[0.92] Resize presets are not saved / restored properly (Linux)
Moderators: XnTriq, xnview, Dreamer
pangwolin
Post by pangwolin » Fri Jan 04, 2019 5:00 pm
Since 0.92(?), presets saved through the "Resize" dialog box are not restored properly.
Steps to reproduce:
1. Open "Resize image" dialog
2. Set any value for parameters
3. Click save preset and enter a name
4. The preset is either saved with the wrong values (none?) or restored with the wrong values.
Not sure if this is Linux specific. Can anyone reproduce and confirm?
Interestingly, the "Last used" preset also doesn't load the actual last used values, and instead gives bad values.
Settings values to be saved as preset
Entering a name for our preset as an example:
The preset is not saving the right values:
Note: I could not find out where those values are stored on disk, not even through strace.
pangwolin
Re: [0.92] Resize presets are not saved / restored properly (Linux)
Post by pangwolin » Fri Jan 04, 2019 9:18 pm
Also, it would be really nice to be able to remove the pre-defined presets completely.
It's really annoying to have to browse through all of them to get to my own every time when I know I would NEVER use any of the default ones.
Even pressing keyboard keys to get to them is annoying, especially with the new ones which also start with numbers. For example, if I want to get to 25% fast, now I have to press 25 twice because I get 2560x1600 first.
Also how many times have I accidentally selected resize to 500% instead of 50%. Quite irritating.
EDIT: for those wondering, there is a way to remove the default resize presets by editing the file "ResizePresets.txt"!
Post by xnview » Wed Jan 16, 2019 3:06 pm
Post by xnview » Thu Jan 31, 2019 1:49 pm
This problem is supposed to be fixed in XnView MP 0.93. Please check and confirm the bug fix here.
pangwolin
Post by pangwolin » Thu Jan 31, 2019 7:24 pm
Thank you, I can confirm the bug is fixed in 0.93.
