XnView MP 0.93
Re: XnView MP 0.93
right you need to install libQt5
SenpaiEd
Re: XnView MP 0.93
Post by SenpaiEd »
xnview wrote: Mon Feb 18, 2019 7:20 am right you need to install libQt5
Hi! I've made it with:
sudo apt-get install build-essential
sudo apt-get install qtcreator
sudo apt-get install qt5-default
Also with no result.
SenpaiEd
Re: XnView MP 0.93
Post by SenpaiEd »
I tried to install all missed libraries separately, but the system informs me that libraties are already installed.
May be, the problem is with linking to the QT5 library in /opt/XnView/xnview.sh?
Re: XnView MP 0.93
SenpaiEd wrote: Mon Feb 18, 2019 10:42 am I tried to install all missed libraries separately, but the system informs me that libraties are already installed.
what do you have as libraries /usr/lib/arm-linux-gnueabihf/libQt*?
SenpaiEd
Re: XnView MP 0.93
Post by SenpaiEd »
xnview wrote: Mon Feb 18, 2019 11:58 am what do you have as libraries /usr/lib/arm-linux-gnueabihf/libQt*?
"ls libQt*" in /usr/lib/arm-linux-gnueabihf/ returns this:
libQt5CLucene.so.5                   libQt5QuickTest.so.5.5
libQt5CLucene.so.5.5                 libQt5QuickTest.so.5.5.1
libQt5CLucene.so.5.5.1               libQt5QuickWidgets.prl
libQt5Concurrent.prl                 libQt5QuickWidgets.so
libQt5Concurrent.so                  libQt5QuickWidgets.so.5
libQt5Concurrent.so.5                libQt5QuickWidgets.so.5.5
libQt5Concurrent.so.5.5              libQt5QuickWidgets.so.5.5.1
libQt5Concurrent.so.5.5.1            libQt5Script.so.5
libQt5Core.prl                       libQt5Script.so.5.5
libQt5Core.so                        libQt5Script.so.5.5.1
libQt5Core.so.5                      libQt5Sql.prl
libQt5Core.so.5.5                    libQt5Sql.so
libQt5Core.so.5.5.1                  libQt5Sql.so.5
libQt5DBus.prl                       libQt5Sql.so.5.5
libQt5DBus.so                        libQt5Sql.so.5.5.1
libQt5DBus.so.5                      libQt5Svg.so.5
libQt5DBus.so.5.5                    libQt5Svg.so.5.5
libQt5DBus.so.5.5.1                  libQt5Svg.so.5.5.1
libQt5DesignerComponents.so.5        libQt5Test.prl
libQt5DesignerComponents.so.5.5      libQt5Test.so
libQt5DesignerComponents.so.5.5.1    libQt5Test.so.5
libQt5Designer.so.5                  libQt5Test.so.5.5
libQt5Designer.so.5.5                libQt5Test.so.5.5.1
libQt5Designer.so.5.5.1              libQt5WebKit.so.5
libQt5EglDeviceIntegration.prl       libQt5WebKit.so.5.5
libQt5EglDeviceIntegration.so        libQt5WebKit.so.5.5.1
libQt5EglDeviceIntegration.so.5      libQt5WebKitWidgets.so.5
libQt5EglDeviceIntegration.so.5.5    libQt5WebKitWidgets.so.5.5
libQt5EglDeviceIntegration.so.5.5.1  libQt5WebKitWidgets.so.5.5.1
libQt5Gui.prl                        libQt5Widgets.prl
libQt5Gui.so                         libQt5Widgets.so
libQt5Gui.so.5                       libQt5Widgets.so.5
libQt5Gui.so.5.5                     libQt5Widgets.so.5.5
libQt5Gui.so.5.5.1                   libQt5Widgets.so.5.5.1
libQt5Help.so.5                      libQt5X11Extras.so.5
libQt5Help.so.5.5                    libQt5X11Extras.so.5.5
libQt5Help.so.5.5.1                  libQt5X11Extras.so.5.5.1
libQt5Multimedia.so.5                libQt5XcbQpa.prl
libQt5Multimedia.so.5.5              libQt5XcbQpa.so
libQt5Multimedia.so.5.5.1            libQt5XcbQpa.so.5
libQt5MultimediaWidgets.so.5         libQt5XcbQpa.so.5.5
libQt5MultimediaWidgets.so.5.5       libQt5XcbQpa.so.5.5.1
libQt5MultimediaWidgets.so.5.5.1     libQt5Xml.prl
libQt5Network.prl                    libQt5Xml.so
libQt5Network.so                     libQt5Xml.so.5
libQt5Network.so.5                   libQt5Xml.so.5.5
libQt5Network.so.5.5                 libQt5Xml.so.5.5.1
libQt5Network.so.5.5.1               libQtCLucene.so.4
libQt5OpenGLExtensions.a             libQtCLucene.so.4.8
libQt5OpenGLExtensions.prl           libQtCLucene.so.4.8.7
libQt5OpenGL.so.5                    libQtCore.so.4
libQt5OpenGL.so.5.5                  libQtCore.so.4.8
libQt5OpenGL.so.5.5.1                libQtCore.so.4.8.7
libQt5PrintSupport.prl               libQtDBus.so.4
libQt5PrintSupport.so                libQtDBus.so.4.8
libQt5PrintSupport.so.5              libQtDBus.so.4.8.7
libQt5PrintSupport.so.5.5            libQtDeclarative.so.4
libQt5PrintSupport.so.5.5.1          libQtDeclarative.so.4.8
libQt5QmlDevTools.a                  libQtDeclarative.so.4.8.7
libQt5QmlDevTools.prl                libQtGui.so.4
libQt5Qml.prl                        libQtGui.so.4.8
libQt5Qml.so                         libQtGui.so.4.8.7
libQt5Qml.so.5                       libQtNetwork.so.4
libQt5Qml.so.5.5                     libQtNetwork.so.4.8
libQt5Qml.so.5.5.1                   libQtNetwork.so.4.8.7
libQt5QuickParticles.prl             libQtScript.so.4
libQt5QuickParticles.so              libQtScript.so.4.8
libQt5QuickParticles.so.5            libQtScript.so.4.8.7
libQt5QuickParticles.so.5.5          libQtSql.so.4
libQt5QuickParticles.so.5.5.1        libQtSql.so.4.8
libQt5Quick.prl                      libQtSql.so.4.8.7
libQt5Quick.so                       libQtXmlPatterns.so.4
libQt5Quick.so.5                     libQtXmlPatterns.so.4.8
libQt5Quick.so.5.5                   libQtXmlPatterns.so.4.8.7
libQt5Quick.so.5.5.1                 libQtXml.so.4
libQt5QuickTest.prl                  libQtXml.so.4.8
libQt5QuickTest.so                   libQtXml.so.4.8.7
Re: XnView MP 0.93
so you have libs, i don't understand
AmigaGamer
Re: XnView MP 0.93
Post by AmigaGamer »
SenpaiEd wrote: Mon Feb 18, 2019 12:27 pm
I had a similar problem on RaspberryPi with QT libraries not being detected. I "think" i had to run
sudo ldconfig
after installing them , but it was a few weeks back so can't remember exactly.. All working fine for me now.
Check for Updates is showing 0.93 is available , but i can only find .92 on the site? Is there an Arm build of 0.93?
Re: XnView MP 0.93
AmigaGamer wrote: Mon Feb 25, 2019 10:32 am Check for Updates is showing 0.93 is available , but i can only find .92 on the site? Is there an Arm build of 0.93?
not yet
KPAH
Re: XnView MP 0.93
Post by KPAH »
Pierre, you ended up with a bunch of redist files in the 64-bit zip download
Clipboard 1.png (20.97 KiB) Viewed 13007 times
Re: XnView MP 0.93
KPAH wrote: Sat Mar 16, 2019 4:38 pm Pierre, you ended up with a bunch of redist files in the 64-bit zip download
yes needed for users that have not them
SenpaiEd
Re: XnView MP 0.93
Post by SenpaiEd »
AmigaGamer wrote: Mon Feb 25, 2019 10:32 am I had a similar problem on RaspberryPi with QT libraries not being detected. I "think" i had to run
sudo ldconfig
Can You, please, describe exactly how to fix the problem starting XnView on ARM devices?
Thank You!
Lee James
Re: XnView MP 0.93
Post by Lee James »
Pierre, thank you so much for the latest version! :)
Forgive my stupidity, but I cannot find the setting for the new "Selection grid setting"?
Re: XnView MP 0.93
Lee James wrote: Sun Mar 24, 2019 9:51 pm Pierre, thank you so much for the latest version! :)
... I cannot find the setting for the new "Selection grid setting"?
Tools > Options... > View -- View tab -- Selection [Normal | Rule of thirds | Phi grid]
Lee James
Re: XnView MP 0.93
Post by Lee James »
cday wrote: Mon Mar 25, 2019 7:09 amTools > Options... > View -- View tab -- Selection [Normal | Rule of thirds | Phi grid]
Thanks but this doesn't work for me. Nothing changes and it looks exactly the same for all three settings. Maybe it's a bug? Or maybe I haven't installed it properly? I just installed over the previous installation.
Re: XnView MP 0.93
Lee James wrote: Mon Mar 25, 2019 2:56 pm
I don''t understand, it works for me even on Linux... :wink:
Your Help > About... shows 0.93? And you have the selection grid options exactly as above? You draw a selection with the mouse, and there is no grid within the selection? Possibly some misunderstanding somewhere???
Edit: I think the detailed interface design of the two selection options could be clearer, and may make a suggestion on that when I have more time.
Locked
