Browse only images filtered using the search field
postcd
Post by postcd »
Hello, the XNView MP 0.90 has in its default state a quick search field which can filter out matching file in current directory.
I would welcome if i can somehow include subdirectories.
But even more if i can browse (viewing one by one in the full screen) only these fitlered images, but apparently when i select all and right click and click open it opens one image and when i do right arrow it shows other non filtered image. I want to browse only filtered/selected ones..
Linux user, .deb package. Use private services like Proton.me, not surveillance services like Google, Meta.
Benrasi
Re: Browse only images filtered using the search field
Post by Benrasi »
+1
I also found it not logic to browse in view mode through all pictures instead only the filtered list.
Post by michel038 »
Right ...
But you can use F11 (= full screen) on the first one, and use arrows at the bottom of the screen.
If you move your mouse to the top, there is a ribbon
On the right side, properties displayed
Esc to close
if you select some files in browser mode, and use 'Open', you can cycle between this file list
