**** Please do not post bugs or requests in this topic!
**** In this new test version 0.90 beta 1 various bugs have been fixed. All reported bugs that aren't listed in the changelog below will be fixed in a later release. Please do not re-report a bug which wasn't fixed yet.
XnView 0.90 beta 1 is available for beta testing. You can download XnView MP 0.90 beta 1 here:
Windows x64 ZIP version: http://www.xnview.com/beta/XnViewMP-win-x64-beta1.zip
If you have reported one or several bugs listed below, we'd kindly ask you to check with the latest version whether the bug really has been fixed and confirm this with a short note in the specific topic with the bug report.
Thank you for your help!
Changelog 0.90:
1376: [New] Open XML file thumbnail support - viewtopic.php?f=82&t=37031
1374: [New] File list thumbnails + detail view
1369: [New] Search on others XMP fields - viewtopic.php?f=110&t=36957
1360: [New] Setting to disable drag&drop custom order
1357: [New] Resize 150% option - viewtopic.php?f=60&t=36496
1379: [Bug] File format color - viewtopic.php?f=82&t=37045
1378: [Bug] No message in Favorite menu if favorite doesn't exist - viewtopic.php?f=104&t=30769
1377: [Bug] XMP not correctly written by IPTC dialog
1375: [Bug] Slideshow: Bad image shown if click before end of animation
1373: [Bug] Split: Red grid not always visible - viewtopic.php?f=62&t=37012
1372: [Bug] Paint: Line not dotted with arrow - viewtopic.php?f=83&t=37011
1371: [Bug] Sometimes screenshot saved have 'read only' - viewtopic.php?f=62&t=36747
1370: [Bug] Update catalog doesn't read sidecar anymore - viewtopic.php?f=62&t=36977
1368: [Bug] 'create thumbnails for whole folder' - viewtopic.php?f=62&t=36961
1367: [Bug] Setting to choose 'save changes' - viewtopic.php?f=95&t=36242
1366: [Bug] Pan with Zoom setting - viewtopic.php?p=146522
1365: [Bug] Draw Tool removes metadata - viewtopic.php?f=95&t=36216
1364: [Bug] Can't undo in crop board - viewtopic.php?f=95&t=35858
1363: [Bug] Show info button not toggled - viewtopic.php?f=95&t=36612
1362: [Bug] Convert to jpg - filename with "_1" - viewtopic.php?f=95&t=36146
1361: [Bug] PSD thumbnail pixelated - viewtopic.php?f=95&t=36213
1359: [Bug] Ctrl+Right Click does not work on folders in the tree view - viewtopic.php?f=95&t=36952
1358: [Bug] Eyedropper cannot take the color for the 2ndary color - viewtopic.php?f=95&t=36863
1356: [Bug] Open .SLD - viewtopic.php?f=62&t=36953
1355: [Bug] No trackpad move on MacOSX - viewtopic.php?f=62&t=36947
