[MP 091 092] Canvas-Resize Presets do not work
quapurna
Post by quapurna »
Halo.
I have tried the "Windows x64 ZIP" of 091 and 092 versions.
For both, the Canvas Resize does not work for my created presets; the newly made and the ones from previous version (MP 0.90).
Do you experience the same problem?
Thanks
Re: [MP 091 092] Canvas-Resize Presets do not work
could you post a screenshot of preset?
quapurna
Post by quapurna »
This is the canvas preset on 090 version which works properly:
And the following is the same canvas preset on 092 version which does not work. The values have been changed; I do not know why.
Thank you,
quapurna
Post by quapurna »
Pierre,
I forgot to mention that the feature "Image Resize" also has the same issue (the change of preset values).
Thank you for fixing the bug.
I've sent you a PM
quapurna
Post by quapurna »
Pierre,
XnviewMP beta 093 still has the problem.
The original image is 300x300 and I want to resize the canvas to 600x300
(double the width, make the added space white, put the original part to the right side).
Without saving the configuration to a preset, It works.
However, it does not work if I try saving the preset.
Right after I enter the name of the preset and click OK button, the configuration is changed.
Thank you.
quapurna wrote: Thu Jan 24, 2019 10:10 pm XnviewMP beta 093 still has the problem.
I've sent you a PM
