XnView 1.82 Alpha (Early test version)
*** 1.82 Beta is now available, see topic XnView 1.82 Beta ***
____________________________________________________________
an Alpha version is available to show the current progress of the new release. This version is very likely to be unstable (GPFs, unexpected behaviour, ...) and still under heavy development. So please do not report bugs, GPFs, or other problems. Later, Beta versions for beta testing and Release Candidates for final testing will be made available.
Important Notes:
+ Normal users should use the current Final version of XnView, which is version 1.80.3. Please see topic XnView 1.80.3 for details.
+ Download portals and websites must link to final versions of XnView only, and in no case link to this Alpha version.
Download & Feedback
XnView 1.82 Alpha is available here.
I'd be happy to get feedback on the new functionality that has been added, best is to place your feedback in the appropriate topic (if available) or start a new topic.
Not all features suggested have made it into the new release. Reason are limited resources, please understand. As written above please do not report bugs or problems.
Changes in XnView 1.82 alpha are:
* Camera RAW : full size, half size, ...
* Send by Email
* Added new view "Thumbnails & Labels"
* Adjust dialog => Hide preview
* batch rename: change <folder> to last folder not full pathname
* Thumbnails for folder
* Thumbnail for text file
* IPTC edit add "Time Created" and "Release Time"
* IPTC edit add "exif date taken, date digitized", System creation date/last modification data
* Support EXIF camera RAW
* Edit metadata/export in browser
* Rotation anti alias + background color
* DeSkew : http://www.catenary.com/howto/deskew.html http://www.recogniform.com/deskew.htm
* In "change timestamp", add/substract date/time from exif date
* Browser: change page from a multipage file
* Batch rename duplicate : http://newsgroup.xnview.com/viewtopic.php?p=16998
* http://newsgroup.xnview.com/viewtopic.php?t=2829 solution A
hidden ini : OpenWithAssociatedProgram, OpenWithXnView, OpenNone
* option resize convert to make resize based on original orientation
* Added Hanning filter to resize
* http://newsgroup.xnview.com/viewtopic.php?t=3610
Write/File Type : most used to the top
* Set jpeg lossless comment, comment <=> iptc caption
* Lossless clean : remove exif, iptc, thumb, ...
* added convert in 32bits
* PDF export
* BLP format http://wowmapview.sourceforge.net/wiki/index.php/BLP
* Sort by EXIF date (browser & batch rename)
* Ignore extensions (separated by space) (e.g., PDF EPS PS EPSF)
* http://newsgroup.xnview.com/viewtopic.php?p=18190 history of convert script
* 'Name (Numeric)' in batch rename & web page
* Options, Switching modes => MiddleButton: Nothing
* Options, Thumbnail appearance => Show filename in thumbnail view
* Option "Auto colapse last used folder"
* Option Options/Browser/Filelist/ ".."
* date template is "Y-m-d_H-M-S" by default
* In Batch Rename, "Case" operation should be the last, currently it's before "Replace/With"
* Option SPACE => quickslide or dir next
* Various bug fixes - a list will be provided with 1.82 Beta
Thank you,
Important Notes:
Download & Feedback
* Send by Email
* PDF export
Thank you,
Re: XnView 1.82 alpha
About Option/Browser/Filter & File list
In this version "File List/Items shown in thumbnail/other mode" is no more used.
And Filter is not the final version. I think that this panel is not good, too many checkbox.
And you can see that i use "Exclude list", i've tried many different choice.
And Include or Exclude are difficult to understand. Exclude list is better because by default Images shown PDF files, so it's easy to exlude PDF/EPS files. But it's not consistent with other checkbox.
wonderful
I know this is not the correct place, but can I suggest somethig?
the bicubic rotation to avoid aliasing in rotated images
in this page there is a very interesting pdf about it:
http://groups.google.com/group/comp.gra ... rt=2&num=3
thanks for XnView!!
thanks for XnView!!
Pierre... "You are my personal savior, you and my man Jesus Christ."
Sorry, but where I can find this?
Oh yeah. Thanks.xnview wrote:In the browser, menu Edit/metadata
I've just downloaded the ZIP archive and it worked fine. Please try again, perhaps a corrupted download.robc wrote:Just to let everybody know... the link for the Alpha version in the first post saves a corrupt zip, or is it just me?
XnView 1.82 Alpha is a single program file which you save in any directory and start. You could have even two program files (with different file names) located in the same directory, but I do not recommend this since both programs will use the same xnview.ini files and you might "spoil" your settings.robc wrote:A question, also, should I succeed in getting the alpha: does it work alongside 1.80.3 or not? I'm especially talking about the catalog cache.
And better---
Helmut wrote
• Yes, right. It's the minimal precaution to take…XnView 1.82 Alpha is a single program file which you save in any directory and start…
• Moreover, in addition I would recommend -if possible- to install the Alpha in a directory set in another drive where not any XnView folder exists formerly.
- This should avoid to get the same Favourite Folders than the normal current version, whether you install the Alpha in the same drive, even in a quite different directory. I noticed that inconvenience already here (§ 2.) and expressed a wish for an improvement… “Strike while the iron is hot”
