Create new folder
Octopuss
Create new folder
Post by Octopuss »
It would be nice if the default folder name was automatically highlighted after creation, because everyone renames it to something different.
Re: Create new folder
but the new folder name is already highlighted after creation
Octopuss
Post by Octopuss »
It is not. When you press F7, a folder is created and you are in the "rename" mode, but the text is not highlighted.
On the left how it currently is, on the right what I believe is the correct behaviour (that is how it works in Windows).
after pressing F7, here is what i have
Octopuss
Post by Octopuss »
What Windows are you using?
This is completely weird. Is there any setting related to this? :shock:
windows 10
Octopuss
Post by Octopuss »
I meant which version. I don't think it's related, but just in case.
I can't figure out why is it misbehaving over here :(
m.Th.
Post by m.Th. »
Win7 x64 - MP 0.93b1 x64, Dark Theme (if matters) :
It doesn't select the name of the folder. I need to press Ctrl+A for this.
EDIT: hmmm... Perhaps it matters: In View menu | View As.. is Thumbnails + Filenames.
m. Th.
Octopuss
Post by Octopuss »
I do have the view option set like that already..
m.Th.
Post by m.Th. »
Octopuss wrote: Sat Jan 26, 2019 12:03 pm I do have the view option set like that already..
So, it is a problem related to View mode.
m. Th.
Octopuss
Post by Octopuss »
I don't know.
It doesn't work even when configured like you suggested.
Octopuss wrote: Sun Feb 17, 2019 11:56 am I don't know.
could you try by renaming your xnview.ini?
Octopuss
Post by Octopuss »
It started working for whatever reason after updating to 0.93.
