v.0.92 random Crashes while browsing
Moderator: Dreamer
ruebyi
Post by ruebyi » Sat Nov 24, 2018 1:55 pm
I'm working on a Macbook Pro Retina 2015
512 SSD - The catalogue is on the SSD
While Browsing my folders - they are in my Catalog - XNView crashes randomly.
It's not related to a folder, a Harddisk or my NAS.
Usually it happens when switching folders, not when opening Pictures.
Today alone 7 crashes and counting...
Re: v.0.92 random Crashes while browsing
Post by xnview » Mon Nov 26, 2018 12:01 pm
do you have sent a crash report? Which format do you have in your folders?
ruebyi
Post by ruebyi » Mon Nov 26, 2018 1:33 pm
Yes, I send a crash report more than once - I hope that helps.
The folders contain ORF, DNG and JPGs
Post by xnview » Mon Nov 26, 2018 2:10 pm
I've seen your crash, it seems that the crash occurs with favorites. Please try to rename ~/.xnviewmp/bookmark.ini or move it to your desktop?
ruebyi
Post by ruebyi » Mon Nov 26, 2018 7:40 pm
Yes, it seems to work out of the Favorites Tab.
Post by xnview » Tue Nov 27, 2018 7:47 am
if you move the bookmark.ini?
ruebyi
Post by ruebyi » Tue Nov 27, 2018 10:23 am
I moved it and didn't have any problem since.
Then I copied it back and just didn't use the "Favorites" Tab and I still had no crash since then.
Post by xnview » Tue Nov 27, 2018 11:54 am
Strange, could you send me it?
thanh
Post by thanh » Mon Jan 14, 2019 4:48 am
i also have random crashes and i sent you using the same email i used to register forum. it often happen when i tried to double click on folder to go into it, it was reproduce able if use the same method double click to go to the same folder again.
if i go to folder using tree on folders or favorites tab, i can open folder and crash issue for that folder stop happening
Post by xnview » Mon Jan 14, 2019 1:26 pm
on contact at xnview dot com?
thanh
Post by thanh » Mon Jan 14, 2019 3:44 pm
no, i sent it using xnview mp built in error reporting. i added my email some time
Post by xnview » Mon Jan 14, 2019 4:37 pm
It seems that the crash occurs with bookmark (known issue)
