XnView MP 0.91
XnView MP 0.91
Please, don't post bugs or request in this topic!
You can download XnView MP 0.91 here:
Windows x32 ZIP version: http://download.xnview.com/XnViewMP-win.zip
Windows x32 SETUP version: http://download.xnview.com/XnViewMP-win.exe
  • SHA256: D3B9DAAD911290699EAFC0905C0CE7AEA71804681613FC646AC74BCB1C77F682
Windows x64 ZIP version: http://download.xnview.com/XnViewMP-win-x64.zip
Windows x64 SETUP version: http://download.xnview.com/XnViewMP-win-x64.exe
  • SHA256: A63C449DC77F8DA6009942D08380E2156D141F88FD4C66DAABBFC289769A6CBC
For Windows 7 and older, you have to install the driver from DirectX to run correctly QtAV (audio/video)
Mac x64 TGZ version: http://download.xnview.com/XnViewMP-mac.tgz
Mac x64 DMG version: http://download.xnview.com/XnViewMP-mac.dmg
Linux TGZ version: http://download.xnview.com/XnViewMP-linux.tgz
Linux DEB version: http://download.xnview.com/XnViewMP-linux.deb
Linux x64 TGZ version: http://download.xnview.com/XnViewMP-linux-x64.tgz
Linux x64 DEB version: http://download.xnview.com/XnViewMP-linux-x64.deb
Linux x64 AppImages version: http://download.xnview.com/XnView_MP-0. ... 4.AppImage
Changelog 0.91:
1487: [New] PDF v1.4 output
1486: [New] Sqlite 2.24.0
1482: [New] Audio with slideshow - viewtopic.php?f=60&t=37463
1387: [New] Ratio field - viewtopic.php?f=60&t=37204
1384: [New] Batch convert: Back color added to convert 32bits into 24bits - viewtopic.php?f=110&t=37147
1391: [New] Autocomplete in copy/move dialog - viewtopic.php?f=110&t=37257
1478: [New] Join: Fit width or height
1475: [New] Batch resize by width or height - viewtopic.php?f=60&t=36864
1471: [New] PackJPG format (read)
1470: [New] Lepton format (read) added
1467: [New] Companion files handling - viewtopic.php?f=95&t=35508
1465: [New] HPI alpha channel supported
1464: [New] Custom title bar in browse mode - viewtopic.php?f=82&t=37446
1457: [New] Change timestamp: Increment at each file - viewtopic.php?f=82&t=37416
1456: [New] Edit colormap - viewtopic.php?f=95&t=37217
1452: [New] QtAV used on Linux/Mac for video playing/thumbnailing
1454: [New] Message before to quit - viewtopic.php?f=82&t=37380
1447: [New] More options for RAW
1439: [New] KRITA support - viewtopic.php?f=60&t=33385
1433: [New] 'Use Alpha channel' not remembered - viewtopic.php?f=95&t=34644
1432: [New] Search: Select pathname field - viewtopic.php?f=95&t=37086
1441: [New] Tooltips when drawing selection - viewtopic.php?f=60&t=37259
1427: [New] Recent quick search list - viewtopic.php?f=95&t=37201
1425: [New] Resize dialog - viewtopic.php?f=95&t=36772
1409: [New] Relative path in .sld - viewtopic.php?f=62&t=37181
1406: [New] Information for Audio/Video file - viewtopic.php?f=95&t=35843
1405: [New] Sharpen in Resize dialog
1404: [New] Autoskew in edit mode
1400: [New] IPTC dialog in view mode - viewtopic.php?f=60&t=34630
1399: [New] Setting to create descript.ion in UTF8
1493: [Bug] ICC support in compare - viewtopic.php?f=62&t=37808
1492: [Bug] JPEG2000 YCC - viewtopic.php?f=35&t=37806
1491: [Bug] Load & save image with ICC profile doesn't change icc (sRGB) - viewtopic.php?f=62&t=37755
1490: [Bug] 'Crop, save & next' doesn't always save cropped image - viewtopic.php?f=82&t=37730
1489: [Bug] Batch convert- automatic crop - viewtopic.php?f=79&t=37782
1488: [Bug] When catalog is not used, can't save search
1485: [Bug] Save 32bits as jpeg - viewtopic.php?f=62&t=37638
1484: [Bug] Crash with 1x1 png - Thanks to Martin Orem of Binary House
1483: [Bug] TIFF with JPEG compression - viewtopic.php?f=35&t=37585
1481: [Bug] IPTC Edit: Object name not always modified on RAW - viewtopic.php?f=83&t=37441
1480: [Bug] Deselecting by CTRL key - viewtopic.php?f=62&t=37486
1479: [Bug] Batch convert: Problem when filename has $ character
1477: [Bug] Embedded comment always written in utf8 - viewtopic.php?f=62&t=37497
1476: [Bug] Batch convert: if 'delete original', steals focus - viewtopic.php?f=79&t=37328
1474: [Bug] Batch Rename: First item no more selected - viewtopic.php?f=62&t=37297
1473: [Bug] Dialog Edit curves: curve not visible if preview enabled - viewtopic.php?f=62&t=37487
1472: [Bug] Crop unavailable until change crop area manually - viewtopic.php?f=82&t=37461
1469: [Bug] Export: wepb quality widget too small - viewtopic.php?f=62&t=37482
1468: [Bug] Slow when entering on a folder with a lot of files (icon create)
1466: [Bug] Characters problem with exif label in view informations - viewtopic.php?f=83&t=37459
1463: [Bug] Edit IPTC: no hierarchicalSubject written for RAW - viewtopic.php?f=83&t=37441
1462: [Bug] Edit IPTC: EXIF:artist modified on RAW file - viewtopic.php?f=83&t=37441
1461: [Bug] Long full path on windows 10 - viewtopic.php?f=95&t=36108
1460: [Bug] Batch Convert: Hot folder, files not completly written, can't be readed - viewtopic.php?f=79&t=3743
1459: [Bug] Error reading panorama image from S9 - viewtopic.php?f=62&t=37427
1458: [Bug] Rounded value in batch resize - viewtopic.php?f=36&t=37451
1455: [Bug] Filesize in Info not changed after save - viewtopic.php?f=62&t=37319
1453: [Bug] Video thumbnail not correctly build by QtAv
1451: [Bug] Open image tab while in fullscreen on second monitor - viewtopic.php?f=62&t=35028
1450: [Bug] PDF output on Linux - viewtopic.php?f=82&t=37376
1449: [Bug] Batch convert: Preview 'after' not always loaded - viewtopic.php?f=62&t=37377
1448: [Bug] All details on info pane are missing while Fullscreen preview is active - viewtopic.php?f=95&t=3658
1446: [Bug] Join: Collage on non image files
1445: [Bug] Batch Convert: ESC before end of process
1444: [Bug] Grid settings are not saved - viewtopic.php?f=62&t=37363
1443: [Bug] When selecting file without thumbnail, should create this one first - viewtopic.php?f=95&t=36704
1442: [Bug] Folders in folder tree are expanded - viewtopic.php?f=62&t=36808
1440: [Bug] Webm support
1438: [Bug] Excluding folders in Catalog & copy files - viewtopic.php?f=95&t=36635
1437: [Bug] Batch Convert: Hot folders & subdirectories - viewtopic.php?f=82&t=37338
1436: [Bug] Included/excluded folder list - double entries possible - viewtopic.php?f=62&t=37345
1435: [Bug] Slideshow order is not being restored on opening an .sld - viewtopic.php?f=62&t=37360
1434: [Bug] Thumbnail and Image Orientation out of sync after Jpeg Lossless Rotate - viewtopic.php?f=95&t=36687
1431: [Bug] Compare: thumbnails view size - viewtopic.php?f=95&t=36954
1430: [Bug] EXIF Image width/height is not updated - viewtopic.php?f=95&t=36625
1429: [Bug] Move shortcut of file - viewtopic.php?f=95&t=36971
1428: [Bug] Name collision dialog uses old name on renaming - viewtopic.php?f=95&t=37084
1426: [Bug] Ctrl+Right Click does not select the image - viewtopic.php?f=95&t=36951
1424: [Bug] Wheel on preview change focus - viewtopic.php?f=95&t=36767
1423: [Bug] Ctrl+Right Click unselects the image in detail view - viewtopic.php?f=95&t=36950
1422: [Bug] Selection must be restored after undo - viewtopic.php?f=95&t=37102
1421: [Bug] Rating/Label on folder always cleared - viewtopic.php?f=95&t=37269
1420: [Bug] Selection with the keyboard controls is inconsistent - viewtopic.php?f=95&t=34297
1419: [Bug] Duplicate video playback - viewtopic.php?f=95&t=35953
1418: [Bug] Not responsive while opening image file - viewtopic.php?f=95&t=35057
1417: [Bug] Wrong focus after returning from image tab - viewtopic.php?f=95&t=35964
1416: [Bug] Image navigation pane shown on animated GIF - viewtopic.php?f=95&t=36012
1415: [Bug] MacOSX: copy instead of move on same partition - viewtopic.php?f=95&t=35754
1414: [Bug] Fixed ratio for selection and horizontal handler - viewtopic.php?f=95&t=36457
1413: [Bug] PDF when viewing are not skipped if ghosctscript is not installed - viewtopic.php?f=95&t=35338
1412: [Bug] Batch Convert: Delete original always use recycle bin - viewtopic.php?f=95&t=37132
1411: [Bug] Thumbnail ratio - viewtopic.php?f=95&t=33725
1410: [Bug] Batch Rename not possible on Movie - viewtopic.php?f=95&t=35923
1401: [Bug] Modified date for OpenXML format changed when creating thumbnail - viewtopic.php?f=62&t=37344
1408: [Bug] Keys in slideshow - viewtopic.php?f=62&t=37181
1407: [Bug] Favorites not sorted after adding one - viewtopic.php?f=95&t=37092
1403: [Bug] Batch Rename: 'always added' not saved - viewtopic.php?f=60&t=37332
1402: [Bug] Wrong thumbnail from catalog - viewtopic.php?f=82&t=33548
1398: [Bug] Slow search on annotations - viewtopic.php?f=82&t=37295
1397: [Bug] Annotation doesn't work, in slideshow - viewtopic.php?f=82&t=37300
1396: [Bug] Freeze when clicking on .url - viewtopic.php?f=62&t=37289
1395: [Bug] Windows default context menu use only 1 file - viewtopic.php?f=82&t=37287
1394: [Bug] Export resize for NConvert - viewtopic.php?f=79&t=37278
1393: [Bug] Thumbnail process on big files can't be interrupted - viewtopic.php?f=110&t=37182
1390: [Bug] Cancel 'Edit Favorites path' - viewtopic.php?f=62&t=37100
1389: [Bug] Print: Incorrect caption in picture collection - viewtopic.php?f=62&t=37274
1388: [Bug] Directory locked after batch convert - viewtopic.php?f=62&t=37242
1386: [Bug] Batch convert: keep folder and folder at root path
1385: [Bug] Paint: b&w, 8bits colormap are converted with bad colors
1383: [Bug] Batch convert: ICC convert doesn't work on 64bits version - viewtopic.php?f=79&t=37176
1382: [Bug] Batch convert: extension is not changed - viewtopic.php?f=79&t=37165
1381: [Bug] Image with alpha channel converted in JPEG - viewtopic.php?f=82&t=37147
DanPF
Re: XnView MP 0.91
Post by DanPF »
I did an install to upgrade to 0.91 and the app will not run. From terminal I get the following "libQtAVWidgets.so.1" cannot be found. Versions before 0.91 all ran perfectly. [Mint Cinnamon 19.0]
DanPF
Re: XnView MP 0.91
Post by DanPF »
I seem to have solved the issue by installing libQtAVWidgets from synaptic (I am using Mint Cinnamon 19.0).
mark13
Re: XnView MP 0.91
Post by mark13 »
DanPF wrote: Tue Sep 11, 2018 4:13 pm I seem to have solved the issue by installing libQtAVWidgets from synaptic (I am using Mint Cinnamon 19.0).
Same problem here, solved installing libQtAVWidgets. I'm using Ubuntu 18.04.
osiris2258
Re: XnView MP 0.91
Post by osiris2258 »
Does this version finally add proper support for viewing zips, rars, cbrs, and cbzs as folders with proper navigation?
viewtopic.php?f=60&t=29736&p=151837#p151837
Re: XnView MP 0.91
please re-download the package... i've updated it.
claudec
Re: XnView MP 0.91
Post by claudec »
Hello Pierre,
I confirm issue on Mint 19.
First version give:
/opt/XnView/XnView: error while loading shared libraries: libQtAVWidgets.so.1: cannot open shared object file: No such file or directory
I have tested second version and I get
/opt/XnView/XnView: error while loading shared libraries: libva.so.1: cannot open shared object file: No such file or directory
Kind regards.
megabis
Re: XnView MP 0.91
Post by megabis »
Hi community,
I upgraded to 0.91 and the app does not run. Versions before 0.91 all ran perfectly.
On Terminal command showed this error :
I tried to install libva2 but not have sold the issue (already installed in case)
Work with Ubuntu 18.04 64 bits
Any ideas ?
Thank you
Regards
stefanxnv
Re: XnView MP 0.91
Post by stefanxnv »
Hi Pierre,
thanks a lot for the quick update.
Now in Debian stretch 64bit it works without problems (package Linux TGZ 64bit).
kgha
Re: XnView MP 0.91
Post by kgha »
megabis wrote: Wed Sep 12, 2018 4:01 pm Hi community,
Any ideas ?
Thank you
Regards
Apparently XnView expects an older libva version (odd). The obvious, quick and dirty solution: create a symlink (actually three symlinks).
ln -s /[folder]/libva.so.2.200.0 /[samefolder]/libva.so.1
[folder] might differ depending on your install. In my case it's /usr/lib64/
Then do the same for libva-drm.so.2.200.0 and libva-x11.so.2.200.0
dietmar
Re: XnView MP 0.91
Post by dietmar »
xnview wrote: Tue Sep 11, 2018 1:59 pm Linux TGZ version: http://download.xnview.com/XnViewMP-linux.tgz
Hi Pierre,
sorry to complain again about the missing 32-bit version for Linux.
I understand (though do not agree) that you don't want to build a 32-bit version if only few people (like me) use it. However, it's a bad trick if 0.89 (32-bit) proudly tells that a new version is available for download and that the website offers a 32-bit version to download - only to find after download that the version you just downloaded is still 0.89.
Kind regards
Dietmar
x230w
Re: XnView MP 0.91
Post by x230w »
Does not work with Mint 18.3 x64 (Ubuntu 16.04 x64).
Displays a message that
/opt/XnView/XnView: error while loading shared libraries: libva-drm.so.1: cannot open shared object file: No such file or directory
Used Link: https://download.xnview.com/XnViewMP-linux-x64.deb
megabis
Re: XnView MP 0.91
Post by megabis »
Hi Community,
Thanx kgha.
followsymlink(s) works fine !
To close issue of libva librairy dependancy We must add few symbolic links :
ln -s /usr/lib/x86_64-linux-gnu/libva.so.2.100.0 /usr/lib/x86_64-linux-gnu/libva.so.1
ln -s /usr/lib/x86_64-linux-gnu/libva-drm.so.2.100.0 /usr/lib/x86_64-linux-gnu/libva-drm.so.1
ln -s /usr/lib/x86_64-linux-gnu/libva-x11.so.2.100.0 /usr/lib/x86_64-linux-gnu/libva-x11.so.1
works fine with Ubuntu 18.04 64bits
thank a lot
DanPF
Re: XnView MP 0.91
Post by DanPF »
xnview wrote: Wed Sep 12, 2018 1:57 pm
I did. And that has now broken the installation again. I tried the linking method below and that wont work either. I will try to regress to previous version
eptefal
Re: XnView MP 0.91
Post by eptefal »
Well, actually it does nothing on win10. (it starts as a program, but not as file association). If I click on a file it starts a progress bar for a sec, but after nothing.
Where can I find some logs to report?
