XnView 2.47
XnView 2.47
Dear user,
XnView 2.47 for Windows is available. Versions are available on the normal XnView Download page.
Please note that the XnView Download page offers packages with German/French Setup and German/French Online help.
Direct links to the English Standard version are:
http://download.xnview.com/XnView-win.exe (English Setup, Multi language)
http://download.xnview.com/XnView-win.zip (ZIP file, Multi language)
XnView Shell Extension 32bits:
http://download.xnview.com/XnShellEx.exe
http://download.xnview.com/XnShellEx.zip
XnView Shell Extension 64bits:
http://download.xnview.com/XnShellEx64.exe
http://download.xnview.com/XnShellEx64.zip
SHA256:
XnView-win.exe: 49329BE79D3FCDA2EBDF66D87C815D315957582E5B1FCB04DDE5AAC3BBC1AC84
XnView-win.zip: 215755E2108BDCF17F1E8D0840441BC804052B50030826E9DC8D2A568607D7C8
XnView-win-full.exe: 7559400499F2E2A0C40BCC12FC1BC3822925E8B9F2FC2224A892B04FBA29DA66
XnView-win-full.zip: 1B7148D92DFC14182A9C345DF3107EF8A5250B5516C9B4912C3A22C1853F7B9A
XnView-win-small.exe: 3861EDDF8AA8168B427547E28687B343DB68580B504E02C3D640514F7999336E
XnView-win-small.zip: 00EAF6727565976BDFB4092C21D968DA481BB7791E04FBD4911194302FED385C
____ 2.47 Changelog
XCF 2.10
ICNS with JPEG2000 icon
GIF loop & Quick slideshow - viewtopic.php?f=36&t=31689
Problem with local charset for image description EXIF field
[Start]/BugBlueLine=1 to remove the bug of blue line
PDF output without font info - viewtopic.php?f=35&t=38030
Space must not show tagbox if not enabled
NConvert: -no_auto_rotate - viewtopic.php?f=57&t=38239
NConvert: -autocrop with position
NConvert: add -lower to lower case output filename
NConvert: Bug when output filename contains a numeric enumerator - viewtopic.php?f=57&t=38014
____ 2.46 Changelog
JPEG2000 YCC - viewtopic.php?f=35&t=37806
Bad loading for ARW - viewtopic.php?f=36&t=37683
TIFF with JPEG compression - viewtopic.php?f=35&t=37585
Adjust dialog clipped - viewtopic.php?f=36&t=32011
PDF version 1.4 output
Sqlite 2.24.0
RLE & ICO vulnerabilities Cody Sixteen from STM Solutions
NConvert: stdout problem on windows - viewtopic.php?f=57&t=37810
____ 2.45 Changelog
License written in HKCU
Support HPI with transparency
Shows dots under certain conditions - viewtopic.php?f=36&t=37447
Resize - viewtopic.php?f=36&t=37451
Blue bar - viewtopic.php?f=36&t=36278
Resize dialog crash with ^^ - viewtopic.php?f=36&t=36644
Parameters & External program - viewtopic.php?f=35&t=15465
____ 2.44 Changelog
Monitor power off during slideshow
Color profile not used Browser>Print - viewtopic.php?f=36&t=36833
-filelist doesn't work anymore
Tile child window - viewtopic.php?f=56&t=36527
Strange colors on grey image - viewtopic.php?f=35&t=36485
UTF8 Exif Image Description
____ 2.43 Changelog
Better HEIF support - http://www.xnview.com/download/plugins/heif_x32.zip
Unwanted file types shown in Viewer - viewtopic.php?f=36&t=35484
FileListUseExt=1
Alpha glitch - viewtopic.php?f=36&t=36454
Folder browsing via command line - viewtopic.php?f=36&t=36434
Lossless crop corruption - viewtopic.php?f=36&t=36378
____ 2.42 Changelog
HEIF support - Extract http://www.xnview.com/download/plugins/heif_x32.zip in Plugins folder
____ 2.41 Changelog
Basic support for unicode filename
2Gb limitation on 64bits OS - http://newsgroup.xnview.com/viewtopic.php?f=36&t=35165
Displaying RGBA image without use alpha - http://newsgroup.xnview.com/viewtopic.php?f=36&t=35809
Print TIFF with orientation flag in browser - http://newsgroup.xnview.com/viewtopic.php?f=36&t=36197
GIF loop not saved in .sld - http://newsgroup.xnview.com/viewtopic.php?f=35&t=35991
Clip support - http://newsgroup.xnview.com/viewtopic.php?f=34&t=28554
Slideshow crash on RAW files - http://newsgroup.xnview.com/viewtopic.php?f=36&t=34632
TIF > 2GB & multipage - http://newsgroup.xnview.com/viewtopic.php?f=79&t=35056
RGBA printing
Thumbnails upscaling - http://newsgroup.xnview.com/viewtopic.php?f=35&t=36090
NConvert: -keepdocsize fixed
NConvert: -shadow - http://newsgroup.xnview.com/viewtopic.php?f=57&t=36163
NConvert: -align - http://newsgroup.xnview.com/viewtopic.php?f=57&t=36164
____ 2.40 Changelog
CMYK image default color profile - http://newsgroup.xnview.com/viewtopic.php?f=35&t=31685
http://newsgroup.xnview.com/viewtopic.php?f=35&t=28839
RGBA resize (bilinear) - http://newsgroup.xnview.com/viewtopic.php?f=36&t=33425
http://newsgroup.xnview.com/viewtopic.php?t=29238
http://newsgroup.xnview.com/viewtopic.php?t=34493
Ctrl+RMB to copy color - http://newsgroup.xnview.com/viewtopic.php?p=141793
Capture rectangle on second monitor - http://newsgroup.xnview.com/viewtopic.php?f=56&t=32892
Print 50+ via command line - http://newsgroup.xnview.com/viewtopic.php?f=35&t=35350
Filelist to print - http://newsgroup.xnview.com/viewtopic.php?f=34&t=35378
LIBPNG 1.6.29
SQLite 3.18.0
ZLIB 1.2.11
LCMS 2.8
BMP 2+10+10+10 - http://newsgroup.xnview.com/viewtopic.php?f=36&t=32577
Category removed if delete file - http://newsgroup.xnview.com/viewtopic.p ... 2&start=15
Category moved with Cut/Paste
8BF & undo - http://newsgroup.xnview.com/viewtopic.php?f=36&t=34508
'Purge Now' - http://newsgroup.xnview.com/viewtopic.php?f=34&t=32667
OpenEXR updated - http://newsgroup.xnview.com/viewtopic.php?f=36&t=33039
Resize gamma correction - http://newsgroup.xnview.com/viewtopic.php?f=34&t=33273
Change timestamp & DST - http://newsgroup.xnview.com/viewtopic.php?f=36&t=33483
Selection + Tab - http://newsgroup.xnview.com/viewtopic.php?f=36&t=33983
GIF loop - http://newsgroup.xnview.com/viewtopic.php?f=35&t=34036
PAM format - http://newsgroup.xnview.com/viewtopic.php?f=36&t=35132
JPEG 2000 - http://newsgroup.xnview.com/viewtopic.php?f=36&t=35277
Maximize on first monitor - http://newsgroup.xnview.com/viewtopic.php?f=36&t=32343
Resize default size - http://newsgroup.xnview.com/viewtopic.php?f=34&t=33694
PEF for thumbnail's folder - http://newsgroup.xnview.com/viewtopic.php?f=35&t=35363
Cancel removed from Setup wizard - http://newsgroup.xnview.com/viewtopic.php?f=34&t=32958
Previous/Next file & RecognizeByExt == false - http://newsgroup.xnview.com/viewtopic.php?f=36&t=33127
Next/Previous & video - http://newsgroup.xnview.com/viewtopic.php?f=36&t=35182
Better dialog for update - http://newsgroup.xnview.com/viewtopic.php?f=34&t=19950
WebP plugin updated
OpenJPEG2000 updated
RIOT addon updated
PNGOUT updated
X3F with only embedded JPEG
NConvert: text with -text_rotation - http://newsgroup.xnview.com/viewtopic.php?f=57&t=35441
NConvert: -text_border added
____ 2.39 Changelog
no IPTC fields in tooltip/info
Thumbnail for blend file
____ 2.38 Changelog
Sort by exif - http://newsgroup.xnview.com/viewtopic.php?f=36&t=32387
Zooming instead file navigation - http://newsgroup.xnview.com/viewtopic.php?f=36&t=33917
____ 2.37 Changelog
Better HiDPI support
Change timestamp and video
GPS direction - http://newsgroup.xnview.com/viewtopic.php?f=35&t=33587
Right click (make selection) and delete - http://newsgroup.xnview.com/viewtopic.php?f=36&t=33700
NConvert: Multipage extract - http://newsgroup.xnview.com/viewtopic.php?f=57&t=33879
____ 2.36 Changelog
FLIF format added
SVG support via rsvg-convert.exe - http://newsgroup.xnview.com/viewtopic.php?f=34&t=31748
Search similar & extension - http://newsgroup.xnview.com/viewtopic.php?f=56&t=32840
Multipage save doesn't use read settings
PCT crash - http://newsgroup.xnview.com/viewtopic.php?f=36&t=33025
NConvert: -t start step for number in output name
____ 2.35 Changelog
#THUMB_WIDTH_MAX# & #THUMB_HEIGHT_MAX# - http://newsgroup.xnview.com/viewtopic.php?f=34&t=30652
JPEGXR
Backspace not working in fullscreen
LibPNG 1.6.20
ZIPPack Addon - http://newsgroup.xnview.com/viewtopic.php?f=35&t=31563
Aokromes
Re: XnView 2.47
Post by Aokromes »
Again i must disturb you xd https://www.xnview.com/en/xnview/#changelog points to 2.46 :)
Re: XnView 2.47
Aokromes wrote: Fri Jan 18, 2019 12:05 am Again i must disturb you xd https://www.xnview.com/en/xnview/#changelog points to 2.46 :)
right :(
Soban
Re: XnView 2.47
Post by Soban »
why are you still developing classic version? I thought MP version is the primary now
Re: XnView 2.47
Soban wrote: Mon Jan 28, 2019 7:12 am why are you still developing classic version? I thought MP version is the primary now
yes, but there is users of classic too
ckit
Re: XnView 2.47
Post by ckit »
XnView Classic is way faster and more responsive than XnViewMP due to QT5.
I'll always prefer Classic even Ashampoo Photo Commander is faster than XnViewMP
Windows 10 Pro x64 21H2 and Vivaldi Browser (standalone)
Soban
Re: XnView 2.47
Post by Soban »
ckit wrote: Thu Jan 31, 2019 11:22 am
maybe it's faster but only on windows ;)
Re: XnView 2.47
Soban wrote: Thu Jan 31, 2019 11:24 am
Out of interest, if you are using Linux, have you tried with Wine, or on a Mac using CrossOver?
Soban
Re: XnView 2.47
Post by Soban »
cday wrote: Thu Jan 31, 2019 11:46 am
TBH I'm not looking for other aplication, MP works fine on my mac so I don't need to :) just asked out of curiosity ;)
Re: XnView 2.47
On a Mac you don't have the very slow startup issue widely reported on the forum?
Soban
Re: XnView 2.47
Post by Soban »
cday wrote: Thu Jan 31, 2019 11:58 am
it depends on what is "very slow" for whom :) maybe it's not super fast but it's ok for me. maybe because I'm using it just few times per day
Re: XnView 2.47
cday wrote: Thu Jan 31, 2019 11:58 am On a Mac you don't have the very slow startup issue widely reported on the forum?
On Mac/Linux, there is no such problem. And using Wine is not good, better is to use native app
Re: XnView 2.47
ckit wrote: Thu Jan 31, 2019 11:22 am even Ashampoo Photo Commander is faster than XnViewMP
Which delay for startup do you have?
