XnViewMP 0.93 goes 'Not Responding' on Windows 10
Moderator: Dreamer
Re: XnViewMP 0.93 goes 'Not Responding' on Windows 10
Post by xnview » Tue May 07, 2019 5:32 am
Next version will be available in june
jgh
Post by jgh » Sat May 11, 2019 11:15 pm
Thanks.
DarbyMaddog
Post by DarbyMaddog » Tue Aug 13, 2019 1:18 pm
I have the problem on start of XnviewMP, Not responding. Found if you quit and save the session, you can not open it again
without removing all the setting files in the C:\Users\USERSNAME\AppData\Roaming\XnViewMP\. if you quit without saving session it opens ok the next time.
Post by xnview » Tue Aug 13, 2019 3:13 pm
what contains your session?
RickFromPhila
Post by RickFromPhila » Fri Aug 16, 2019 3:02 pm
I've got it working again by going to the icon, (on desktop, etc), right click for "Properties"...select "Compatibility" tab...select "Run this program as an administrator", below that...Change settings for all users"...then Apply.
When I installed the latest update...it worked fine without admin being selected...but next day at reboot...wouldn't open at all....except doing above.
Thx...hope it helps.
Rick
Post by xnview » Mon Aug 19, 2019 8:07 am
Strange, if you change back, same problem?
jgh
Post by jgh » Sun Oct 27, 2019 9:42 am
Is this issue fixed (supposedly) in XnView 0.94 beta, as I don't see it in the changelog?
Post by xnview » Wed Nov 13, 2019 1:39 pm
0.94 is available...
