XnView MP 0.93
XnView MP 0.93
Please, don't post bugs or request in this topic!
You can download XnView MP 0.93 here:
Windows x32 ZIP version: http://download.xnview.com/XnViewMP-win.zip
Windows x32 SETUP version: http://download.xnview.com/XnViewMP-win.exe
  • SHA256: 6E4FE10C38329B15384C7F5D5E504AB7B4072EE71887804F6E5F48FB4EEC5A13
Windows x64 ZIP version: http://download.xnview.com/XnViewMP-win-x64.zip
Windows x64 SETUP version: http://download.xnview.com/XnViewMP-win-x64.exe
  • SHA256: D7493C82CC146803F9FA2315F582547BF312801AC4493BA95CDEA5CF95A72B19
For Windows 7 and older, you have to install the driver from DirectX to run correctly QtAV (audio/video)
Mac x64 TGZ version: http://download.xnview.com/XnViewMP-mac.tgz
Mac x64 DMG version: http://download.xnview.com/XnViewMP-mac.dmg
Linux TGZ version: http://download.xnview.com/XnViewMP-linux.tgz
Linux DEB version: http://download.xnview.com/XnViewMP-linux.deb
Linux x64 TGZ version: http://download.xnview.com/XnViewMP-linux-x64.tgz
Linux x64 DEB version: http://download.xnview.com/XnViewMP-linux-x64.deb
ARM version: http://download.xnview.com/XnViewMP-linux-arm.tgz http://download.xnview.com/XnViewMP-lin ... _armhf.deb
Linux x64 AppImages version: http://download.xnview.com/XnView_MP-0. ... 4.AppImage
Changelog 0.93:
1507: [New] Space key for next picture
1506: [New] 'Add selection to Favorites' - http://newsgroup.xnview.com/viewtopic.php?t=37666
1505: [New] After 'save as', use output filename setting
1504: [New] Format option button in save dialog (Windows only)
1500: [New] SHIFT/CTRL to constraint drawing line horizontally/vertically
1543: [New] ScrollbarValue setting - http://newsgroup.xnview.com/viewtopic.php?t=33419
1540: [New] Selection grid setting - http://newsgroup.xnview.com/viewtopic.php?t=38270
1539: [New] [General/scanDone] to close or not TWAIN dialog after scan
1534: [New] Import&Sort: Video subfolder - http://newsgroup.xnview.com/viewtopic.php?t=37976
0076: [New] Batch Processing running on multiple cores - http://newsgroup.xnview.com/viewtopic.php?t=24355
1524: [New] WEBP EXIF/XMP support
1523: [New] OpenJPEG updated
1522: [New] WEBP updated
1516: [New] Settings to choose color label - http://newsgroup.xnview.com/viewtopic.php?t=38191
1515: [New] Ratio always > 0, settings added - http://newsgroup.xnview.com/viewtopic.php?t=38107
1514: [New] -clipaste
1553: [Bug] IPTC dialog: Crash 'insert from' in Edit mode
1552: [Bug] Capture (rectangle) with hotkey returns desktop
1551: [Bug] Batch convert: Description not used in 'Add Text'
1550: [Bug] Slideshow: Audio file not loaded from .sld - http://newsgroup.xnview.com/viewtopic.php?t=38427
1549: [Bug] Import&Sort: Image with no EXIF date are not imported
1548: [Bug] Batch Convert: 'Keep structure' & 'Keep parent' can't convert on same root partition
1547: [Bug] Resize presets not correctly saved/restored - http://newsgroup.xnview.com/viewtopic.php?t=38351
1546: [Bug] Crash when renaming folder in folder tree - http://newsgroup.xnview.com/viewtopic.php?t=38380
1545: [Bug] Batch convert: Delete icon not enabled after saving script
1544: [Bug] Batch convert: Small/Large thumbnails setting not restored
1542: [Bug] XnConvert: 'Delete original' setting not saved - http://newsgroup.xnview.com/viewtopic.php?t=38355
1541: [Bug] ICNS with JPEG2000 icon - http://newsgroup.xnview.com/viewtopic.php?t=38363
1538: [Bug] Seek video by clicking on time slider bar - http://newsgroup.xnview.com/viewtopic.php?t=35144
1537: [Bug] XCF 2.10
1536: [Bug] Curves: Area to move control point too small - http://newsgroup.xnview.com/viewtopic.php?t=38336
1535: [Bug] key navigation disabled after crop - http://newsgroup.xnview.com/viewtopic.php?t=38294
1533: [Bug] Paint: Text not saved - http://newsgroup.xnview.com/viewtopic.php?t=37691
1532: [Bug] Contact Sheet: no top margin - http://newsgroup.xnview.com/viewtopic.php?t=37617
0756: [Bug] Print custom size - http://newsgroup.xnview.com/viewtopic.php?t=32327
1531: [Bug] Linux move to trash - http://newsgroup.xnview.com/viewtopic.php?t=37989
1530: [Bug] Freeze when creating thumbnail for small video files - http://newsgroup.xnview.com/viewtopic.php?t=38045
1529: [Bug] DPX 8bits load/save - http://newsgroup.xnview.com/viewtopic.php?t=38159
1528: [Bug] Language mix in dialogs - http://newsgroup.xnview.com/viewtopic.php?t=38096
1527: [Bug] Batch Convert Drag&Drop does not work when listview is enabled - http://newsgroup.xnview.com/viewtopic.php?t=38266
1526: [Bug] Open a PDF can show an error - http://newsgroup.xnview.com/viewtopic.php?t=38249
1525: [Bug] Can't drag in browser mode if there are marked files - http://newsgroup.xnview.com/viewtopic.php?t=38227
1521: [Bug] XCF dead lock
1520: [Bug] Context menu must not be shown on folder in favorite
1519: [Bug] Dead lock on mpa/m4a files - http://newsgroup.xnview.com/viewtopic.php?t=38224
1517: [Bug] Problem with icons generation, settings added (was causing some crash on older QT)
1513: [Bug] Problems when searching with 'base path'
1512: [Bug] MacOSX: UI problem with video files
1511: [Bug] IPTC keywords sorted in details view - http://newsgroup.xnview.com/viewtopic.php?t=38011
1510: [Bug] .lnk can't be viewed - http://newsgroup.xnview.com/viewtopic.php?t=37995
1509: [Bug] Batch Rename: same name but different extension - http://newsgroup.xnview.com/viewtopic.php?t=38020
1508: [Bug] Arrow keys not working in list view
1503: [Bug] Slideshow: use transition not checked after loading .sld
1502: [Bug] Batch convert: Clear input file don't work anymore
1501: [Bug] Slideshow crash
1499: [Bug] Searching by Image Width and Image Height Returns 0 Results - http://newsgroup.xnview.com/viewtopic.php?t=38100
1498: [Bug] Batch Convert: 'Source folder' not selected after load .xbs - http://newsgroup.xnview.com/viewtopic.php?t=38057
1491: [Bug] Load & save image with ICC profile doesn't change icc (sRGB) - http://newsgroup.xnview.com/viewtopic.php?t=37755
1497: [Bug] Bad decoding of embedded comment
1496: [Bug] Crash when renaming Favorites
Changelog 0.92:
1495: [Bug] Open problem - viewtopic.php?f=62&t=37920
1495: [Bug] Switch mode - viewtopic.php?f=62&t=37916
Changelog 0.91:
1487: [New] PDF v1.4 output
1486: [New] Sqlite 2.24.0
1482: [New] Audio with slideshow - viewtopic.php?f=60&t=37463
1387: [New] Ratio field - viewtopic.php?f=60&t=37204
1384: [New] Batch convert: Back color added to convert 32bits into 24bits - viewtopic.php?f=110&t=37147
1391: [New] Autocomplete in copy/move dialog - viewtopic.php?f=110&t=37257
1478: [New] Join: Fit width or height
1475: [New] Batch resize by width or height - viewtopic.php?f=60&t=36864
1471: [New] PackJPG format (read)
1470: [New] Lepton format (read) added
1467: [New] Companion files handling - viewtopic.php?f=95&t=35508
1465: [New] HPI alpha channel supported
1464: [New] Custom title bar in browse mode - viewtopic.php?f=82&t=37446
1457: [New] Change timestamp: Increment at each file - viewtopic.php?f=82&t=37416
1456: [New] Edit colormap - viewtopic.php?f=95&t=37217
1452: [New] QtAV used on Linux/Mac for video playing/thumbnailing
1454: [New] Message before to quit - viewtopic.php?f=82&t=37380
1447: [New] More options for RAW
1439: [New] KRITA support - viewtopic.php?f=60&t=33385
1433: [New] 'Use Alpha channel' not remembered - viewtopic.php?f=95&t=34644
1432: [New] Search: Select pathname field - viewtopic.php?f=95&t=37086
1441: [New] Tooltips when drawing selection - viewtopic.php?f=60&t=37259
1427: [New] Recent quick search list - viewtopic.php?f=95&t=37201
1425: [New] Resize dialog - viewtopic.php?f=95&t=36772
1409: [New] Relative path in .sld - viewtopic.php?f=62&t=37181
1406: [New] Information for Audio/Video file - viewtopic.php?f=95&t=35843
1405: [New] Sharpen in Resize dialog
1404: [New] Autoskew in edit mode
1400: [New] IPTC dialog in view mode - viewtopic.php?f=60&t=34630
1399: [New] Setting to create descript.ion in UTF8
1493: [Bug] ICC support in compare - viewtopic.php?f=62&t=37808
1492: [Bug] JPEG2000 YCC - viewtopic.php?f=35&t=37806
1491: [Bug] Load & save image with ICC profile doesn't change icc (sRGB) - viewtopic.php?f=62&t=37755
1490: [Bug] 'Crop, save & next' doesn't always save cropped image - viewtopic.php?f=82&t=37730
1489: [Bug] Batch convert- automatic crop - viewtopic.php?f=79&t=37782
1488: [Bug] When catalog is not used, can't save search
1485: [Bug] Save 32bits as jpeg - viewtopic.php?f=62&t=37638
1484: [Bug] Crash with 1x1 png - Thanks to Martin Orem of Binary House
1483: [Bug] TIFF with JPEG compression - viewtopic.php?f=35&t=37585
1481: [Bug] IPTC Edit: Object name not always modified on RAW - viewtopic.php?f=83&t=37441
1480: [Bug] Deselecting by CTRL key - viewtopic.php?f=62&t=37486
1479: [Bug] Batch convert: Problem when filename has $ character
1477: [Bug] Embedded comment always written in utf8 - viewtopic.php?f=62&t=37497
1476: [Bug] Batch convert: if 'delete original', steals focus - viewtopic.php?f=79&t=37328
1474: [Bug] Batch Rename: First item no more selected - viewtopic.php?f=62&t=37297
1473: [Bug] Dialog Edit curves: curve not visible if preview enabled - viewtopic.php?f=62&t=37487
1472: [Bug] Crop unavailable until change crop area manually - viewtopic.php?f=82&t=37461
1469: [Bug] Export: wepb quality widget too small - viewtopic.php?f=62&t=37482
1468: [Bug] Slow when entering on a folder with a lot of files (icon create)
1466: [Bug] Characters problem with exif label in view informations - viewtopic.php?f=83&t=37459
1463: [Bug] Edit IPTC: no hierarchicalSubject written for RAW - viewtopic.php?f=83&t=37441
1462: [Bug] Edit IPTC: EXIF:artist modified on RAW file - viewtopic.php?f=83&t=37441
1461: [Bug] Long full path on windows 10 - viewtopic.php?f=95&t=36108
1460: [Bug] Batch Convert: Hot folder, files not completly written, can't be readed - viewtopic.php?f=79&t=3743
1459: [Bug] Error reading panorama image from S9 - viewtopic.php?f=62&t=37427
1458: [Bug] Rounded value in batch resize - viewtopic.php?f=36&t=37451
1455: [Bug] Filesize in Info not changed after save - viewtopic.php?f=62&t=37319
1453: [Bug] Video thumbnail not correctly build by QtAv
1451: [Bug] Open image tab while in fullscreen on second monitor - viewtopic.php?f=62&t=35028
1450: [Bug] PDF output on Linux - viewtopic.php?f=82&t=37376
1449: [Bug] Batch convert: Preview 'after' not always loaded - viewtopic.php?f=62&t=37377
1448: [Bug] All details on info pane are missing while Fullscreen preview is active - viewtopic.php?f=95&t=3658
1446: [Bug] Join: Collage on non image files
1445: [Bug] Batch Convert: ESC before end of process
1444: [Bug] Grid settings are not saved - viewtopic.php?f=62&t=37363
1443: [Bug] When selecting file without thumbnail, should create this one first - viewtopic.php?f=95&t=36704
1442: [Bug] Folders in folder tree are expanded - viewtopic.php?f=62&t=36808
1440: [Bug] Webm support
1438: [Bug] Excluding folders in Catalog & copy files - viewtopic.php?f=95&t=36635
1437: [Bug] Batch Convert: Hot folders & subdirectories - viewtopic.php?f=82&t=37338
1436: [Bug] Included/excluded folder list - double entries possible - viewtopic.php?f=62&t=37345
1435: [Bug] Slideshow order is not being restored on opening an .sld - viewtopic.php?f=62&t=37360
1434: [Bug] Thumbnail and Image Orientation out of sync after Jpeg Lossless Rotate - viewtopic.php?f=95&t=36687
1431: [Bug] Compare: thumbnails view size - viewtopic.php?f=95&t=36954
1430: [Bug] EXIF Image width/height is not updated - viewtopic.php?f=95&t=36625
1429: [Bug] Move shortcut of file - viewtopic.php?f=95&t=36971
1428: [Bug] Name collision dialog uses old name on renaming - viewtopic.php?f=95&t=37084
1426: [Bug] Ctrl+Right Click does not select the image - viewtopic.php?f=95&t=36951
1424: [Bug] Wheel on preview change focus - viewtopic.php?f=95&t=36767
1423: [Bug] Ctrl+Right Click unselects the image in detail view - viewtopic.php?f=95&t=36950
1422: [Bug] Selection must be restored after undo - viewtopic.php?f=95&t=37102
1421: [Bug] Rating/Label on folder always cleared - viewtopic.php?f=95&t=37269
1420: [Bug] Selection with the keyboard controls is inconsistent - viewtopic.php?f=95&t=34297
1419: [Bug] Duplicate video playback - viewtopic.php?f=95&t=35953
1418: [Bug] Not responsive while opening image file - viewtopic.php?f=95&t=35057
1417: [Bug] Wrong focus after returning from image tab - viewtopic.php?f=95&t=35964
1416: [Bug] Image navigation pane shown on animated GIF - viewtopic.php?f=95&t=36012
1415: [Bug] MacOSX: copy instead of move on same partition - viewtopic.php?f=95&t=35754
1414: [Bug] Fixed ratio for selection and horizontal handler - viewtopic.php?f=95&t=36457
1413: [Bug] PDF when viewing are not skipped if ghosctscript is not installed - viewtopic.php?f=95&t=35338
1412: [Bug] Batch Convert: Delete original always use recycle bin - viewtopic.php?f=95&t=37132
1411: [Bug] Thumbnail ratio - viewtopic.php?f=95&t=33725
1410: [Bug] Batch Rename not possible on Movie - viewtopic.php?f=95&t=35923
1401: [Bug] Modified date for OpenXML format changed when creating thumbnail - viewtopic.php?f=62&t=37344
1408: [Bug] Keys in slideshow - viewtopic.php?f=62&t=37181
1407: [Bug] Favorites not sorted after adding one - viewtopic.php?f=95&t=37092
1403: [Bug] Batch Rename: 'always added' not saved - viewtopic.php?f=60&t=37332
1402: [Bug] Wrong thumbnail from catalog - viewtopic.php?f=82&t=33548
1398: [Bug] Slow search on annotations - viewtopic.php?f=82&t=37295
1397: [Bug] Annotation doesn't work, in slideshow - viewtopic.php?f=82&t=37300
1396: [Bug] Freeze when clicking on .url - viewtopic.php?f=62&t=37289
1395: [Bug] Windows default context menu use only 1 file - viewtopic.php?f=82&t=37287
1394: [Bug] Export resize for NConvert - viewtopic.php?f=79&t=37278
1393: [Bug] Thumbnail process on big files can't be interrupted - viewtopic.php?f=110&t=37182
1390: [Bug] Cancel 'Edit Favorites path' - viewtopic.php?f=62&t=37100
1389: [Bug] Print: Incorrect caption in picture collection - viewtopic.php?f=62&t=37274
1388: [Bug] Directory locked after batch convert - viewtopic.php?f=62&t=37242
1386: [Bug] Batch convert: keep folder and folder at root path
1385: [Bug] Paint: b&w, 8bits colormap are converted with bad colors
1383: [Bug] Batch convert: ICC convert doesn't work on 64bits version - viewtopic.php?f=79&t=37176
1382: [Bug] Batch convert: extension is not changed - viewtopic.php?f=79&t=37165
1381: [Bug] Image with alpha channel converted in JPEG - viewtopic.php?f=82&t=37147
deus-ex
Re: XnView MP 0.93
Post by deus-ex »
Thank you for a great new release, it's very much appreciated!
The release date shown on the changelog page is wrong:
The XnViewMP installer is missing several files that are available only in the ZIP distribution. Besides the entire folder \AddOn\Clut and a couple of language files (qt_ar.qm, qt_bg.qm, qt_da.qm, qt_en.qm, qt_es.qm, qt_gd.qm, qt_he.qm) the following files are unavailable in the installer:
\plugins\audio\qtaudio_wasapi.dll
\plugins\imageformats\qjpeg.dll
\plugins\imageformats\qtiff.dll
\plugins\imageformats\qwebp.dll
\plugins\position\qtposition_geoclue.dll
Can you please clarify whether these files, especially the image format plugins, are critically required and when they are needed. Because, for example XnViewMP is able to display JPG images and convert to the JPG format without the availability of the JPEG image format plugin.
ruebyi
Re: XnView MP 0.93
Post by ruebyi »
Thank you so much for this release!
Re: XnView MP 0.93
deus-ex wrote: Fri Feb 01, 2019 4:40 pm Can you please clarify whether these files, especially the image format plugins, are critically required and when they are needed. Because, for example XnViewMP is able to display JPG images and convert to the JPG format without the availability of the JPEG image format plugin.
I'll fix it, these files are not needed
deus-ex
Re: XnView MP 0.93
Post by deus-ex »
So, can you please confirm whether all the image plugins located in the folder \Plugins\ImageFormats\ can be safely removed?
And to that regard, what about this file: \Plugins\IconEngines\QSVGIcon.dll
I believe XnViewMP has its own internal management routines of icons, so this file probably is not required, too?
Re: XnView MP 0.93
deus-ex wrote: Sat Feb 02, 2019 8:48 am So, can you please confirm whether all the image plugins located in the folder \Plugins\ImageFormats\ can be safely removed?
these plugins are not used
SenpaiEd
Re: XnView MP 0.93
Post by SenpaiEd »
Hi! Thank You for XnView!
I use XnView on Windows PC's with great pleasure very long time!
Just tried to install XnViewMP on ARM-based Armbian (Debian) powered devboard OrangePi +2. This is the only thing I missed on OrangePi.
I used this .deb http://download.xnview.com/XnViewMP-lin ... _armhf.deb
After the installation trying to start the program from the menu. Nothing is happening!
Can You help me to make XnViewMP working? May be, I need to install some dependencies or something else?
Thank You!
Re: XnView MP 0.93
SenpaiEd wrote: Sun Feb 17, 2019 1:24 pm Can You help me to make XnViewMP working? May be, I need to install some dependencies or something else?
when you start xnview from a terminal command, what do you have?
SenpaiEd
Re: XnView MP 0.93
Post by SenpaiEd »
xnview wrote: Sun Feb 17, 2019 1:59 pm
Tried to start from terminal with "sudo xnviewmp", "sudo xnview", "sudo xnviewmp-linux".
The ansver is "no such command".
What correct command must I enter from a terminal to test and get error messages?
Thank You!
SenpaiEd
Re: XnView MP 0.93
Post by SenpaiEd »
This is a screenshot after installation and terminal start.
Re: XnView MP 0.93
SenpaiEd wrote: Sun Feb 17, 2019 2:21 pm This is a screenshot after installation and terminal start.
should be xnview
SenpaiEd
Re: XnView MP 0.93
Post by SenpaiEd »
xnview wrote: Sun Feb 17, 2019 2:45 pm should be xnview
Hi! "sudo xnview" also without result. Also no reaction from click in the menu "Graphic->XnView Multi Platform".
SenpaiEd
Re: XnView MP 0.93
Post by SenpaiEd »
Hi! I have found the XnView directory in /opt/XnView/
Nothing happening when I try to start the XnView executable.
SenpaiEd
Re: XnView MP 0.93
Post by SenpaiEd »
Hi! Tried to start:
/opt/XnView/xnview.sh %F
Found error:
/opt/XnView/XnView: error while loading shared libraries: libQt5Svg.so.5: cannot open shared object file: No such file or directory
SenpaiEd
Re: XnView MP 0.93
Post by SenpaiEd »
I also found that:
senpai@orangepiplus:~$ /opt/XnView/xnview.sh %F
/opt/XnView/XnView: /usr/lib/arm-linux-gnueabihf/libQt5X11Extras.so.5: version `Qt_5' not found (required by /opt/XnView/XnView)
/opt/XnView/XnView: /usr/lib/arm-linux-gnueabihf/libQt5Svg.so.5: version `Qt_5' not found (required by /opt/XnView/XnView)
/opt/XnView/XnView: /usr/lib/arm-linux-gnueabihf/libQt5Xml.so.5: version `Qt_5' not found (required by /opt/XnView/XnView)
/opt/XnView/XnView: /usr/lib/arm-linux-gnueabihf/libQt5Concurrent.so.5: version `Qt_5' not found (required by /opt/XnView/XnView)
/opt/XnView/XnView: /usr/lib/arm-linux-gnueabihf/libQt5MultimediaWidgets.so.5: version `Qt_5' not found (required by /opt/XnView/XnView)
/opt/XnView/XnView: /usr/lib/arm-linux-gnueabihf/libQt5Multimedia.so.5: version `Qt_5' not found (required by /opt/XnView/XnView)
/opt/XnView/XnView: /usr/lib/arm-linux-gnueabihf/libQt5Network.so.5: version `Qt_5_PRIVATE_API' not found (required by /opt/XnView/XnView)
/opt/XnView/XnView: /usr/lib/arm-linux-gnueabihf/libQt5Network.so.5: version `Qt_5' not found (required by /opt/XnView/XnView)
/opt/XnView/XnView: /usr/lib/arm-linux-gnueabihf/libQt5WebKitWidgets.so.5: no version information available (required by /opt/XnView/XnView)
/opt/XnView/XnView: /usr/lib/arm-linux-gnueabihf/libQt5PrintSupport.so.5: version `Qt_5' not found (required by /opt/XnView/XnView)
/opt/XnView/XnView: /usr/lib/arm-linux-gnueabihf/libQt5Gui.so.5: version `Qt_5' not found (required by /opt/XnView/XnView)
/opt/XnView/XnView: /usr/lib/arm-linux-gnueabihf/libQt5Core.so.5: version `Qt_5' not found (required by /opt/XnView/XnView)
/opt/XnView/XnView: /usr/lib/arm-linux-gnueabihf/libQt5Widgets.so.5: version `Qt_5' not found (required by /opt/XnView/XnView)
What should I install by one command to make XnView work?
