Open en close XnViewMP
Moderators: XnTriq, xnview, Dreamer
mrwul
Post by mrwul » Thu Apr 26, 2018 9:32 am
Up front... I know... it is my mistake.
I know...
However, I am making the mistake over and over again and get frustrated about my own mistakes,
I would like to ask whether there is a solution for the following:
when in XnViewMP browser, double clicking an image, it will open.
then I always click on the wrong button to close it (right hand top corner), thus closing XnViewMP.
I have to relaunch XnViewMP again.
Next time I again, without thinking, close the right hand top corner [X] button...
Is there a way that XnViewMP asks whether I wish to close all tabs?
(Similar to default settings of most browsers)
So I can hit the Esc or Cancel key then.
Thanks.
Re: Open en close XnViewMP
Post by xnview » Fri Apr 27, 2018 9:06 am
if settings>General>Save session on program exit is 'Ask', you'll have a confirmation dialog
mrwul
Post by mrwul » Fri Apr 27, 2018 10:36 am
Ah .. right!
Thank you very much.
mrwul
Post by mrwul » Fri Apr 27, 2018 12:12 pm
I tried this a few times. No luck.
Getting the pop window, but no matter what I click/select, XnViewMP closes anyway, my idea is to keep it running.
SnagIt-27042018 140822.png (14.56 KiB) Viewed 1022 times
Post by xnview » Fri Apr 27, 2018 12:19 pm
oh ok, a message box asking to close XnView, right?
mrwul
Post by mrwul » Fri Apr 27, 2018 12:21 pm
Yes, that is the idea. Again, it is my mistake.. but it would be nice if XnViewMP ask whether I want to close, then I click on 'No' or hit 'Esc' so I can continiue with XnViewMP, instead of having to re-launch again.
Post by xnview » Sat Apr 28, 2018 7:41 am
Post by xnview » Thu Jun 07, 2018 9:40 am
This problem is supposed to be fixed in XnView MP 0.91. Please check and confirm the bug fix here.
HanVroon
Post by HanVroon » Sat Jul 21, 2018 7:30 am
Tested with 0.91 beta 4.
When one or more images are open, the program asks to quit when clicking on the X.
And the answer can be remembered as default (never ask again), which is great :wink:
