Unable to paste files directly onto a disk
Octopuss
Post by Octopuss »
The paste function is greyed out if you right click on a disk (like C:, D:...), and you have to open it in order to be able to paste copied files to root folder.
Re: Unable to paste files directly onto a disk
in menu?
anonymous_user
Post by anonymous_user »
Yes the right-click menu. I noticed that the paste option works fine for a USB drive I have (labelled F:). Also the paste option is disabled for my secondary internal drive (labelled D:).
anonymous_user wrote: Sun Jan 13, 2019 5:42 pm Yes the right-click menu. I noticed that the paste option works fine for a USB drive I have (labelled F:). Also the paste option is disabled for my secondary internal drive (labelled D:).
sorry but right click menu in tree folder view? not thumbnail view
anonymous_user
Correct.
Octopuss
Post by Octopuss »
Yes, that is correct.
This problem is supposed to be fixed in XnView MP 0.94. Please check and confirm the bug fix here.
