[bug] Drag'n'Drop imagefile does not work when listview is enabled
Older bugs which are supposed to be fixed in 0.84. *** Please try to reproduce your bug and confirm the bug fix. ***
Moderator: Dreamer
bul
Post by bul » Sun Dec 16, 2018 9:26 am
Hi
I just encountered an error when I tried to drag and drop a bunch of files into the input-tab of xnview 1.77:
You can choose visualization by clicking small, large and (normal) thumbnails, and also list.
If you select "list" the software does no more accept files to be draged and dropped - it does on all other views.
OS: Windows Server 2016 standard - Version 1607 (Build 14393.2665)
Microsoft Windows [Version 10.0.14393]
Ow
regards,
B
bul
Re: [bug] Drag'n'Drop imagefile does not work when listview is enabled
Post by bul » Sun Dec 16, 2018 2:20 pm
To precise the bug: It seems, that wmdropfiles property is not set for the empty listbox. The mainform and entries of the listbox are working.
But please dont mind my bugreport - at least for me, because I uninstalled xnconvert after finding out that it does not use multicore when converting in 2018. I will stay at ABIC. Inserting files is a pain but converting uses all 16 cores and is 16x faster than xnview.
regards,
bul
Post by xnview » Mon Dec 17, 2018 12:35 pm
Post by xnview » Thu Jan 31, 2019 1:50 pm
This problem is supposed to be fixed in XnView MP 0.93. Please check and confirm the bug fix here.
