I tested the export dialog and selected the pcx format for export.
To test the RLE compression I recognize, that the RLE compression produce bigger files!
Is it correct? I though a picture compression reduce the filesize and do not increase it.
The upper picture shows the picture without RLE compression and the lower picture with RLE compression.
0.91 beta 1 - Export to PCX - Bigger filesize with RLE compression?
PC: Intel 8700k + Asus Z370-F + 16 GB RAM G.Skill + Asus RTX 3050 OC + Samsung SSD
OS: Windows 10 Pro 64bit 22H2 |
GFX: XN-View 2.51.2 | XnViewMP 1.5.5 | XnConvert 1.98 | Adobe Photoshop Elements 2023 | Elements XXL 10 | Paint.Net
Re: 0.91 beta 1 - Export to PCX - Bigger filesize with RLE compression?
I think the answer is simply that different types of compression are best suited to different types of image: colour mode (colour, grayscale or black and white) and different types of content: (photograph or line drawing, for example).
In this case RLE compression isn't suited to the complexity of your photo, but it could be very effective for a line drawing.
RLE Compression
I thought so, but I was not sure. Thank you.
yes it's normal. RLE for PCX is not good for photography, only drawing
