NConvert 7.00 - Bug when output filename contains a numeric enumerator
NConvert 7.00 introduced a bug when the numeric enumerator # is used in an output filename.
In the code below, which outputs renumbered copies of four files in a folder Test:
Expected result: output files numbered 001 002 003 004
Actual result: output files numbered 003 004 005 006
D:\Desktop\Test>nconvert_7.00  -o ### Test\*.*
** NCONVERT v7.00 (c) 1991-2017 Pierre-E Gougelet (Apr 18 2017/09:49:26) **
        Version for Windows NT/9x/2000/Xp/Vista/7  (All rights reserved)
** This is freeware software (for non-commercial use)
  Error: Can't open file (D:\Desktop\Test\Test)
  Error: Can't open file (D:\Desktop\Test)
Conversion of D:\Desktop\Test\Test\1.png into 003.png OK
Conversion of D:\Desktop\Test\Test\2.png into 004.png OK
Conversion of D:\Desktop\Test\Test\3.png into 005.png OK
Conversion of D:\Desktop\Test\Test\4.png into 006.png OK
NConvert 6.93 outputs the expected result.
Re: NConvert 7.00 - Bug when output filename contains a numeric enumerator
you have only 4 files in Test folder? I can't reproduce
xnview wrote: Mon Oct 22, 2018 8:41 am you have only 4 files in Test folder? I can't reproduce
Yes, but with more files the enumeration has the same offset...
The terminal output with NConvert 6.93 is as follows:
D:\Desktop\Test - Copy>nconvert_6.93  -o ### Test\*.*
** NCONVERT v6.93 (c) 1991-2016 Pierre-E Gougelet (Oct 11 2016/20:18:09) **
Conversion of Test\1.png into 001.png OK
Conversion of Test\2.png into 002.png OK
Conversion of Test\3.png into 003.png OK
Conversion of Test\4.png into 004.png OK
But with NConvert 7.00 the output is as follows:
From the terminal output, it seems that NConvert 7.00 is trying to open folders that it shouldn't be opening, and incrementing the enumeration index once for each.
Something changed between 6.93 and 7.00...
I'll email you a ZIP containing my test setup as it is just too large to attach, please confirm safe arrival in case of an email security issue. :D
will be fixed
