label setting lost
Locked
flock
label setting lost
Post by flock »
copying my XnView 1.80.3 setup in 1.82 alpha I lost the "labels"; I use this setup in 1.80.3 (picture), in 1.82 alpha I see only the filename
goodbye
XnView 1.82 alpha
Re: label setting lost
flock wrote:copying my XnView 1.80.3 setup in 1.82 alpha I lost the "labels"; I use this setup in 1.80.3 (picture), in 1.82 alpha I see only the filename
You means keep your .ini? If so could send me it?
flock
Post by flock »
sorry! I misenderstood your reply... :(
anyway...
at the beginning I think the labels are not correctly imported from old xnview.ini file, now after some deep tests (also with a "fresh" installation without xnview.ini) I cannot see any labels; I see only the filename like in the picture below
goodbye :)
thanks for the promp reply
flock wrote:sorry! I misenderstood your reply... :(
anyway...
goodbye :)
In the .ini sent, you have only one label (file size), so it's normal
And now you have types of views, "Thumbnails" and "Thumbnails & Labels". (Menu item "View > View as > ...")
Locked
