severe batch convert bug
Older bugs which are supposed to be fixed in 0.84. *** Please try to reproduce your bug and confirm the bug fix. ***
Moderator: Dreamer
toyotadesigner
Post by toyotadesigner » Wed Oct 17, 2018 12:20 pm
OS X 10.11.6 (15G31) El Capitan
Xn View MP 0.92
I have set up a process to convert JPEG images of a size of 1.500 x 1.000 pixels to a size of 660 x 440 pixels.
Set the 'Output Folder' to 'Source Folder'.
Saved this as 'blog.xbs'.
Now I open 'Batch Convert', select the 'blog.xbs', and the 'Source Folder' is no longer selected, but some weird folder:
No matter what I do, 'Batch Convert' always uses the weird folder instead of the 'Source Folder'
If I don't check all settings, my converted images end up somewhere, but never in the 'Source Folder'.
Would you please be so kind an correct this annoying bug?
hobbyists discuss new camera features
photographers discuss new software
masters discuss light
Re: severe batch convert bug
Post by xnview » Fri Oct 19, 2018 1:17 pm
could you send the blog.xbs?
toyotadesigner
Post by toyotadesigner » Sat Oct 20, 2018 12:32 pm
I try to post it here.
blog.xbs.zip
(577 Bytes) Downloaded 31 times
Post by xnview » Mon Oct 22, 2018 8:20 am
the pathname in 'Folder' is an old used folder, it's not in the .xbs
But the bug is that 'source folder' should be selected
toyotadesigner
Post by toyotadesigner » Wed Oct 24, 2018 4:55 am
I restarted Xnview.
I deleted all *.xbs files
I recreated the action
I selected 'Folder'
I saved the action
Problem is still there. Something must be stored somewhere in the programm, but I don't know where.
When I edit the *.xbs file with BBEDIT and remove in the line '<Output ' the element 'folder="" ', everything is ok.
Post by xnview » Wed Oct 24, 2018 6:45 am
it's saved in ~/.config/xnview/xnview.ini
toyotadesigner
Post by toyotadesigner » Wed Oct 24, 2018 8:55 pm
Pierre,
I've edited the xnview.ini - now everything seems to be perfect.
There were two paths to folders in History= which I deleted.
In the folder I've found a hidden .xnviewmp folder. I moved it to the desktop and restarted xnview - it still works. So it seems that the hidden folder is not needed any longer (from a previous version?).
Post by xnview » Thu Jan 31, 2019 1:52 pm
This problem is supposed to be fixed in XnView MP 0.93. Please check and confirm the bug fix here.
