Looking for a feature - disable drag&drop sort
M-a-v
Post by M-a-v »
I've been using version ver. 0.90.. works great on Windows 10
I saw on the Changelog
1360: [New] Setting to disable drag&drop custom order
Where can I find this feature? can't seem to find it in the settings.
or is it only in the .ini
Thanks.
M-
P.S.
Ver: XnView MP 0.90 (64bit)
OS: Windows 10 (64bit)
Re: Looking for a feature - disable drag&drop sort
in xnview.ini, please add
allowCustomOrder=false
in [Browser] section
M-a-v
Post by M-a-v »
sweet... Thank you!
