Options Filter>Folders/Parent folder are not saved on exi
Locked
Dreamer
Post by Dreamer »
Options Filter > Folders / Parent folder are not saved on exit.
Only with my old ini file, not with default settings.
Dreamer
Re: Options Filter>Folders/Parent folder are not saved on
Dreamer wrote:Options Filter > Folders / Parent folder are not saved on exit.
Could you send me your .ini?
Dreamer
Post by Dreamer »
Done.
Dreamer wrote:Done.
Ok, i can reproduce it
Dreamer
Post by Dreamer »
Fixed.
Locked
