Check and quickly choose the compression ratio
Moderators: XnTriq, xnview, Dreamer
Piteur
Post by Piteur » Tue May 08, 2018 5:42 pm
Hello!
Would it be possible that, in the recording window, XnViewMP, like XnView, has a button to check and quickly change the compression ratio? Or is it tricky because of the multiplatform nature of XnViewMP?
Thanks.
=== EDIT ===
Was this talk read? Or is my question stupid? :?
Re: Check and quickly choose the compression ratio
Post by xnview » Mon Jun 04, 2018 3:00 pm
Currently there is a problem to add it like xnView Classic. But it will be better, i need to check how to add 'options' in filename dialog
Piteur
Post by Piteur » Mon Jun 04, 2018 3:34 pm
It does not surprise me, coming from you: you will find a solution, I am sure!
Many thanks, Pierre!
Post by xnview » Thu Jan 31, 2019 1:52 pm
This problem is supposed to be fixed in XnView MP 0.93. Please check and confirm the bug fix here.
Piteur
Post by Piteur » Thu Jan 31, 2019 2:29 pm
Unless I'm mistaken, it works perfectly on Windows 10. As soon as I check it out on (x) Ubuntu, I come back to confirm!
Thank you, Pierre.
:arrow: NB: hard installation because of Avast, which obviously doesn't recognize the install file; used the ZIP in the end! 😋
=== EDIT ===
Is the function supposed to be present in the Xubuntu version? I don't see it... :?
Post by xnview » Thu Jan 31, 2019 3:53 pm
currently only on Windows
Piteur
Post by Piteur » Thu Jan 31, 2019 4:45 pm
In the future on Xubuntu too? Or don't count because of the difficulties that this could cause?
Post by xnview » Thu Jan 31, 2019 4:55 pm
not sure for unbuntu
Piteur
Post by Piteur » Thu Jan 31, 2019 5:11 pm
If, on Ubuntu, it isn't possible to change the compression directly in the recording dialog, could one at least have the display of the compression used? Like that, if it fits, just continue ...
I juggle a lot with different compressions: for the Web, strong compression; for other uses, reduced compression.
A quick knowledge of the compression is really useful in my opinion! 😍
