Import XMP color labels
Older bugs which are supposed to be fixed in 0.84. *** Please try to reproduce your bug and confirm the bug fix. ***
Moderator: Dreamer
Post by michel038 » Mon Nov 26, 2018 5:11 pm
When reading metadata while import, XnViewMP can read xmp:label .
But it only reads values in (red, yellow,green,blue, purple)
But some other softwares use different values for this metadata. (rot, gelb, grün, blau, violett ... or anything else)
With some of these softwares, it's possible to choose to read other values ...
Could you implement a new method of import color labels, with a user defined list of equivalent values ?
This list could be added in Settings, metadata, Encoding or Labels tab ...
Related topic : viewtopic.php?f=82&t=38186
Re: Import XMP color labels
Post by xnview » Fri Nov 30, 2018 9:17 am
currently we have Settings>Metadata>Labels only used as displayed info.
Perhaps it will better to expand this setting. 'displayed label', 'write label', 'read label'
e.g.: 'Important' - 'Red' - 'Red,rot,rouge'
ruebyi
Post by ruebyi » Fri Nov 30, 2018 10:06 am
This would be great!!!
Post by michel038 » Fri Nov 30, 2018 12:11 pm
YES , tout à fait
Post by michel038 » Mon Dec 03, 2018 7:33 pm
I tried v0.93 beta version for color labels.
I tried multiple configurations, and it works fine . Great job !
Maybe a wildcard can be useful when reading unknown metadata content
(purple, later, todo, * ) , so if black, grey, orange or anything else was read, purple label will be used instead.
I also searched for the use of color labels in other software :
- XnviewMP, Lightroom, Bridge are using 5 colors R Y G B P
- Aperture , Apple photos : 7 colors, Orange and Grey are added
- Digikam 9 colors, Black and White are added
Digikam uses numeric values : Red=1, Orange=2, Yellow=3, Green= 4, Blue=5, Magenta(purple?)=6, Grey=7, Black=8, White=9.
- Photomechanic 8 colors : no black, no white but light blue and dark blue
Some months ago jadO asked for extended color labels. viewtopic.php?f=60&t=37595
I don't know if it's useful , but it seems possible, I found no restrictions in xmp docs.
Last one, Imatch, reads all labels found in metadata, but seems to use only 7 colors
ruebyi
Post by ruebyi » Mon Dec 03, 2018 9:55 pm
WOW! That's great!
May I ask where I can find the beta? I didn't find a downloadlink in the Betaforum
Post by xnview » Thu Jan 31, 2019 1:50 pm
This problem is supposed to be fixed in XnView MP 0.93. Please check and confirm the bug fix here.
fredericconsejo
Post by fredericconsejo » Sat Mar 16, 2019 1:49 pm
Did not fix the issue for me V0.93 64 bits
Post by xnview » Sun Mar 17, 2019 2:40 pm
Please explain me more your issue?
