Colour label icons larger
RoyAndrews
Post by RoyAndrews »
I love this XnviewMP software package and I only have one query about it.
Is it possible to make the colour label icons larger or better still make the text background in the thumbnail the same colour as the label,
as in what I use in Adobe Bridge, regards, Roy Andrews
Re: Colour label icons larger
so the possibility to add a label based on 'Colour label' below thumbnails?
RoyAndrews
Thanks for your response Pierre.
Yes would be great if the background colour that is behind the thumbnail could be the "colour label" colour, or the colour behind the "file name" in the thumbnail could be the "colour label" colour,
regards, Roy
no i means add a new field below/above filename
RoyAndrews
Yes that'd be great , below the thumbnail, regards,
Roy
This problem is supposed to be fixed in XnView MP 0.98.0. Please check and confirm the bug fix here.
Korben
Post by Korben »
Is it possible to set just Color label field, without Rating instead of "Rating + Color Label"? I have tried type in Custom Field: {Color Label}, but it doesn't work. Or maybe I can hide stars indicator under thumbnail, for files that doesn't have ratings, somehow?
Korben wrote: Mon Jul 05, 2021 8:23 am Is it possible to set just Color label field, without Rating instead of "Rating + Color Label"? I have tried type in Custom Field: {Color Label}, but it doesn't work. Or maybe I can hide stars indicator under thumbnail, for files that doesn't have ratings, somehow?
yes perhaps it's better to hide rating if there is no rating...?
Korben
Post by Korben »
xnview wrote: Mon Jul 05, 2021 12:26 pm
I think it's more intuitive and less distracted, if stars showing only on files with rating greater then 0.
Korben wrote: Mon Jul 05, 2021 1:41 pm
ok, will be changed in next release...
