Quick slideshow - viewtopic.php?f=36&t=31689
Problem with local charset for image description EXIF field
[Start]/BugBlueLine=1 to remove the bug of blue line
PDF output without font info - viewtopic.php?f=35&t=38030
Space must not show tagbox if not enabled
NConvert: -no_auto_rotate - viewtopic.php?f=57&t=38239
NConvert: -autocrop with position
NConvert: add -lower to lower case output filename
NConvert: Bug when output filename contains a numeric enumerator - viewtopic.php?f=57&t=38014
____ 2.46 Changelog
JPEG2000 YCC - viewtopic.php?f=35&t=37806
Bad loading for ARW - viewtopic.php?f=36&t=37683
TIFF with JPEG compression - viewtopic.php?f=35&t=37585
Adjust dialog clipped - viewtopic.php?f=36&t=32011
PDF version 1.4 output
Sqlite 2.24.0
RLE & ICO vulnerabilities Cody Sixteen from STM Solutions
NConvert: stdout problem on windows - viewtopic.php?f=57&t=37810
____ 2.45 Changelog
License written in HKCU
Support HPI with transparency
Shows dots under certain conditions - viewtopic.php?f=36&t=37447
Resize - viewtopic.php?f=36&t=37451
Blue bar - viewtopic.php?f=36&t=36278
Resize dialog crash with ^^ - viewtopic.php?f=36&t=36644
Parameters & External program - viewtopic.php?f=35&t=15465
____ 2.44 Changelog
Monitor power off during slideshow
Color profile not used Browser>Print - viewtopic.php?f=36&t=36833
-filelist doesn't work anymore
Tile child window - viewtopic.php?f=56&t=36527
Strange colors on grey image - viewtopic.php?f=35&t=36485
UTF8 Exif Image Description
____ 2.43 Changelog
Better HEIF support - http://www.xnview.com/download/plugins/heif_x32.zip
Unwanted file types shown in Viewer - viewtopic.php?f=36&t=35484
FileListUseExt=1
Alpha glitch - viewtopic.php?f=36&t=36454
Folder browsing via command line - viewtopic.php?f=36&t=36434
Lossless crop corruption - viewtopic.php?f=36&t=36378
____ 2.42 Changelog
HEIF support - Extract http://www.xnview.com/download/plugins/heif_x32.zip in Plugins folder
____ 2.41 Changelog
Basic support for unicode filename
2Gb limitation on 64bits OS - http://newsgroup.xnview.com/viewtopic.php?f=36&t=35165
Displaying RGBA image without use alpha - http://newsgroup.xnview.com/viewtopic.php?f=36&t=35809
Print TIFF with orientation flag in browser - http://newsgroup.xnview.com/viewtopic.php?f=36&t=36197
GIF loop not saved in .sld - http://newsgroup.xnview.com/viewtopic.php?f=35&t=35991
Clip support - http://newsgroup.xnview.com/viewtopic.php?f=34&t=28554
Slideshow crash on RAW files - http://newsgroup.xnview.com/viewtopic.php?f=36&t=34632
TIF > 2GB & multipage - http://newsgroup.xnview.com/viewtopic.php?f=79&t=35056
RGBA printing
Thumbnails upscaling - http://newsgroup.xnview.com/viewtopic.php?f=35&t=36090
NConvert: -keepdocsize fixed
NConvert: -shadow - http://newsgroup.xnview.com/viewtopic.php?f=57&t=36163
NConvert: -align - http://newsgroup.xnview.com/viewtopic.php?f=57&t=36164
____ 2.40 Changelog
CMYK image default color profile - http://newsgroup.xnview.com/viewtopic.php?f=35&t=31685
http://newsgroup.xnview.com/viewtopic.php?f=35&t=28839
RGBA resize (bilinear) - http://newsgroup.xnview.com/viewtopic.php?f=36&t=33425
http://newsgroup.xnview.com/viewtopic.php?t=29238
http://newsgroup.xnview.com/viewtopic.php?t=34493
Ctrl+RMB to copy color - http://newsgroup.xnview.com/viewtopic.php?p=141793
Capture rectangle on second monitor - http://newsgroup.xnview.com/viewtopic.php?f=56&t=32892
Print 50+ via command line - http://newsgroup.xnview.com/viewtopic.php?f=35&t=35350
Filelist to print - http://newsgroup.xnview.com/viewtopic.php?f=34&t=35378
LIBPNG 1.6.29
SQLite 3.18.0
ZLIB 1.2.11
LCMS 2.8
BMP 2+10+10+10 - http://newsgroup.xnview.com/viewtopic.php?f=36&t=32577
Category removed if delete file - http://newsgroup.xnview.com/viewtopic.p ... 2&start=15
Category moved with Cut/Paste
8BF & undo - http://newsgroup.xnview.com/viewtopic.php?f=36&t=34508
'Purge Now' - http://newsgroup.xnview.com/viewtopic.php?f=34&t=32667
OpenEXR updated - http://newsgroup.xnview.com/viewtopic.php?f=36&t=33039
Resize gamma correction - http://newsgroup.xnview.com/viewtopic.php?f=34&t=33273
Change timestamp & DST - http://newsgroup.xnview.com/viewtopic.php?f=36&t=33483
Selection + Tab - http://newsgroup.xnview.com/viewtopic.php?f=36&t=33983
GIF loop - http://newsgroup.xnview.com/viewtopic.php?f=35&t=34036
PAM format - http://newsgroup.xnview.com/viewtopic.php?f=36&t=35132
JPEG 2000 - http://newsgroup.xnview.com/viewtopic.php?f=36&t=35277
Maximize on first monitor - http://newsgroup.xnview.com/viewtopic.php?f=36&t=32343
Resize default size - http://newsgroup.xnview.com/viewtopic.php?f=34&t=33694
PEF for thumbnail's folder - http://newsgroup.xnview.com/viewtopic.php?f=35&t=35363
Cancel removed from Setup wizard - http://newsgroup.xnview.com/viewtopic.php?f=34&t=32958
Previous/Next file & RecognizeByExt == false - http://newsgroup.xnview.com/viewtopic.php?f=36&t=33127
Next/Previous & video - http://newsgroup.xnview.com/viewtopic.php?f=36&t=35182
Better dialog for update - http://newsgroup.xnview.com/viewtopic.php?f=34&t=19950
WebP plugin updated
OpenJPEG2000 updated
RIOT addon updated
PNGOUT updated
X3F with only embedded JPEG
NConvert: text with -text_rotation - http://newsgroup.xnview.com/viewtopic.php?f=57&t=35441
NConvert: -text_border added
____ 2.39 Changelog
no IPTC fields in tooltip/info
Thumbnail for blend file
____ 2.38 Changelog
Sort by exif - http://newsgroup.xnview.com/viewtopic.php?f=36&t=32387
Zooming instead file navigation - http://newsgroup.xnview.com/viewtopic.php?f=36&t=33917
____ 2.37 Changelog
Better HiDPI support
Change timestamp and video
GPS direction - http://newsgroup.xnview.com/viewtopic.php?f=35&t=33587
Right click (make selection) and delete - http://newsgroup.xnview.com/viewtopic.php?f=36&t=33700
NConvert: Multipage extract - http://newsgroup.xnview.com/viewtopic.php?f=57&t=33879
____ 2.36 Changelog
FLIF format added
SVG support via rsvg-convert.exe - http://newsgroup.xnview.com/viewtopic.php?f=34&t=31748
Search similar & extension - http://newsgroup.xnview.com/viewtopic.php?f=56&t=32840
Multipage save doesn't use read settings
PCT crash - http://newsgroup.xnview.com/viewtopic.php?f=36&t=33025
NConvert: -t start step for number in output name
____ 2.35 Changelog
#THUMB_WIDTH_MAX# & #THUMB_HEIGHT_MAX# - http://newsgroup.xnview.com/viewtopic.php?f=34&t=30652
JPEGXR
Backspace not working in fullscreen
LibPNG 1.6.20
ZIPPack Addon - http://newsgroup.xnview.com/viewtopic.php?f=35&t=31563
johnb
Re: XnView 2.48
Post by johnb »
The SHA256 hash for XnView 2.48 "XnView-win-full.exe" does not match.
Stated:
BE523A62A02ABAD2D908244826C9C0B8643D66198DC2A5601329B3C58FD27517
Actual:
04758d98547bd1b2746062aa4703b21fa46be02a0ce5f0a90a4ce1ca8b1aebd3
https://www.virustotal.com/#/file/04758 ... d3/details
P.S. I didn't check the hashes for the other files.
Re: XnView 2.48
fixed
Dan Harkless
Re: XnView 2.48
Post by Dan Harkless »
The checksums on https://www.xnview.com/en/xnview/ are still showing:
XnView-win-full.exe: BE523A62A02ABAD2D908244826C9C0B8643D66198DC2A5601329B3C58FD27517
Also, FYI, when I first got the update notification from the application, 2.48 was not yet actually available for download from the website.
