Browser to fullscreen issues
Moderators: XnTriq, xnview
Locked
Glantern
Post by Glantern » Wed Nov 02, 2005 5:30 pm
In 1.82 Under tools, options, general, switching modes,
the use double click to switch between
browser > fullscreen > viewer
does not work, instead it makes the image come up in a non-fullscreen viewer.
Using browser <> fullscreen | viewer <> fullscreen doesn't work properly either (if you have the view, fullscreen "enable navigation with left and right mouse button" option selected)-
what happens if you double click the second image in a folder is it comes up fullscreen, but something catches the double click in a buffer or the mouseup event and shows the second image for a second, but then instantly moves back to the first image in the folder- so you always see one off of the image you meant to click.
In 1.80.3, the browser <> fullscreen | viewer option worked ok I think, and the browser > fullscreen > viewer displayed the image you double clicked on. But there was still an issue where if you double clicked again to go to the non-full viewer and left/right navigation was on, it would rewind to the previous image before going to non-fullscreen (probably a similar cause of being confused by the mouse buffer or events).
However in 1.80.3 my normal use of going between browser and fullscreen worked pretty well- in 1.82 my normal use is not working well because of this issue.
(My os is windows xp sp2, using normal microsoft intellipoint mouse driver, 2ghz cpu)
XnView 1.82 alpha
Re: Browser to fullscreen issues
Post by xnview » Wed Nov 02, 2005 8:09 pm
Glantern wrote:In 1.82 Under tools, options, general, switching modes,
Right a bug
Post by helmut » Mon Feb 20, 2006 9:31 pm
Has this been solved in 1.82 final?
marsh
Post by marsh » Tue Feb 21, 2006 10:08 am
helmut wrote:Has this been solved in 1.82 final?
Fixed for me. Users should be able to get 'modes' to act like v.1.80.3 now.
Related fixes below:
http://newsgroup.xnview.com/viewtopic.php?t=4861
http://newsgroup.xnview.com/viewtopic.php?t=4835
http://newsgroup.xnview.com/viewtopic.php?t=4160
Locked
