Shrink all images as .bat, script, batch code
OhLeut
Post by OhLeut »
I want to keep images in the folder and subfolders shrinking example 250px and aspect ratio.
The originals should remain and the changed ones are to be stored in the new folder.
All this as a script, .bat, Batch for Windows Task Scheduler
Can you help me ?
Re: Shrink all images as .bat, script, batch code
OhLeut wrote: Sat Oct 27, 2018 6:18 pm I want to keep images in the folder and subfolders shrinking example 250px and aspect ratio.
NConvert?
OhLeut
Post by OhLeut »
yes NConvert is available
OhLeut wrote: Sat Oct 27, 2018 7:21 pm yes NConvert is available
If you are familiar with working at the command line, could you download NConvert, create a help file using -help, and see if it might meet your needs. I'm not sure whether all the functions you need are supported.
Another possibility might be to use the GUI program XnConvert, if necessary launched from a batch file if that is currently supported, which I am more confident supports recursion. Sorry I can't easily give you definitive answers on these points.
