Xcf files of Gimp 2.10 cannot be displayed
Moderators: XnTriq, xnview
forest_bear59
Post by forest_bear59 » Tue May 15, 2018 6:58 pm
just in case that other users have noticed this already : xnviewmp does not display Gimp's xcf-files with the new internal structure (from 2.10).
It is already mailed to the developer plus example files. This thread is just to document that the effect has been reported if somebody should look here and as a place for messages from the developer.
Thanks for the good work so far. Xnviewmp has become my 1&only viewer.
Stephan
Re: Xcf files of Gimp 2.10 cannot be displayed
Post by xnview » Sun May 20, 2018 1:58 pm
currently i search what is changed, but the specification are not updated. ImageMagick can't load them too
latacz
Post by latacz » Wed May 23, 2018 6:19 am
mbeckett
Post by mbeckett » Mon Jul 23, 2018 6:11 pm
what is the status on this one? i couldn't find it any of the bug lists.
zmblr
Post by zmblr » Fri Jul 27, 2018 1:48 pm
I'm interested too.
Any advance on support the new xcf format?
br
Post by xnview » Sun Aug 05, 2018 2:55 pm
i have not found the lastest specs
Felice
Post by Felice » Sun Aug 12, 2018 1:48 pm
GIMP is open-source. I assume you could just grab it with git and find all the structures in a set of headers somewhere.
https://www.gimp.org/source/howtos/gimp-git-build.html
Akovia
Post by Akovia » Mon Oct 01, 2018 11:55 pm
Just wanted to add another voice in support of this.
Arch Linux
XnView MP
mbeckett
Post by mbeckett » Tue Oct 23, 2018 9:25 pm
Every time xnViewMP and (xnView Classic) come across a folder with a file created in gimp 2.10, they hang and ultimately crash. if you can't fix the thumbnails for the new Gimp files, can you at least keep the program from crashing? i have had to figure out which files were created in the new Gimp and remove them from anywhere xnview can find them, and i have gone back to the previous version of Gimp to get around this for now. hardly what i call progress *sigh
ssrmnch
Post by ssrmnch » Sun Dec 30, 2018 10:00 pm
Hi, I experienced this weird behaviour as well.
I'll keep it short: it happened to me only for one specific Gimp-file that I noticed had a guide in it, unlike most of my other gimp-files. You know a vertical, manually added snap/guide line. I removed it, resaved the xcf-file and viola! - Xnview don't crash when showing the folder as it did before.
I recreated a guide in the gimp-file, which again caused XNview to crash.
I don't have a clue as to why, but I may have stumbled upon a hint to the cause for this bug, that I hope someone wiser can use to fix it in future versions (of Gimp or Xnview, what do I know...!).
Otherwise good job, dear programmers! Have a great new year!
Best, Asser.
Post by xnview » Thu Jan 03, 2019 12:55 pm
it will be fixed in next release
forest_bear59
Post by forest_bear59 » Tue Jan 29, 2019 5:19 am
I am happy to read this. Thank You very much!
Regards
Stephan
Akovia
Post by Akovia » Tue Feb 05, 2019 12:35 pm
This is now worse than before for me and unusable. Just browsing to a directory with xcf files causes one of many types of crashes. There may be more.
free(): invalid size
Aborted (core dumped)
munmap_chunk(): invalid pointer
double free or corruption (out)
Arch Linux
XnView MP
Post by xnview » Tue Feb 05, 2019 12:41 pm
really? could you send me a xcf that crash?
Akovia
Post by Akovia » Tue Feb 05, 2019 3:01 pm
Here are a few xcf files that crash with different errors as well as a text file listing the errors.
https://drive.google.com/open?id=1mDk2L ... RzDpNI7ixc_
Arch Linux
XnView MP
