Some of EXIF tags can't be used to format the info-string
Alexey Lubkin
Post by Alexey Lubkin »
One unable to use most important exif tags which is displayed at the bottom of metadata list (Alt+Enter -> EXIF). For example, Nikon-D70's exif the "ISO Value" is placed only in the bottom part of the list (called "ISO Setting"), so I can't use it to make(=format) information string (Options->View->Fullscreen->Show Information).
Re: Some of EXIF tags can't be used to format the info-strin
Alexey Lubkin wrote:One unable to use most important exif tags which is displayed at the bottom of metadata list (Alt+Enter -> EXIF). For example, Nikon-D70's exif the "ISO Value" is placed only in the bottom part of the list (called "ISO Setting"), so I can't use it to make(=format) information string (Options->View->Fullscreen->Show Information).
Yes sometimes ISO value is stored on makernotes and not in EXIF standard fields.
Alexey Lubkin
xnview wrote:Yes sometimes ISO value is stored on makernotes and not in EXIF standard fields.
So it would be awesome to have ability to use makernotes, such as "ISO Setting", "Focus Mode", "Lens", "Shutter Count".
This could be done by using special tag, for example
<makernotes="Shutter Count">
Alexey Lubkin
This is still the problem in 1.82 RC3.
I can't see "ISO Setting" in full screen view :(
Alexey Lubkin wrote:This is still the problem in 1.82 RC3.
If ISO setting is in Makernotes, it's normal... Currently no support of makernotes...
Alexey Lubkin
xnview wrote:If ISO setting is in Makernotes, it's normal... Currently no support of makernotes...
It's a pity :(
Something like <makernotes="ISO Setting"> would be very useful for all Nikon photographers! :D
mic
Post by mic »
Vraiment dommage de ne pouvoir accéder la valeur ISO de la photo (nikon D200)
Une idée d'une date de dispo éventuelle ? ça me permettrait de me passer de nikon view et ne plus utiliser que XnView qui est super par ailleurs et le sera encore plus quand on pourra l'utiliser sur une clé usb framakey ;-)
cordialement
mic
mic wrote:Vraiment dommage de ne pouvoir accéder la valeur ISO de la photo (nikon D200)
Non pour l'iso dans les makernotes, je ne sais pas.
Sinon vous pouvez dejà utiliser xnview sur une framakey!
