Extension of "descript.ion"
Moderators: XnTriq, xnview
rrs
Post by rrs » Fri Oct 05, 2018 9:31 am
I use the "descript.ion" file to store basic information about images. Usually I modify it manually before archiving (store on external media) to add some information about directory or group of images. Unfortunately this additions are lost when file is changed by xnview.
I think that option "keep info about not existing files in descript,ion" should be useful.
Some examples of my descript.ion extension:
"." Album or directory information (i.e. "My family on holidays") - The "." means "current directory", so this is a good place to store global information,
"" Note (i.e. "Taken 2018-08-14 to 2008-09-02") - "Unnamed file" used as a note line,
IMG_39816.JPG Image info (i.e. "Sea and sun") - Standard description.
This is pretty compatible, because information about not-existing files is ignored by default.
Re: Extension of "descript.ion"
Post by xnview » Mon Oct 08, 2018 8:20 am
could you send me an extended descript.ion
