"Single click to expand folder tree" option does not work sometimes:
- click the name to expand folder
- press [-] symbol
- click the name to expand folder again
= folder is not expanded, insted the name is selected to rename
I think also "collapse folder tree" option should be added/combined with "Single click to expand folder tree" option.
Re: "Single click to expand folder tree" option do
But is it a problem? How to rename it?Dreamer wrote:"Single click to expand folder tree" option does not work sometimes:
- press [-] symbol
But it doesn't work, folder should be expanded after I click it once but it isn't!xnview wrote:But is it a problem? How to rename it?
Is it a normal behaviour? How to rename it?Dreamer wrote:But it doesn't work, folder should be expanded after I click it once but it isn't!xnview wrote:But is it a problem? How to rename it?
When "Single click to expand folder tree" option is enabled and I click the name of folder (once) it should expand folder, but it doesn't do it = this is a bug.xnview wrote:Is it a normal behaviour? How to rename it?Dreamer wrote:But it doesn't work, folder should be expanded after I click it once but it isn't!xnview wrote:But is it a problem? How to rename it?
About rename - you can rename folder in folder tree with F2 or context menu>rename, so "1 click to rename" should be disabled if "Single click to expand folder tree" option is enabled, since it is a conflict.
