XnViewMP and silent association
Moderators: XnTriq, xnview
KiboOst
Post by KiboOst » Tue Mar 13, 2018 4:22 pm
I would like to copy the zip (portable) version of XnViewMP on another computer and silently associate image files with it.
I see there is the Associate files with XnViewMP.exe but it doesn't seem to take arguments to run silently like for example:
Associate files with XnViewMP.exe -register -all
Is there some common reg file or other way to do it with MP ?
Thks
Re: XnViewMP and silent association
Post by xnview » Thu Mar 15, 2018 9:22 am
you can export the registry HKLM\software\XnViewMP, and import it on the other PC
KiboOst
Post by KiboOst » Sat Mar 17, 2018 9:44 am
Thanks, I will try that.
So without anything in HKEY_CLASSES_ROOT all jpg, tiff etc files will open with xnviewmp ? On Win7 x64 ?
KiboOst
Post by KiboOst » Mon Mar 19, 2018 10:18 am
Ideed, this alone doesn't work
Post by xnview » Mon Mar 19, 2018 11:08 am
yes sorry you need the root classes
