Add a folder to the "Favorite" folders
Moderators: XnTriq, xnview, Dreamer
BlackWinny
Post by BlackWinny » Thu Jul 05, 2018 1:16 pm
Hello Pierre
In XnView as well as in XnView MP, when the local menu of a folder is open there isn't any command to add that folder to the favorite folders. It is required to open it previously to be able to add it to the favorite folders by the star which is close to the address bar.
Could you add this command to the local menu of the folders so that the operation can be done without having to open them ?
Another solution (also missing) would be by dragging & dropping the folder to the "Favorites" panel. But if at least one of these two solutions was available it would be really nice because it wouldn't make loose the focus on the current work in the mind of the user when he is in a repetitive work.
Thanks !
Jacques (in France)
Windows 10 64 bits - Total Commander - Chrome - Thunderbird - Notepad++ - XnView - A pillow (un oreiller) - A teapot always hot (une théière toujours chaude)
Re: Add a folder to the "Favorite" folders
Post by xnview » Fri Jul 13, 2018 11:52 am
you want a direct item in toolbar?
BlackWinny
Post by BlackWinny » Fri Jul 13, 2018 1:01 pm
Hello Pierre !
No no... much simpler : just to add this menu (in XnViewMP as well as in XnView) :
Thanks !
:D
Jacques
Post by xnview » Sun Jul 15, 2018 2:39 pm
ok :)
BlackWinny
Post by BlackWinny » Sun Jul 15, 2018 6:13 pm
BlackWinny
Post by BlackWinny » Wed Sep 12, 2018 12:57 pm
Hello Pierre,
It seems that you forgot this request in the new release.
Cheers,
Jacques
BlackWinny
Post by BlackWinny » Fri Sep 21, 2018 2:42 pm
Still missing in 0.92.
Post by xnview » Tue Nov 27, 2018 2:18 pm
See Issue
BlackWinny
Post by BlackWinny » Thu Nov 29, 2018 6:22 pm
See Issue
Ah Ok. Great !
:D
Un grand merci, Pierre !
Will you add this feature to XnView Classic too ?
:D
Post by xnview » Thu Jan 31, 2019 1:50 pm
This problem is supposed to be fixed in XnView MP 0.93. Please check and confirm the bug fix here.
BlackWinny
Post by BlackWinny » Wed Feb 06, 2019 10:15 pm
Excellent ! Tip top !
Merci Pierre !
Jacques
