XnView MP 0.91 beta 4
**** Please do not post bugs or requests in this topic!
**** In this new test version 0.91 beta 4 various bugs have been fixed. All reported bugs that aren't listed in the changelog below will be fixed in a later release. Please do not re-report a bug which wasn't fixed yet.
XnView 0.91 beta 4 is available for beta testing. You can download XnView MP 0.91 beta 3 here:
Windows x64 ZIP version: http://www.xnview.com/beta/XnViewMP-win-x64-beta4.zip
MacOSX TGZ version: http://www.xnview.com/beta/XnViewMP-mac-beta4.tgz
If you have reported one or several bugs listed below, we'd kindly ask you to check with the latest version whether the bug really has been fixed and confirm this with a short note in the specific topic with the bug report.
Thank you for your help!
Changelog 0.91:
1482: [New] Audio with slideshow - viewtopic.php?f=60&t=37463
1387: [New] Ratio field - viewtopic.php?f=60&t=37204
1384: [New] Batch convert: Back color added to convert 32bits into 24bits - viewtopic.php?f=110&t=37147
1391: [New] Autocomplete in copy/move dialog - viewtopic.php?f=110&t=37257
1478: [New] Join: Fit width or height
1475: [New] Batch resize by width or height - viewtopic.php?f=60&t=36864
1471: [New] PackJPG format (read)
1470: [New] Lepton format (read) added
1467: [New] Companion files handling - viewtopic.php?f=95&t=35508
1465: [New] HPI alpha channel supported
1464: [New] Custom title bar in browse mode - viewtopic.php?f=82&t=37446
1457: [New] Change timestamp: Increment at each file - viewtopic.php?f=82&t=37416
1456: [New] Edit colormap - viewtopic.php?f=95&t=37217
1452: [New] QtAV used on Linux/Mac for video playing/thumbnailing
1454: [New] Message before to quit - viewtopic.php?f=82&t=37380
1447: [New] More options for RAW
1439: [New] KRITA support - viewtopic.php?f=60&t=33385
1433: [New] 'Use Alpha channel' not remembered - viewtopic.php?f=95&t=34644
1432: [New] Search: Select pathname field - viewtopic.php?f=95&t=37086
1441: [New] Tooltips when drawing selection - viewtopic.php?f=60&t=37259
1427: [New] Recent quick search list - viewtopic.php?f=95&t=37201
1425: [New] Resize dialog - viewtopic.php?f=95&t=36772
1409: [New] Relative path in .sld - viewtopic.php?f=62&t=37181
1406: [New] Information for Audio/Video file - viewtopic.php?f=95&t=35843
1405: [New] Sharpen in Resize dialog
1404: [New] Autoskew in edit mode
1400: [New] IPTC dialog in view mode - viewtopic.php?f=60&t=34630
1399: [New] Setting to create descript.ion in UTF8
1481: [Bug] IPTC Edit: Object name not always modified on RAW - viewtopic.php?f=83&t=37441
1480: [Bug] Deselecting by CTRL key - viewtopic.php?f=62&t=37486
1479: [Bug] Batch convert: Problem when filename has $ character
1477: [Bug] Embedded comment always written in utf8 - viewtopic.php?f=62&t=37497
1476: [Bug] Batch convert: if 'delete original', steals focus - viewtopic.php?f=79&t=37328
1474: [Bug] Batch Rename: First item no more selected - viewtopic.php?f=62&t=37297
1473: [Bug] Dialog Edit curves: curve not visible if preview enabled - viewtopic.php?f=62&t=37487
1472: [Bug] Crop unavailable until change crop area manually - viewtopic.php?f=82&t=37461
1469: [Bug] Export: wepb quality widget too small - viewtopic.php?f=62&t=37482
1468: [Bug] Slow when entering on a folder with a lot of files (icon create)
1466: [Bug] Characters problem with exif label in view informations - viewtopic.php?f=83&t=37459
1463: [Bug] Edit IPTC: no hierarchicalSubject written for RAW - viewtopic.php?f=83&t=37441
1462: [Bug] Edit IPTC: EXIF:artist modified on RAW file - viewtopic.php?f=83&t=37441
1461: [Bug] Long full path on windows 10 - viewtopic.php?f=95&t=36108
1460: [Bug] Batch Convert: Hot folder, files not completly written, can't be readed - viewtopic.php?f=79&t=3743
1459: [Bug] Error reading panorama image from S9 - viewtopic.php?f=62&t=37427
1458: [Bug] Rounded value in batch resize - viewtopic.php?f=36&t=37451
1455: [Bug] Filesize in Info not changed after save - viewtopic.php?f=62&t=37319
1453: [Bug] Video thumbnail not correctly build by QtAv
1451: [Bug] Open image tab while in fullscreen on second monitor - viewtopic.php?f=62&t=35028
1450: [Bug] PDF output on Linux - viewtopic.php?f=82&t=37376
1449: [Bug] Batch convert: Preview 'after' not always loaded - viewtopic.php?f=62&t=37377
1448: [Bug] All details on info pane are missing while Fullscreen preview is active - viewtopic.php?f=95&t=3658
1446: [Bug] Join: Collage on non image files
1445: [Bug] Batch Convert: ESC before end of process
1444: [Bug] Grid settings are not saved - viewtopic.php?f=62&t=37363
1443: [Bug] When selecting file without thumbnail, should create this one first - viewtopic.php?f=95&t=36704
1442: [Bug] Folders in folder tree are expanded - viewtopic.php?f=62&t=36808
1440: [Bug] Webm support
1438: [Bug] Excluding folders in Catalog & copy files - viewtopic.php?f=95&t=36635
1437: [Bug] Batch Convert: Hot folders & subdirectories - viewtopic.php?f=82&t=37338
1436: [Bug] Included/excluded folder list - double entries possible - viewtopic.php?f=62&t=37345
1435: [Bug] Slideshow order is not being restored on opening an .sld - viewtopic.php?f=62&t=37360
1434: [Bug] Thumbnail and Image Orientation out of sync after Jpeg Lossless Rotate - viewtopic.php?f=95&t=36687
1431: [Bug] Compare: thumbnails view size - viewtopic.php?f=95&t=36954
1430: [Bug] EXIF Image width/height is not updated - viewtopic.php?f=95&t=36625
1429: [Bug] Move shortcut of file - viewtopic.php?f=95&t=36971
1428: [Bug] Name collision dialog uses old name on renaming - viewtopic.php?f=95&t=37084
1426: [Bug] Ctrl+Right Click does not select the image - viewtopic.php?f=95&t=36951
1424: [Bug] Wheel on preview change focus - viewtopic.php?f=95&t=36767
1423: [Bug] Ctrl+Right Click unselects the image in detail view - viewtopic.php?f=95&t=36950
1422: [Bug] Selection must be restored after undo - viewtopic.php?f=95&t=37102
1421: [Bug] Rating/Label on folder always cleared - viewtopic.php?f=95&t=37269
1420: [Bug] Selection with the keyboard controls is inconsistent - viewtopic.php?f=95&t=34297
1419: [Bug] Duplicate video playback - viewtopic.php?f=95&t=35953
1418: [Bug] Not responsive while opening image file - viewtopic.php?f=95&t=35057
1417: [Bug] Wrong focus after returning from image tab - viewtopic.php?f=95&t=35964
1416: [Bug] Image navigation pane shown on animated GIF - viewtopic.php?f=95&t=36012
1415: [Bug] MacOSX: copy instead of move on same partition - viewtopic.php?f=95&t=35754
1414: [Bug] Fixed ratio for selection and horizontal handler - viewtopic.php?f=95&t=36457
1413: [Bug] PDF when viewing are not skipped if ghosctscript is not installed - viewtopic.php?f=95&t=35338
1412: [Bug] Batch Convert: Delete original always use recycle bin - viewtopic.php?f=95&t=37132
1411: [Bug] Thumbnail ratio - viewtopic.php?f=95&t=33725
1410: [Bug] Batch Rename not possible on Movie - viewtopic.php?f=95&t=35923
1401: [Bug] Modified date for OpenXML format changed when creating thumbnail - viewtopic.php?f=62&t=37344
1408: [Bug] Keys in slideshow - viewtopic.php?f=62&t=37181
1407: [Bug] Favorites not sorted after adding one - viewtopic.php?f=95&t=37092
1403: [Bug] Batch Rename: 'always added' not saved - viewtopic.php?f=60&t=37332
1402: [Bug] Wrong thumbnail from catalog - viewtopic.php?f=82&t=33548
1398: [Bug] Slow search on annotations - viewtopic.php?f=82&t=37295
1397: [Bug] Annotation doesn't work, in slideshow - viewtopic.php?f=82&t=37300
1396: [Bug] Freeze when clicking on .url - viewtopic.php?f=62&t=37289
1395: [Bug] Windows default context menu use only 1 file - viewtopic.php?f=82&t=37287
1394: [Bug] Export resize for NConvert - viewtopic.php?f=79&t=37278
1393: [Bug] Thumbnail process on big files can't be interrupted - viewtopic.php?f=110&t=37182
1390: [Bug] Cancel 'Edit Favorites path' - viewtopic.php?f=62&t=37100
1389: [Bug] Print: Incorrect caption in picture collection - viewtopic.php?f=62&t=37274
1388: [Bug] Directory locked after batch convert - viewtopic.php?f=62&t=37242
1386: [Bug] Batch convert: keep folder and folder at root path
1385: [Bug] Paint: b&w, 8bits colormap are converted with bad colors
1383: [Bug] Batch convert: ICC convert doesn't work on 64bits version - viewtopic.php?f=79&t=37176
1382: [Bug] Batch convert: extension is not changed - viewtopic.php?f=79&t=37165
1381: [Bug] Image with alpha channel converted in JPEG - viewtopic.php?f=82&t=37147
