Command line options of nconvert 4.51
Moderators: XnTriq, xnview
Here's the command line options (output by 'nconvert -help'):
** NCONVERT v4.51 (c) 1991-2005 Pierre-E Gougelet (Sep  6 2005/15:00:05) **
        Version for Windows NT/9x/2000  (All rights reserved)
** This is a freeware software (for non commercial use)
The JPEG code is based in part on the work of the Independent JPEG Group's software.
The PNG code is based in part on the work of the Group 42, Inc.
This software is based in part on compression library of Jean-loup Gailly and Mark Adler
Usage : nconvert.exe [options] file ...
        Options :
          -quiet            : Quiet mode
          -info             : Display informations only
          -v[.]             : Verbose
          -in format        : Input format number or -1
          -page num         : Page/image number
          -xall             : Extract all images
          -multi            : Create a multi-page (TIFF/DCX/LDF only)
          -npcd num         : PCD 0:192x128, 1:384x256, 2:768x512 (default)
          -ngrb npic        : HP-48 number of grey : 1, 2 or 4 (default : 1)
          -ctype type       : Channel Type (Raw)
              grey  : Greyscale (default)
              rgb   : Red,Green,Blue
              bgr   : Blue,Green,Red
              rgba  : Red,Green,Blue,Alpha
              abgr  : Alpha,Blue,Green,Red
              cmy   : Cyan,Magenta,Yellow
              cmyk  : Cyan,Magenta,Yellow,Black
          -corder order     : Channel Order (Raw)
              inter : Interleaved (default)
              seq   : Sequential
              sep   : Separate
          -size geometry    : Width and height (Raw/YUV)
                Geometry is widthxheight+offset
          -n start end step : Begin End Step (for image sequence)
          -o filename       : Output filename
              Use # to specify position of numeric enumerator
              Use % to specify source filename
              Use $ to specify source folder
          -out format       : Output format name
          -D                : Delete original picture
          -c value          : Compression number (default : 0)
              TIFF   : 1 (Rle), 2 (LZW), 3 (LZW+Prediction)
                       4 (ZLIB)
                       5 (CCITT G3), 6 (CCITT G3-2D), 7 (CCITT G4) only B/W
                       8 (JPEG) only 24/32 bits
              TARGA, Softimage, SGI, PCX, IFF, BMP : 1 (Rle)
          -q value          : JPEG/PNG/FPX/WIC quality (default : 100)
          -clevel value     : PNG Compression level (default : 6)
          -i                : Interlaced GIF / Progressive JPEG
          -transparent value: Transparency index (GIF/PNG)
          -transpcolor red green blue: Transparency color (GIF/PNG)
          -opthuff          : Optimize Huffman Table
          -bgcolor red green blue: Background color (for rotate/canvas)
          -dpi res_dpi      : Set the resolution in DPI
          -keepdocsize      : Resize bitmap function of the old and new DPI value
          -keepcspace       : Keep original color space if possible
          -jpegtrans op     : JPEG lossless transformations
              rot90  : Rotate 90 degrees
              rot180 : Rotate 180 degrees
              rot270 : Rotate 270 degrees
              vflip  : Flip vertical
              hflip  : Flip horizontal
          -rmeta  : Remove Metadata (EXIF/IPTC/...)
          -rexifthumb  : Remove EXIF thumbnail
          -wflag flag       : Write flag
              os2    : Write OS/2 bmp
              gif87  : Write GIF87a
              hp49   : Write HP49
          -high_res             : Load high resolution (CRW)
          -ascii                : Ascii (PPM)
          -one_strip            : One strip (TIFF)
          -raw_auto_balance     : Auto balance (Camera RAW)
          -raw_camera_balance   : Camera balance (Camera RAW)
          -raw_gamma value      : Gamma (Camera RAW), default=0.6
          -raw_brightness value : Brighness (Camera RAW), default=0.8
          -raw_redscale value   : Red scaling (Camera RAW)
          -raw_bluescale value  : Blue scaling (Camera RAW)
          -ilut file        : Input LUT file (DPX/Cineon)
          -olut file        : Output LUT file (DPX/Cineon)
          -wmfile file      : Watermark file
          -wmpos x y        : Watermark position
          -wmflag flag      : Watermark position
              top-left, top-center, top-right
              center-left, center, center-right
              bottom-left, bottom-center, bottom-right
        Process :
          -average size     : Average (3,5,7,9,11,13)
          -autocrop tol r g b : Auto Crop
          -balance r g b    : Color balance
          -binary dither    : Convert in Binary
              pattern : Ordered pattern
              floyd   : Floyd steinberg
              halft45 : Halftone 45
              halft90 : Halftone 90
              nodither : No dithering
          -blur percent     : Blur (1...100)
          -brightness value : Modify brightness (-100...100)
          -canvas w h pos   : Resize canvas
              w h can be percent (ex: -resize 100% 200%)
              pos top-left, top-center, top-right
          -conbright value  : Modify brightness (-100...100)
          -colours num
          -colors num       : Convert in Indexed Colors (256, 216, 128, 64, 32, 16 or 8)
          -contrast value   : Modify contrast (-100...100)
          -crop x y w h     : Crop
          -dither           : Use dither for conversion (Colors and Grey only)
          -deinter k n      : De-interlace
              k : even or odd
              n : dup or int
          -edetail          : Enhance detail
          -eedge percent    : Enhance edges (1...100)
          -edgedetect type  : Edge detect
              light/medium/heavy
          -efocus           : Enhance focus
          -emboss           : Emboss
          -embossmore       : Emboss more
          -equalize         : Equalize
          -frestore         : Focus restoration
          -gamma value      : Modify gamma (0.01<->5.0
          -gammasat value   : Modify gamma (0.01<->5.0
          -gauss size       : Blur gaussian (3,5,7,9,11,13)
          -grey num         : Convert in Grey Scale (256, 128, 64, 32, 16, 8 or 4)
          -hls h l s        : Adjust Hue Lightness Saturation
          -lens percent     : Lens (1...100)
          -log              : Apply logarithmic correction
          -maximum size     : Maximum filter (3,5,7,9,11,13)
          -medianb size     : Median Box filter (3,5,7,9,11,13)
          -medianc size     : Median Cross filter (3,5,7,9,11,13)
          -minimum size     : Minimum filter (3,5,7,9,11,13)
          -mosaic size      : Mosaic (1...64)
          -negate           : Negate
          -noise reduce     : Reduce noise
          -noise type value
              uniform   : Add uniform noise
              gaussian  : Add gaussian noise
              laplacian : Add laplacian noise
              poisson   : Add poisson noise
          -normalize        : Normalize
          -oil size         : Oilify (1...16)
          -posterize count  : Posterize (2...256)
          -ratio            : Keep the ratio for scaling
          -rtype            : Type of resampling
              quick    : Quick resize
              linear   : Bi-linear (linear)
              hermite  : Hermite
              gaussian : Gaussian
              bell     : Bell
              bspline  : Bspline
              mitchell : Mitchell
              lanczos  : Lanczos 3
          -rflag            : Flag for resizing
              incr   : Increase only
              decr   : Decrease only
              orient : Follow orientation
          -resize w h      : Scale width-height
          -rotate degrees   : Rotate
          -sepia            : Sepia
          -sharpen percent  : Sharpen (1...100)
          -shear            : Shear
          -slice            : Slice
          -soften percent   : Soften (1...100)
          -solarize value   : Solarize (1...255)
          -spread amount    : Spread (1...32)
          -swap type        : Swap component
              rbg   : RGB->RBG
              bgr   : RGB->BGR
              brg   : RGB->BRG
              grb   : RGB->GRB
              gbr   : RGB->GBR
          -swirl degrees    : Swirl (1...360)
          -text string      : Add a text
          -text_font name size  : Font name and size
          -text_color r g b : Text color
          -text_back r g b  : Text background color
          -text_flag pos    : Position of text
          -text_pos x y     : Position or offset
          -tile size        : Tile (1...64)
          -truecolors
          -truecolours      : Convert in True Colors
          -xflip            : Flip horizontal
          -yflip            : Flip vertical
          -waves wavelength phase amount : Waves
              wavelength   : (1.0 50.0)
              phase        : (0.0 360.0)
              amount       : (0.0 100.0)
        Available format:
               Name     Write  Description
                -1            : Automatic (Only for input)
               [*       ]     : JFIF based file
               [2bp     ]     : Pocket PC Bitmap
               [2d      ]     : Amapi
               [411     ]     : Mavica
               [a64     ]     : Artist 64
               [abmp    ]     : Alpha Microsystems BMP
               [abs     ]     : Optocat
               [acc     ]     : Access
               [ace     ]     : ACE texture
               [aces    ]     : Aces200
               [acorn   ]     : Acorn Sprite
               [adex    ]     : ADEX
               [adt     ]     : AdTech perfectfax
               [afx     ]     : Auto F/X
               [ai      ]     : Adobe Illustrator
               [aim     ]     : AIM Grey Scale
               [aip     ]     : Starlight Xpress SX 500x291 RAW
               [alias   ]  *  : Alias Image File
               [ami     ]     : Amica Paint
               [ani     ]     : Windows Animated Cursor
               [anv     ]     : AirNav
               [aphp    ]     : Adobe PhotoParade (images)
               [apx     ]     : Ability Photopaint Image
               [arcib   ]  *  : ArcInfo Binary
               [arf     ]     : ARF
               [arn     ]     : Astronomical Research Network
               [art     ]     : Artisan
               [artdir  ]     : Art Director
               [atk     ]     : Andrew Toolkit raster object
               [att     ]     : AT&T Group 4
               [aurora  ]     : Aurora
               [avs     ]     : Stardent AVS X
               [b16     ]     : PCO
               [b3d     ]     : B3D (images)
               [bdr     ]     : Brender
               [bfli    ]     : BFLI
               [bfx     ]     : Bfx Bitware
               [bga     ]     : Os/2 Warp
               [bias    ]     : BIAS FringeProcessor
               [bif     ]     : byLight
               [biorad  ]  *  : Bio-Rad confocal
               [bld     ]     : MegaPaint
               [bmc     ]     : Embroidery
               [bmg     ]     : Bert's Coloring
               [bmp     ]  *  : Windows Bitmap
               [bms     ]     : Playback Bitmap Sequence
               [bmx     ]     : Siemens Mobile
               [bob     ]     : Bob Raytracer
               [bpr     ]     : AAA logo
               [brk     ]     : Brooktrout 301
               [bsg     ]     : Fontasy Grafik
               [btn     ]     : JustButtons animated bitmap
               [bum     ]     : Poser Bump
               [byusir  ]     : BYU SIR
               [c4      ]     : Edmics
               [cadc    ]     : Autocad CAD-Camera
               [cals    ]     : CALS Raster
               [cam     ]     : Casio QV-10/100 Camera
               [can     ]     : Canon Navigator Fax
               [car     ]     : NeoBook Cartoon
               [cart    ]     : Crayola
               [cat     ]     : Photomatrix
               [cbmf    ]     : Corel Flow (preview)
               [cdr     ]     : Corel Draw Bitmap (preview)
               [cdu     ]     : CDU Paint
               [ce      ]     : Computer Eyes, Digital Vision
               [ce1     ]     : ComputerEyes Raw
               [cel     ]     : Kiss Cel
               [cft     ]     : Optigraphics
               [cin     ]  *  : Kodak Cineon
               [cip     ]     : Cisco IP Phone
               [ciph    ]     : InterPaint (Hires)
               [cipt    ]     : InterPaint (Multicolor)
               [cish    ]     : Image System (Hires)
               [cism    ]     : Image System (Multicolor)
               [cloe    ]     : Cloe Ray-Tracer
               [clp     ]     : Windows Clipboard
               [cmt     ]     : Chinon ES-1000 digital camera
               [cmu     ]     : CMU Window Manager
               [cmx     ]     : Corel Metafile Exchange (preview)
               [cncd    ]     : CoverDesigner (images)
               [cnct    ]     : CoverDesigner Template (images)
               [cp8     ]     : CP8 256 Gray Scale
               [cpa     ]     : Prism
               [cpat    ]     : Corel Draw Pattern (preview)
               [cpc     ]     : Amstrad Cpc Screen
               [cpt     ]     : Corel PhotoPaint 6.0
               [cr2     ]     : Canon EOS-1D Mark II RAW
               [crd     ]     : PowerCard maker
               [crg     ]     : Calamus
               [crw     ]     : Canon PowerShot
               [ct      ]     : Iris CT
               [cur     ]     : Windows Cursor
               [cut     ]     : Dr Halo
               [cvp     ]     : Portrait
               [d3d     ]     : TopDesign Thumbnail
               [dali    ]     : Dali Raw
               [dbw     ]     : DBW Render
               [dcmp    ]     : Discorp CMP Image
               [dcpy    ]     : Datacopy
               [dcr     ]     : Kodak Pro Digital RAW
               [dcx     ]  *  : Zsoft Multi-page Paintbrush
               [dd      ]     : Doodle C64
               [dds     ]  *  : Direct Draw Surface
               [degas   ]  *  : Degas & Degas Elite
               [dib     ]     : Windows DIB
               [dicom   ]     : Dicom
               [dkb     ]  *  : DKB Ray-Tracer
               [dng     ]     : DNG
               [dol     ]     : DolphinEd
               [doodle  ]     : Doodle Atari
               [dpx     ]  *  : DPX
               [drz     ]     : Draz Paint
               [dsi     ]     : CImage
               [dta     ]     : Zeiss BIVAS
               [ecc     ]     : Ecchi
               [efx     ]     : Everex Everfax
               [eidi    ]     : Electric Image
               [eif     ]     : Eroiica
               [emf     ]  *  : Windows Enhanced Metafile
               [epa     ]     : Award Bios Logo
               [epi     ]     : EPS Interchange Format
               [eps     ]     : Encapsulated Postscript
               [epsp    ]     : Encapsulated Postscript(Preview)
               [esm     ]     : Enhance Simplex
               [esmp    ]     : ESM Software Pix
               [eyes    ]     : Microtek Eyestar
               [f96     ]     : Fremont Fax96
               [face    ]     : Usenix FaceServer
               [fax     ]     : Fax Group 3
               [fbm     ]     : Fuzzy bitmap
               [fcx     ]     : Faxable PCX
               [fff     ]     : Maggi Hairstyles & Cosmetics
               [ffpg    ]     : Fenix Multi Map
               [fi      ]     : Flash Image
               [fit     ]     : FIT
               [fits    ]  *  : Flexible Image Transport System
               [fli     ]     : Autodesk Animator
               [fmag    ]     : FileMagic
               [fmap    ]     : Fenix Map
               [fmf     ]     : Fax man
               [fp2     ]     : Fun Painter II
               [fpg     ]     : DIV Game Studio Multi Map
               [fpr     ]     : Fun Photor
               [fpt     ]     : Face Painter
               [fre     ]     : Male Normal CT
               [frm     ]     : PhotoFrame
               [frm2    ]     : Album bébé
               [fsh     ]     : EA Sports FSH
               [fsy     ]     : PhotoFantasy Image
               [ftf     ]     : Faxable TIFF
               [fx3     ]     : Fugawi Map
               [fxs     ]     : WinFAX
               [g16     ]     : GRS16
               [g3n     ]     : Imaging Fax
               [gaf     ]     : Total Annihilation
               [gbr     ]     : Gimp Brush
               [gem     ]     : Digital Research (GEM Paint)
               [geo     ]     : GeoPaint
               [gfaray  ]     : Gfa Raytrace
               [gg      ]     : Koala Paint (Compressed)
               [gicon   ]     : Gimp Icon
               [gif     ]  *  : CompuServe GIF
               [gig     ]     : GigaPaint Multi
               [gih     ]     : GigaPaint Hi-res
               [gm      ]     : Autologic
               [gmf     ]     : Gamma Fax
               [god     ]     : GoDot
               [gpat    ]  *  : Gimp Pattern
               [gpb     ]     : Sharp GPB
               [grob    ]  *  : HP-48/49 GROB
               [gun     ]     : GunPaint
               [hdri    ]     : HDRI
               [hdru    ]     : Apollo HDRU
               [hed     ]     : Hi-Eddi
               [hf      ]     : HF
               [hir     ]     : Hires C64
               [hpi     ]     : Hemera Photo Image
               [hr      ]     : TRS 80
               [hru     ]  *  : HRU
               [hrz     ]     : Slow Scan Television
               [hsi     ]     : HSI Raw
               [hta     ]     : Hemera Thumbs
               [icb     ]     : Image Capture Board
               [icd     ]     : Core IDC
               [icl     ]     : Icon Library
               [icns    ]     : Mac icon
               [ico     ]  *  : Windows Icon
               [icon    ]     : Sun Icon/Cursor
               [iff     ]  *  : Amiga IFF
               [iim     ]     : Inshape
               [iimg    ]     : Interleaf
               [ilab    ]     : ImageLab
               [im5     ]     : IM5 (Visilog)
               [img     ]     : Img Software Set
               [imgt    ]     : Imaging Technology
               [imi     ]     : TMSat image
               [imt     ]     : IMNET Image
               [info    ]     : Amiga icon
               [ingr    ]     : Intergraph Format
               [ioca    ]     : IOCA
               [ipg     ]     : Mindjongg Format
               [iris    ]     : Iris Graphics
               [ish     ]     : Image Speeder
               [iss     ]     : ISS
               [j6i     ]     : Ricoh Digital Camera
               [jbf     ]     : PaintShopPro Browser Cache File
               [jif     ]  *  : Jeff's Image Format
               [jig     ]     : Jigsaw
               [jig2    ]     : Weekly Puzzle
               [jj      ]     : Doodle C64 (Compressed)
               [jpeg    ]  *  : JPEG / JFIF
               [jps     ]     : Stereo Image
               [jtf     ]     : Hayes JTFax
               [k25     ]     : Kodak DC25 Camera
               [kdc     ]     : Kodak DC120 Digital Camera
               [kfx     ]     : Kofax Group 4
               [kntr    ]     : KONTRON
               [koa     ]     : Koala Paint
               [kps     ]     : IBM Kips
               [kqp     ]     : Konica Camera File
               [kskn    ]     : KinuPix Skin
               [lbm     ]     : Deluxe Paint, Electronic Arts
               [lcel    ]     : Lumena CEL
               [lda     ]     : LaserData
               [lff     ]     : LucasFilm Format
               [lif     ]     : Homeworld Texture
               [lss     ]     : LSS16
               [lvp     ]     : LView Pro
               [lwi     ]     : Light Work Image
               [m8      ]     : Heretic II MipMap
               [mac     ]     : Mac Paint
               [mag     ]     : MAKIchan Graphics
               [map     ]     : DIV Game Studio Map
               [mbig    ]     : Cartes Michelin
               [mdl     ]     : Half-Life Model
               [mfrm    ]     : Megalux Frame
               [mgr     ]     : MGR bitmap
               [mh      ]     : Teli Fax
               [miff    ]  *  : Image Magick file
               [mil     ]     : Micro Illustrator Uncompressed
               [mjpg    ]     : JPEG 8BIM header (Mac)
               [mkcf    ]     : MonkeyCard
               [mklg    ]     : MonkeyLogo
               [mng     ]     : Multiple Network Graphics
               [mph     ]     : MonkeyPhoto
               [mrf     ]     : Marks Russel File
               [mrw     ]     : Minolta DiMAGE RAW
               [msp     ]     : Microsoft Paint
               [msx2    ]     : Msx 2 Screen
               [mtv     ]  *  : MTV Ray-Tracer
               [mtx     ]     : Maw-Ware Textures
               [ncr     ]     : NCR Image
               [ncy     ]     : FlashCam Frame
               [ncy     ]     : FlashCam frame
               [nef     ]     : Nikon RAW
               [neo     ]     : Neochrome (ST & TT)
               [ngg     ]  *  : Nokia Group Graphics
               [nist    ]     : NIST ihdr
               [nitf    ]     : National Imagery Transmission F.
               [nlm     ]  *  : Nokia Logo File
               [nol     ]  *  : Nokia Operator Logo
               [npm     ]     : Neopaint Mask
               [nsr     ]     : NewsRoom
               [oaz     ]     : OAZ Fax
               [ocp     ]     : Advanced Art Studio
               [of      ]     : HP-49 OpenFire
               [ofx     ]     : Olicom Fax
               [ohir    ]     : Oric Hires
               [oil     ]     : Open Image Library Format
               [orf     ]     : Olympus RAW
               [os2     ]     : OS/2 Bitmap
               [otap    ]     : Oric TAP
               [otb     ]  *  : Nokia OTA bitmap
               [p64     ]     : Picasso 64
               [p7      ]     : XV Visual Schnauzer
               [pabx    ]  *  : PABX background
               [palm    ]  *  : Palm Pilot
               [pan     ]     : SmoothMove Pan Viewer
               [pbm     ]  *  : Portable Bitmap
               [pbt     ]     : Micro Dynamics MARS
               [pcd     ]     : Kodak Photo CD
               [pcl     ]  *  : Page Control Language
               [pcp     ]     : Atari grafik
               [pcx     ]  *  : Zsoft Publisher's Paintbrush
               [pd      ]     : Male MRI
               [pdd     ]     : Photo Deluxe
               [pdf     ]     : Portable Document Format
               [pds     ]     : Planetary Data System
               [pdx     ]     : Mayura Draw
               [pef     ]     : Pentax *ist D
               [pegs    ]     : Pegs
               [pfs     ]     : Pfs Art Publisher
               [pgc     ]     : Portfolio Graphics Compressed
               [pgf     ]     : Portfolio Graphics
               [pgm     ]  *  : Portable Greyscale
               [pi      ]     : Blazing Paddles
               [pic     ]     : PC Paint / Pictor Page
               [pict    ]     : Macintosh Quickdraw/Pict
               [pig     ]     : Ricoh IS30
               [pixi    ]     : Pixibox
               [pixp    ]     : Pixel Power Collage
               [pm      ]     : PM
               [pm      ]     : Print Master
               [pmg     ]     : Paint Magic
               [pmp     ]     : Sony DSC-F1 Cyber-shot
               [pmsk    ]     : PaintShopPro Mask
               [png     ]  *  : Portable Network Graphics
               [pnm     ]  *  : Portable Image
               [pp4     ]     : Micrografx Picture Publisher 4.0
               [pp5     ]     : Micrografx Picture Publisher 5.0
               [ppm     ]  *  : Portable Pixmap
               [ppp     ]     : Punk Productions Picture
               [pps     ]     : PowerPoint (images)
               [ppt     ]     : PowerPoint Presentation (images)
               [prc     ]  *  : Picture Gear Pocket
               [prf     ]     : Polychrome Recursive Format
               [prisms  ]     : Prisms
               [prx     ]     : Printfox/Pagefox
               [ps      ]  *  : Postscript
               [psa     ]     : Print Shop
               [psd     ]  *  : Adobe Photoshop
               [pseg    ]     : IBM Printer Page Segment
               [psf     ]     : PhotoStudio File
               [psion3  ]  *  : Psion Series 3 Bitmap
               [psion5  ]  *  : Psion Series 5 Bitmap
               [psp     ]     : PaintShopPro Image
               [pspb    ]     : PaintShopPro Brush
               [pspf    ]     : PaintShopPro Frame
               [pspm    ]     : PaintShopPro Mask
               [pspp    ]     : PaintShopPro Pattern
               [pspt    ]     : PaintShopPro Texture
               [ptg     ]     : Artrage
               [pwp     ]     : Seattle Film Works multi-image
               [pxa     ]     : Pixia
               [pxr     ]     : Pixar picture file
               [pzl     ]     : Puzzle
               [pzp     ]     : MGI Photosuite Project (images)
               [q0      ]     : Q0
               [qcad    ]     : Autodesk QuickCAD thumbnail
               [qdv     ]     : Qdv (Random Dot Software)
               [qrt     ]  *  : Qrt Ray-Tracer
               [qtif    ]     : QuickTime Image Format
               [rad     ]  *  : Radiance
               [raf     ]     : Fuji S2 RAW
               [ras     ]     : Sun Rasterfile
               [raw     ]  *  : Raw
               [ray     ]  *  : Rayshade
               [rfa     ]     : Mobile FAX
               [rfax    ]     : Ricoh Fax
               [ript    ]     : RIPTerm Image
               [rix     ]     : ColoRIX
               [rla     ]  *  : Wavefront Raster file
               [rlc2    ]     : Image Systems RLC2 Graphic
               [rle     ]     : Utah raster image
               [rp      ]     : Rainbow Painter
               [rpm     ]     : RunPaint (Multicolor)
               [rsb     ]     : Red Storm File Format
               [sar     ]     : Saracen Paint
               [sci     ]     : SciFax
               [sct     ]  *  : SciTex Continuous Tone
               [sdg     ]     : Star Office Gallery
               [sdt     ]     : SmartDraw 6 template
               [sfax    ]     : SmartFax
               [sfw     ]     : Seattle Film Works
               [sgi     ]  *  : Silicon Graphics RGB
               [sir     ]     : Solitaire Image Recorder
               [sj1     ]     : Sega SJ-1 DIGIO
               [skf     ]     : Autodesk SKETCH thumbnail
               [skn     ]     : Skantek
               [skp     ]     : Autodesk SketchUp component
               [smp     ]     : Xionics SMP
               [soft    ]  *  : Softimage
               [spc     ]     : Spectrum 512 (Compressed)
               [spot    ]     : SPOT
               [sps     ]     : Spectrum 512 (Smooshed)
               [spu     ]     : Spectrum 512
               [srf     ]     : Panasonic DMC-LC1 RAW
               [srf2    ]     : Sony DSC-F828 RAW
               [ssi     ]     : SriSun
               [ssp     ]     : Axialis Screensaver (images)
               [sst     ]     : AVHRR Image
               [st4     ]     : SBIG CCD camera ST-4
               [stad    ]     : Stad
               [star    ]     : Starbase
               [stm     ]     : PhotoStudio Stamp
               [stw     ]     : Neopaint Stamp
               [stx     ]     : SBIG CCD camera ST-X
               [syj     ]     : Syberia texture
               [synu    ]     : Synthetic Universe
               [taac    ]     : Sun TAAC file
               [tdi     ]  *  : Explore (TDI) & Maya
               [tdim    ]     : Digital F/X
               [teal    ]     : TealPaint
               [tg4     ]     : TG4
               [tga     ]  *  : Truevision Targa
               [ti      ]  *  : TI Bitmap
               [tiff    ]  *  : TIFF Revision 6
               [til     ]     : Buttonz & Tilez texture
               [tile    ]     : Eclipse
               [tim     ]     : Sony Playstation TIM
               [tim2    ]     : Sony PS2 TIM
               [tiny    ]     : Tiny
               [tjp     ]     : TilePic
               [tnl     ]     : Thumbnail
               [trup    ]     : Egg Paint
               [tsk     ]     : Pocket PC Themes (images)
               [ttf     ]     : Optigraphics Tiled
               [tub     ]     : PaintShopPro Picture Tube
               [uni     ]     : Brother Fax
               [upe4    ]     : Ulead Texture (images)
               [upi     ]     : Ulead PhotoImpact
               [upst    ]     : Ulead Pattern
               [uyvy    ]  *  : YUV 16Bits
               [uyvyi   ]  *  : YUV 16Bits Interleaved
               [v       ]     : VIPS Image
               [vda     ]     : Video Display Adapter
               [vfx     ]     : Venta Fax
               [vi      ]     : Jovian VI
               [vicar   ]     : Vicar
               [vid     ]     : Vidcom 64
               [vif     ]     : Verity
               [viff    ]     : Khoros Visualization Image file
               [vista   ]  *  : Vista
               [vit     ]     : VITec
               [vivid   ]  *  : Vivid Ray-Tracer
               [vob     ]     : Vue d'esprit
               [vort    ]     : Vort
               [vpb     ]     : Quantel VPB
               [wad     ]     : WAD (Half life)
               [wal     ]     : Quake Texture
               [wbc     ]     : WebShots (images)
               [wbmp    ]  *  : Wireless Bitmap (level 0)
               [wfx     ]     : Worldport Fax
               [winm    ]     : WinMIPS
               [wmf     ]     : Windows & Aldus Metafile
               [wpg     ]     : Word Perfect Graphics (images)
               [wrl     ]  *  : VRML2
               [wzl     ]     : Winzle Puzzle
               [x3f     ]     : Sigma RAW
               [xar     ]     : Xara (images)
               [xbm     ]  *  : X11 Bitmap
               [xcf     ]     : Gimp Bitmap
               [xif     ]     : Xerox DIFF
               [xim     ]     : Ximage
               [xp0     ]     : SecretPhotos puzzle
               [xpm     ]  *  : X11 Pixmap
               [xwd     ]     : X Windows System dump
               [xyz     ]     : Rm2K XYZ
               [yuv411  ]     : YUV 4:1:1
               [yuv422  ]     : YUV 4:2:2
               [yuv444  ]     : YUV 4:4:4
               [zbr     ]     : Zoner Zebra Metafile (preview)
               [zmf     ]     : Zoner Callisto Metafile (preview)
               [zxhob   ]     : ZX Spectrum Hobetta
               [zxscr   ]     : ZX Spectrum standard screen
               [zxsna   ]     : ZX Spectrum Snapshot
               [zzrough ]     : ZZ Rough
rsch
Command line options of nconvert 5.06
Post by rsch »
nconvert -help >help.txt
**[b] NCONVERT v5.06[/b] (c) 1991-2008 Pierre-E Gougelet (Oct 13 2008/07:49:14) **
        Version for Windows NT/9x/2000/Xp/Vista  (All rights reserved)
Usage : nconvert [options] file ...
        Options :
          -quiet            : Quiet mode
          -fullinfo         : Display informations & metadata only
          -v[.]             : Verbose
          -no#              : # not used for numeric operator
          -clipboard        : Import from clipboard
              seq   : Sequential
              sep   : Separate
          -l file : Use file as filelist
              PDF    : 1 (Fax), 2 (Rle), 3 (LZW), 4(ZIP), 5 (JPEG)
                       4 (ZLIB)
          -q value          : JPEG/PNG/FPX/WIC/PDF quality (default : 100)
          -icc              : Use ICC Profile
          -merge_alpha      : Merge alpha by using 'transparent color' (32bits)
          -keepfiledate     : Keep original file data/time
              exif   : Use orientation EXIF tag
          -jpegcrop x y w h : JPEG lossless crop
          -clean value  : JPEG Clean Metadata (EXIF/IPTC/...)
              1      : Comment
              2      : EXIF
              4      : XMP
              8      : EXIF thumbnail
              16     : IPTC
              32     : ICC Profile
              64     : Other markers
          -buildexifthumb  : Try to rebuild EXIF thumbnail
          -thumb width height : Extract thumbnail
          -use_cie   : Use CIE Colors (PS/EPS/PDF ghostscript)
              hp49   : Write HP49
          -high_res             : Load high resolution (Camera RAW)
          -raw_autobalance      : Auto balance (Camera RAW)
          -raw_camerabalance    : Camera balance (Camera RAW)
          -raw_autobright       : Auto brightness (Camera RAW)
        Process :
          -32bits           : Convert in 32bits
              or #x #y for offset
          -colours num
              k : even or odd
              n : dup or int
              light/medium/heavy
          -emboss           : Emboss
          -levels b w       : Levels
          -negate           : Negate
          -noise type value
              hermite  : Hermite
              gaussian : Gaussian
              bell     : Bell
              bspline  : Bspline
              mitchell : Mitchell
              lanczos  : Lanczos 3
          -rotate_flag      : Rotate flags
              smooth : Use smooth rotate
          -sepia            : Sepia
          -shear            : Shear
          -slice            : Slice
              rbg   : RGB->RBG
              bgr   : RGB->BGR
              brg   : RGB->BRG
              grb   : RGB->GRB
              gbr   : RGB->GBR
          -text_rotation degrees : Rotation
          -truecolors
              phase        : (0.0 360.0)
        Available format:
               [2d      ]     : Amapi
               [411     ]     : Mavica
               [a64     ]     : Artist 64
               [abs     ]     : Optocat
               [acc     ]     : Access
               [aces    ]     : Aces200
               [adex    ]     : ADEX
               [afx     ]     : Auto F/X
               [aipd    ]     : AIPD image
               [anv     ]     : AirNav
               [arf     ]     : ARF
               [art     ]     : Artisan
               [aurora  ]     : Aurora
               [b16     ]     : PCO
               [bdr     ]     : Brender
               [bfli    ]     : BFLI
               [bga     ]     : Os/2 Warp
               [bif     ]     : byLight
               [bld     ]     : MegaPaint
               [blp     ]     : BLP textures
               [bmc     ]     : Embroidery
               [bpr     ]     : AAA logo
               [bum     ]     : Poser Bump
               [byusir  ]     : BYU SIR
               [c4      ]     : Edmics
               [cart    ]     : Crayola
               [cdu     ]     : CDU Paint
               [cel     ]     : Kiss Cel
               [cgm     ]     : CGM
               [cpa     ]     : Prism
               [craw    ]     : Camera RAW
               [crg     ]     : Calamus
               [csv     ]  *  : CSV
               [ct      ]     : Iris CT
               [cut     ]     : Dr Halo
               [cvp     ]     : Portrait
               [dali    ]     : Dali Raw
               [dbw     ]     : DBW Render
               [dcpy    ]     : Datacopy
               [dd      ]     : Doodle C64
               [dicom   ]     : Dicom
               [dng     ]     : DNG
               [dol     ]     : DolphinEd
               [dpx     ]  *  : DPX
               [drz     ]     : Draz Paint
               [dsi     ]     : CImage
               [dwg     ]     : AutoCAD DWG
               [ecc     ]     : Ecchi
               [eif     ]     : Eroiica
               [emz     ]     : Windows Comp. Enhanced Metafile
               [fi      ]     : Flash Image
               [fit     ]     : FIT
               [fmag    ]     : FileMagic
               [fmap    ]     : Fenix Map
               [fmf     ]     : Fax man
               [fpr     ]     : Fun Photor
               [frm     ]     : PhotoFrame
               [fx3     ]     : Fugawi Map
               [fxs     ]     : WinFAX
               [g16     ]     : GRS16
               [gbr     ]     : Gimp Brush
               [geo     ]     : GeoPaint
               [gm      ]     : Autologic
               [gmf     ]     : Gamma Fax
               [god     ]     : GoDot
               [gpb     ]     : Sharp GPB
               [gun     ]     : GunPaint
               [hdri    ]     : HDRI
               [hed     ]     : Hi-Eddi
               [hf      ]     : HF
               [hir     ]     : Hires C64
               [hpgl    ]     : HPGL-2
               [hr      ]     : TRS 80
               [hru     ]  *  : HRU
               [hsi     ]     : HSI Raw
               [icd     ]     : Core IDC
               [icn     ]     : AT&T multigen
               [icns    ]     : Mac icon
               [iim     ]     : Inshape
               [iimg    ]     : Interleaf
               [ilab    ]     : ImageLab
               [ioca    ]     : IOCA
               [ipl     ]     : IPLab
               [iss     ]     : ISS
               [jbr     ]     : PaintShopPro Brush
               [jig     ]     : Jigsaw
               [kdc2    ]     : Kodak DC120 Digital Camera
               [kntr    ]     : KONTRON
               [kps     ]     : IBM Kips
               [lda     ]     : LaserData
               [lss     ]     : LSS16
               [lvp     ]     : LView Pro
               [mac     ]     : Mac Paint
               [mgr     ]     : MGR bitmap
               [mh      ]     : Teli Fax
               [ncr     ]     : NCR Image
               [nef     ]     : Nikon RAW
               [nist    ]     : NIST ihdr
               [nsr     ]     : NewsRoom
               [oaz     ]     : OAZ Fax
               [ofx     ]     : Olicom Fax
               [otap    ]     : Oric TAP
               [p64     ]     : Picasso 64
               [pd      ]     : Male MRI
               [pdf     ]  *  : Portable Document Format
               [pegs    ]     : Pegs
               [pfi     ]     : Photo Filtre Studio
               [pig     ]     : Ricoh IS30
               [pixi    ]     : Pixibox
               [pm      ]     : PM
               [prisms  ]     : Prisms
               [psa     ]     : Print Shop
               [ptg     ]     : Artrage
               [pxa     ]     : Pixia
               [pzl     ]     : Puzzle
               [q0      ]     : Q0
               [rad     ]  *  : Radiance
               [raw     ]     : RAW DVR
               [raw     ]  *  : Raw
               [rawe    ]  *  : Raw
               [ray     ]  *  : Rayshade
               [rfa     ]     : Mobile FAX
               [rfax    ]     : Ricoh Fax
               [rix     ]     : ColoRIX
               [sci     ]     : SciFax
               [sfax    ]     : SmartFax
               [skn     ]     : Skantek
               [spot    ]     : SPOT
               [sr2     ]     : Sony RAW
               [ssi     ]     : SriSun
               [stad    ]     : Stad
               [star    ]     : Starbase
               [svg     ]     : SVG
               [teal    ]     : TealPaint
               [tg4     ]     : TG4
               [thmb    ]     : IPod thumb
               [ti      ]  *  : TI Bitmap
               [tile    ]     : Eclipse
               [tiny    ]     : Tiny
               [tjp     ]     : TilePic
               [tnl     ]     : Thumbnail
               [trup    ]     : Egg Paint
               [v       ]     : VIPS Image
               [vfx     ]     : Venta Fax
               [vi      ]     : Jovian VI
               [vicar   ]     : Vicar
               [vid     ]     : Vidcom 64
               [vif     ]     : Verity
               [vista   ]  *  : Vista
               [vit     ]     : VITec
               [vort    ]     : Vort
               [winm    ]     : WinMIPS
               [wmz     ]     : Windows Compressed Metafile
               [wrl     ]  *  : VRML2
               [x3f     ]     : Sigma RAW
               [xif     ]     : Xerox DIFF
               [xim     ]     : Ximage
               [xyz     ]     : Rm2K XYZ
MikeTheWatchGuy
Re: Command line options of nconvert 6.10
Post by MikeTheWatchGuy »
Maybe I missed it, but this information would be great to put into a TXT file and distribute with nConvert. I must have just missed it as it is a little too obvious of a thing to include.
** NCONVERT v6.10 (c) 1991-2011 Pierre-E Gougelet (May 31 2012/21:35:34) **
        Version for Windows NT/9x/2000/Xp/Vista/7  (All rights reserved)
        Options :
          -quiet            : Quiet mode
          -v[.]             : Verbose
          -org_depth        : Load with original depth
          -older n          : Convert only if older than n days
          -overwrite        : Overwrite existing file
          -no_auto_ext      : Don't add extension to output filename
              seq   : Sequential
              sep   : Separate
              Use $ to specify full source pathname
              Use $$ to specify source folder name
                       4 (ZLIB)
          -keep_icc         : Keep ICC Profile from original file
          -icc_in filename  : Input color profile
          -icc_out filename : Output color profile
          -icc_intent value : Intent value
          -icc_bcp          : Black point compensation
          -icc_ie           : Ignore embedded ICC profile
          -add_alpha value  : Add alpha channel (24bits)
          -opthuff          : Optimize Huffman Table (JPEG)
          -dct value         : DCT method
              0  : Slow
              1  : Fast
              2  : Float
          -smoothingf value  : Smoothing factor (0-10)
          -subsampling value : Subsampling factor
              0  : 2x2,1x1,1x1
              1  : 2x1,1x1,1x1
              2  : 1x1,1x1,1x1
          -comp_ratio value: Compress ratio (JPEG2K)
          -max_filesize value: Maximum filesize (JPEG2K)
          -cmyk_space       : Convert if possible in CMYK space
              1      : Comment
              2      : EXIF
              4      : XMP
              8      : EXIF thumbnail
              16     : IPTC
              32     : ICC Profile
              64     : Other markers
          -iptc_print tag  : Print IPTC tag value
          -iptc_clear tag  : Erase IPTC tag
          -iptc_set tag value : Set value to IPTC tag
          -iptc_add tag value : Add value to IPTC tag
              hp49   : Write HP49
          -jxr_color value      : JpegXR color format (yuv444, yuv422, yuv420)
          -jxr_filter value     : JpegXR block filtering
              0: off, 1: HP, 2:all
          -gam value            : Gamma (EXR, HDRI), default=1.0
          -wmopacity value  : Watermark opacity (0-100)
        Process :
          -autocontrast     : Auto Contrast
          -autolevels       : Auto Levels
              or #x #y for offset
          -colours num
          -dither           : Use Bayer dithering for conversion (Colors and Grey only)
              k : even or odd
              n : dup or int
              light/medium/heavy
          -emboss           : Emboss
          -floyd            : Use floydSteinberg dithering for conversion (Colors and Grey only)
          -negate           : Negate
          -new bpp w h      : Create new bitmap
          -noise type value
          -replace r g b r g b : Replace color
              hermite  : Hermite
              gaussian : Gaussian
              bell     : Bell
              bspline  : Bspline
              mitchell : Mitchell
              lanczos  : Lanczos 3
          -sepia percent    : Sepia
          -shear            : Shear
          -slice            : Slice
              rbg   : RGB->RBG
              bgr   : RGB->BGR
              brg   : RGB->BRG
              grb   : RGB->GRB
              gbr   : RGB->GBR
          -truecolors
              phase        : (0.0 360.0)
        Available format:
               [2d      ]     : Amapi
               [3fr     ]     : Hasselblad RAW
               [411     ]     : Mavica
               [a64     ]     : Artist 64
               [abr     ]     : PS Brush
               [abs     ]     : Optocat
               [acc     ]     : Access
               [aces    ]     : Aces200
               [adex    ]     : ADEX
               [afx     ]     : Auto F/X
               [anv     ]     : AirNav
               [arf     ]     : ARF
               [art     ]     : Artisan
               [arw     ]     : Sony RAW
               [aurora  ]     : Aurora
               [avw     ]     : Analyze
               [az7     ]     : Analyze-7
               [b16     ]     : PCO
               [bdr     ]     : Brender
               [bfli    ]     : BFLI
               [bga     ]     : Os/2 Warp
               [bif     ]     : byLight
               [bld     ]     : MegaPaint
               [bmc     ]     : Embroidery
               [bpr     ]     : AAA logo
               [bum     ]     : Poser Bump
               [byusir  ]     : BYU SIR
               [c4      ]     : Edmics
               [cart    ]     : Crayola
               [cdu     ]     : CDU Paint
               [cel     ]     : Kiss Cel
               [cgm     ]     : CGM
               [che     ]     : Cheese
               [cpa     ]     : Prism
               [crg     ]     : Calamus
               [csv     ]  *  : CSV
               [ct      ]     : Iris CT
               [cut     ]     : Dr Halo
               [cvp     ]     : Portrait
               [cwg     ]     : CreateWithGarfield
               [dali    ]     : Dali Raw
               [dbw     ]     : DBW Render
               [dcpy    ]     : Datacopy
               [dd      ]     : Doodle C64
               [dicom   ]     : Dicom
               [dng     ]     : DNG
               [dol     ]     : DolphinEd
               [dpx     ]  *  : DPX
               [drz     ]     : Draz Paint
               [dsi     ]     : CImage
               [ecc     ]     : Ecchi
               [eif     ]     : Eroiica
               [erf     ]     : Epson RAW
               [fff     ]     : Imacon/Hasselblad RAW
               [fgs     ]     : Fun Graphics Machine Hires
               [fi      ]     : Flash Image
               [fit     ]     : FIT
               [fmag    ]     : FileMagic
               [fmap    ]     : Fenix Map
               [fmf     ]     : Fax man
               [fpr     ]     : Fun Photor
               [frm     ]     : PhotoFrame
               [fx3     ]     : Fugawi Map
               [fxs     ]     : WinFAX
               [g16     ]     : GRS16
               [gbr     ]     : Gimp Brush
               [gcd     ]     : Gigacad (Hires)
               [geo     ]     : GeoPaint
               [gm      ]     : Autologic
               [gmf     ]     : Gamma Fax
               [god     ]     : GoDot
               [gpb     ]     : Sharp GPB
               [gun     ]     : GunPaint
               [hdri    ]     : HDRI
               [hed     ]     : Hi-Eddi
               [hf      ]     : HF
               [hir     ]     : Hires C64
               [hpgl    ]     : HPGL-2
               [hr      ]     : TRS 80
               [hru     ]  *  : HRU
               [hsi     ]     : HSI Raw
               [icd     ]     : Core IDC
               [icns    ]     : Mac icon
               [ifx     ]     : IcoFX
               [iim     ]     : Inshape
               [iimg    ]     : Interleaf
               [ilab    ]     : ImageLab
               [ioca    ]     : IOCA
               [ipl     ]     : IPLab
               [ipl2    ]     : IPLab
               [ipseq   ]     : ImagePro Sequence
               [iss     ]     : ISS
               [jig     ]     : Jigsaw
               [jxr     ]  *  : JPEG XR
               [kntr    ]     : KONTRON
               [kps     ]     : IBM Kips
               [kro     ]  *  : Kolor Raw Format
               [lda     ]     : LaserData
               [lsm     ]     : Zeiss LSM
               [lss     ]     : LSS16
               [lvp     ]     : LView Pro
               [mac     ]     : Mac Paint
               [mef     ]     : Mamiya RAW
               [mgr     ]     : MGR bitmap
               [mh      ]     : Teli Fax
               [mon     ]     : Mono Magic
               [mos     ]     : Leaf RAW
               [mpo     ]     : Multiple Picture
               [mrc     ]     : MRC (Medical Research Council)
               [ncr     ]     : NCR Image
               [nef     ]     : Nikon RAW
               [nifti   ]     : Nifti
               [nist    ]     : NIST ihdr
               [nrw     ]     : Nikon RAW
               [nsr     ]     : NewsRoom
               [oaz     ]     : OAZ Fax
               [ofx     ]     : Olicom Fax
               [ols     ]     : Olympus Scan
               [otap    ]     : Oric TAP
               [p64     ]     : Picasso 64
               [patps   ]     : Photoshop Pattern
               [pd      ]     : Male MRI
               [pegs    ]     : Pegs
               [pfm     ]     : PFM graphic
               [pig     ]     : Ricoh IS30
               [pixi    ]     : Pixibox
               [pld     ]     : PhotoLine (preview)
               [pm      ]     : PM
               [prisms  ]     : Prisms
               [psa     ]     : Print Shop
               [psb     ]     : Adobe Photoshop (large)
               [ptg     ]     : Artrage
               [pxa     ]     : Pixia
               [pzl     ]     : Puzzle
               [q0      ]     : Q0
               [rad     ]  *  : Radiance
               [raw     ]  *  : Raw
               [raw1    ]     : Sinar RAW
               [raw2    ]     : AVT RAW
               [raw3    ]     : Casio RAW
               [raw4    ]     : Contax RAW
               [raw5    ]     : Creative PC-CAM RAW
               [raw6    ]     : Foculus RAW
               [raw7    ]     : Leica RAW
               [raw8    ]     : Micron RAW
               [raw9    ]     : Panasonic RAW
               [rawa    ]     : RoverShot RAW
               [rawb    ]     : ST Micro RAW
               [rawdvr  ]     : RAW DVR
               [rawe    ]  *  : Raw
               [ray     ]  *  : Rayshade
               [rdc     ]     : Rollei RAW
               [rfa     ]     : Mobile FAX
               [rfax    ]     : Ricoh Fax
               [rix     ]     : ColoRIX
               [rsrc    ]     : Mac OSX Resource
               [rw2     ]     : Panasonic LX3 RAW
               [rwl     ]     : Leica RAW
               [rwz     ]     : Rawzor
               [sci     ]     : SciFax
               [sfax    ]     : SmartFax
               [sif     ]     : SIF MICHEL-Soft
               [skn     ]     : Skantek
               [spot    ]     : SPOT
               [srw     ]     : Samsung RAW
               [ssi     ]     : SriSun
               [stad    ]     : Stad
               [star    ]     : Starbase
               [svg     ]     : SVG
               [teal    ]     : TealPaint
               [tg4     ]     : TG4
               [ti      ]  *  : TI Bitmap
               [tile    ]     : Eclipse
               [tiny    ]     : Tiny
               [tjp     ]     : TilePic
               [tnl     ]     : Thumbnail
               [trup    ]     : Egg Paint
               [txc     ]     : PS2 TXC
               [v       ]     : VIPS Image
               [vfx     ]     : Venta Fax
               [vi      ]     : Jovian VI
               [vicar   ]     : Vicar
               [vid     ]     : Vidcom 64
               [vif     ]     : Verity
               [vista   ]  *  : Vista
               [vit     ]     : VITec
               [vort    ]     : Vort
               [winm    ]     : WinMIPS
               [wrl     ]  *  : VRML2
               [x3f     ]     : Sigma RAW
               [xif     ]     : Xerox DIFF
               [xim     ]     : Ximage
               [xyz     ]     : Rm2K XYZ
