No Exif Date In Details Column View...
Katamara
Post by Katamara »
Hello.
System;
Linux Mint Cinnamon 18.3
XnViewMP v.0.90
Reference image;
https://biz.kwamsook.com/ImageMagick/02 ... 0x1200.jpg
Testing with: exiftool v.10.10
Issue;
No EXIF Date Displayed in Detail view, column "Exif Date".
Test Command;
$ exiftool -time:all -a -G0:1 -s 02599_hiltonborabora_1600x1200.jpg
Result;
[File:System]             FileModifyDate       :  2018:08:30  12:08:47-07:00
[File:System]             FileAccessDate       :  2018:08:30  12:09:37-07:00
[File:System]             FileInodeChangeDate  :  2018:08:30  12:08:47-07:00
[XMP:XMP-xmp]             ModifyDate           :  2011:05:29  18:05:15+10:00
[XMP:XMP-xmp]             CreateDate           :  2010:11:13  17:08:54
[XMP:XMP-xmp]             MetadataDate         :  2011:05:29  18:05:15+10:00
[XMP:XMP-photoshop]       DateCreated          :  2010:11:13
[XMP:XMP-exif]            DateTimeOriginal     :  2010:11:13  17:08:54-05:00
[XMP:XMP-exif]            DateTimeDigitized    :  2010:11:13  17:08:54-05:00
[XMP:XMP-xmpMM]           HistoryWhen          :  2011:05:29  18:05:15+10:00,  2011:05:29  18:05:15+10:00
[ICC_Profile:ICC-header]  ProfileDateTime      :  1998:02:09  06:49:00
Question;
The "Details view" (Column "Exif Date") is empty, but there are other metadata date fields available above.
* Which metadata information is used to obtain the date listed in the "Exif Date" column in the data view ?
Thank you.
Re: No Exif Date In Details Column View...
ok, currently only EXIF date are shown, not XMP
Katamara
Post by Katamara »
Thank you Pierre.
May I ask which EXIF tag will always be used, there are more than 1 ?
For example, using another Sony Raw Image file...
$ exiftool -time:all -a -G0:1 -s DSC00333.ARW
Result;
[File:System]   FileModifyDate                  : 2018:08:23 12:19:38-07:00
[File:System]   FileAccessDate                  : 2018:08:30 14:36:02-07:00
[File:System]   FileInodeChangeDate             : 2018:08:28 01:08:06-07:00
[EXIF:IFD0]     ModifyDate                      : 2016:06:12 18:35:14
[EXIF:ExifIFD]  DateTimeOriginal                : 2016:06:12 18:35:14
[EXIF:ExifIFD]  CreateDate                      : 2016:06:12 18:35:14
[MakerNotes:Sony] SonyDateTime                  : 2016:06:12 18:35:14
[MakerNotes:Sony] SonyDateTime2                 : 2016:06:13 02:35:14
[EXIF:IFD1]     ModifyDate                      : 2016:06:12 18:35:14
Which of the exif dates will be used ?
Thank you Pierre.
Best regards.
Katamara
Post by Katamara »
This Thread Was Incorrectly Posted To This Forum. May It Please Be Moved To General XnViewMP Help ? Thank You.
continued...
Katamara
Post by Katamara »
Also...
If there are Multiple EXIF dates, available, will XnViewMP cycle through them until it finds one ?
I think XnViewMP uses 'DateTimeOriginal', but I'm not 100 percent sure.
Thank you for your assistance.
Katamara
Post by Katamara »
I'll repost in the correct forum.
Cheers.
Moderator & Librarian
Katamara wrote: Sun Sep 02, 2018 12:14 pm--------------------------------------------------------------------------------------------------------------------------------------------------------
continued...
Sorry, Katamara, I've been asleep at the wheel. As requested, I've now moved the topic to the “General Support” section of the MP forum.
Katamara
Post by Katamara »
Thank you for moving this post to the correct forum.
Continuing...
If there are Multiple EXIF dates available in an image,
will XnViewMP cycle through them until it finds one...,
or does XnViewMP use 'DateTimeOriginal' ?
Best regards
